Trace example: Get map
No.     Time        Source                Destination           Protocol Info
     1 0.000000    192.168.10.114        128.40.58.202         TCP      3175 > http [SYN] Seq=0 Len=0 MSS=1460
Frame 1 (62 bytes on wire, 62 bytes captured)
   Arrival Time: May 28, 2007 21:50:25.286509000
   [Time delta from previous packet: 0.000000000 seconds]
   [Time since reference or first frame: 0.000000000 seconds]
   Frame Number: 1
   Packet Length: 62 bytes
   Capture Length: 62 bytes
   [Frame is marked: True]
   [Protocols in frame: eth:ip:tcp]
   [Coloring Rule Name: HTTP]
   [Coloring Rule String: http || tcp.port == 80]
Ethernet II, Src: AsustekC_b1:7e:61 (00:0c:6e:b1:7e:61), Dst: Cisco-Li_f7:67:ed  (00:14:bf:f7:67:ed)
   Destination: Cisco-Li_f7:67:ed (00:14:bf:f7:67:ed)
   Source: AsustekC_b1:7e:61 (00:0c:6e:b1:7e:61)
   Type: IP (0x0800)
Internet Protocol, Src: 192.168.10.114 (192.168.10.114), Dst: 128.40.58.202 (128.40.58.202)
   Version: 4
   Header length: 20 bytes
   Differentiated Services Field: 0x00 (DSCP 0x00: Default; ECN: 0x00)
   Total Length: 48
   Identification: 0x9a89 (39561)
   Flags: 0x04 (Don't Fragment)
   Fragment offset: 0
   Time to live: 128
   Protocol: TCP (0x06)
   Header checksum: 0xda31 [correct]
   Source: 192.168.10.114 (192.168.10.114)
   Destination: 128.40.58.202 (128.40.58.202)
Transmission Control Protocol, Src Port: 3175 (3175), Dst Port: http (80), Seq: 0, Len: 0
   Source port: 3175 (3175)
   Destination port: http (80)
   Sequence number: 0    (relative sequence number)
   Header length: 28 bytes
   Flags: 0x02 (SYN)
       0... .... = Congestion Window Reduced (CWR): Not set
       .0.. .... = ECN-Echo: Not set
       ..0. .... = Urgent: Not set
       ...0 .... = Acknowledgment: Not set
       .... 0... = Push: Not set
       .... .0.. = Reset: Not set
       .... ..1. = Syn: Set
       .... ...0 = Fin: Not set
   Window size: 65535
   Checksum: 0xeec2 [correct]
       [Good Checksum: True]
       [Bad Checksum: False]
   Options: (8 bytes)
     2 0.038396    128.40.58.202         192.168.10.114        TCP      http > 3175 [SYN, ACK] Seq=0 Ack=1 Win=5840 Len=0 MSS=1380
Frame 2 (62 bytes on wire, 62 bytes captured)
   Arrival Time: May 28, 2007 21:50:25.324905000
   [Time delta from previous packet: 0.038396000 seconds]
   [Time since reference or first frame: 0.038396000 seconds]
   Frame Number: 2
Ethernet II, Src: Cisco-Li_f7:67:ed (00:14:bf:f7:67:ed), Dst: AsustekC_b1:7e:61  (00:0c:6e:b1:7e:61)
   Destination: AsustekC_b1:7e:61 (00:0c:6e:b1:7e:61)
   Source: Cisco-Li_f7:67:ed (00:14:bf:f7:67:ed)
   Type: IP (0x0800)
Internet Protocol, Src: 128.40.58.202 (128.40.58.202), Dst: 192.168.10.114 (192.168.10.114)
   Version: 4
   Total Length: 48
   Identification: 0x0000 (0)
   Fragment offset: 0
   Time to live: 46
   Header checksum: 0xc6bb [correct]
   Source: 128.40.58.202 (128.40.58.202)
   Destination: 192.168.10.114 (192.168.10.114)
Transmission Control Protocol, Src Port: http (80), Dst Port: 3175 (3175), Seq: 0, Ack: 1, Len: 0
   Source port: http (80)
   Destination port: 3175 (3175)
   Acknowledgement number: 1    (relative ack number)
   Flags: 0x12 (SYN, ACK)
       ...1 .... = Acknowledgment: Set
   Window size: 5840
   Checksum: 0x7ee6 [correct]
   Options: (8 bytes)
   [SEQ/ACK analysis]
       [This is an ACK to the segment in frame: 1]
       [The RTT to ACK the segment was: 0.038396000 seconds]
     3 0.038467    192.168.10.114        128.40.58.202         TCP      3175 > http [ACK] Seq=1 Ack=1 Win=65535 Len=0
Frame 3 (54 bytes on wire, 54 bytes captured)
   Arrival Time: May 28, 2007 21:50:25.324976000
   [Time delta from previous packet: 0.000071000 seconds]
   [Time since reference or first frame: 0.038467000 seconds]
   Frame Number: 3
   Packet Length: 54 bytes
   Capture Length: 54 bytes
   Type: IP (0x0800)
   Version: 4
   Total Length: 40
   Identification: 0x9a8a (39562)
   Fragment offset: 0
   Time to live: 128
   Header checksum: 0xda38 [correct]
Transmission Control Protocol, Src Port: 3175 (3175), Dst Port: http (80), Seq: 1, Ack: 1, Len: 0
   Sequence number: 1    (relative sequence number)
   Flags: 0x10 (ACK)
       .... ..0. = Syn: Not set
   Window size: 65535
   Checksum: 0xc22a [correct]
   [SEQ/ACK analysis]
       [This is an ACK to the segment in frame: 2]
       [The RTT to ACK the segment was: 0.000071000 seconds]
     4 0.039256    192.168.10.114        128.40.58.202         HTTP     GET /api/0.4/map?bbox=11.604978036624916,48.058621827874134,11.607368725108133,48.06093515971922 HTTP/1.1
Frame 4 (400 bytes on wire, 400 bytes captured)
   Arrival Time: May 28, 2007 21:50:25.325765000
   [Time delta from previous packet: 0.000789000 seconds]
   [Time since reference or first frame: 0.039256000 seconds]
   Frame Number: 4
   Packet Length: 400 bytes
   Capture Length: 400 bytes
   [Protocols in frame: eth:ip:tcp:http]
   Type: IP (0x0800)
   Version: 4
   Total Length: 386
   Identification: 0x9a8b (39563)
   Fragment offset: 0
   Time to live: 128
   Header checksum: 0xd8dd [correct]
Transmission Control Protocol, Src Port: 3175 (3175), Dst Port: http (80), Seq: 1, Ack: 1, Len: 346
   [Next sequence number: 347    (relative sequence number)]
   Flags: 0x18 (PSH, ACK)
       .... 1... = Push: Set
   Window size: 65535
   Checksum: 0x77e2 [correct]
Hypertext Transfer Protocol
   GET /api/0.4/map?bbox=11.604978036624916,48.058621827874134,11.607368725108133,48.06093515971922 HTTP/1.1\r\n
       Request Method: GET
       Request URI: /api/0.4/map?bbox=11.604978036624916,48.058621827874134,11.607368725108133,48.06093515971922
       Request Version: HTTP/1.1
   Accept-Encoding: gzip, deflate\r\n
   User-Agent: Java/1.6.0_01\r\n
   Host: www.openstreetmap.org\r\n
   Accept: text/html, image/gif, image/jpeg, *; q=.2, */*; q=.2\r\n
   Connection: keep-alive\r\n
   Authorization: Basic bV9qb3NlbmhhbnNAd2ViLmRlOmJsdWVkaWFtb25k\r\n
       Credentials: [email protected]
   \r\n
     5 0.081467    128.40.58.202         192.168.10.114        TCP      http > 3175 [ACK] Seq=1 Ack=347 Win=6432 Len=0
Frame 5 (60 bytes on wire, 60 bytes captured)
   Arrival Time: May 28, 2007 21:50:25.367976000
   [Time delta from previous packet: 0.042211000 seconds]
   [Time since reference or first frame: 0.081467000 seconds]
   Frame Number: 5
   Packet Length: 60 bytes
   Capture Length: 60 bytes
   Type: IP (0x0800)
   Trailer: 000093C03755
   Version: 4
   Total Length: 40
   Identification: 0xbbc7 (48071)
   Fragment offset: 0
   Time to live: 46
   Header checksum: 0x0afc [correct]
Transmission Control Protocol, Src Port: http (80), Dst Port: 3175 (3175), Seq: 1, Ack: 347, Len: 0
   Acknowledgement number: 347    (relative ack number)
   Flags: 0x10 (ACK)
   Window size: 6432
   Checksum: 0xa7b0 [correct]
   [SEQ/ACK analysis]
       [This is an ACK to the segment in frame: 4]
       [The RTT to ACK the segment was: 0.042211000 seconds]
     6 1.641027    128.40.58.202         192.168.10.114        HTTP/XML HTTP/1.1 200 OK
Frame 6 (729 bytes on wire, 729 bytes captured)
   Arrival Time: May 28, 2007 21:50:26.927536000
   [Time delta from previous packet: 1.559560000 seconds]
   [Time since reference or first frame: 1.641027000 seconds]
   Frame Number: 6
   Packet Length: 729 bytes
   Capture Length: 729 bytes
   [Protocols in frame: eth:ip:tcp:http:xml]
   Type: IP (0x0800)
   Version: 4
   Total Length: 715
   Identification: 0xbbc8 (48072)
   Fragment offset: 0
   Time to live: 46
   Header checksum: 0x0858 [correct]
Transmission Control Protocol, Src Port: http (80), Dst Port: 3175 (3175), Seq: 1, Ack: 347, Len: 675
   [Next sequence number: 676    (relative sequence number)]
   Window size: 6432
   Checksum: 0xb970 [correct]
   HTTP/1.1 200 OK\r\n
       Response Code: 200
   Connection: close\r\n
   Content-Type: text/xml; charset=utf-8\r\n
   Set-Cookie: _session_id=62074a180669c164510847aaf72783d8; path=/\r\n
   Cache-Control: no-cache\r\n
   Content-encoding: gzip\r\n
   Content-Length: 400
   Date: Mon, 28 May 2007 19:46:56 GMT\r\n
   Server: lighttpd/1.4.13\r\n
   \r\n
   Content-encoded entity body (gzip): 400 bytes -> 1259 bytes
eXtensible Markup Language
   <?xml
   <osm
       version="0.4"
       generator="OpenStreetMap server">
       <node
           id="29732149"
           lat="48.0600076198293"
           lon="11.606888413519"
           user="user_1400"
           visible="true"
           timestamp="2007-05-28T20:37:40+01:00">
           <tag
               k="created_by"
               v="JOSM"/>
           </node>
       <node
           id="29732148"
           lat="48.0600973794434"
           lon="11.6060985289149"
           user="user_1400"
           visible="true"
           <tag
               k="created_by"
               v="JOSM"/>
           </node>
       <node
           id="29732147"
           lat="48.0602948505944"
           lon="11.6052368366196"
           user="user_1400"
           visible="true"
           timestamp="2007-05-28T20:37:37+01:00">
           <tag
               k="created_by"
               v="JOSM"/>
           </node>
       <segment
           id="25759071"
           from="29732147"
           to="29732148"
           user="user_1400"
           visible="true"
           timestamp="2007-05-28T20:37:42+01:00">
           <tag
               k="created_by"
               v="JOSM"/>
           </segment>
       <segment
           id="25759072"
           from="29732148"
           to="29732149"
           user="user_1400"
           visible="true"
           <tag
               k="created_by"
               v="JOSM"/>
           </segment>
       <way
           id="4680128"
           visible="true"
           user="user_1400">
           <seg
               id="25759071"/>
           <seg
               id="25759072"/>
           <tag
               k="created_by"
               v="JOSM"/>
           <tag
               k="name"
               v="MyTestStreet"/>
           <tag
               k="highway"
               v="residential"/>
           </way>
       </osm>
     7 1.641079    128.40.58.202         192.168.10.114        TCP      http > 3175 [FIN, ACK] Seq=676 Ack=347 Win=6432 Len=0
Frame 7 (60 bytes on wire, 60 bytes captured)
   Arrival Time: May 28, 2007 21:50:26.927588000
   [Time delta from previous packet: 0.000052000 seconds]
   [Time since reference or first frame: 1.641079000 seconds]
   Frame Number: 7
   Type: IP (0x0800)
   Trailer: 0000A95092D4
   Version: 4
   Total Length: 40
   Identification: 0xbbc9 (48073)
   Fragment offset: 0
   Time to live: 46
   Header checksum: 0x0afa [correct]
Transmission Control Protocol, Src Port: http (80), Dst Port: 3175 (3175), Seq: 676, Ack: 347, Len: 0
   Sequence number: 676    (relative sequence number)
   Flags: 0x11 (FIN, ACK)
       .... ...1 = Fin: Set
   Window size: 6432
   Checksum: 0xa50c [correct]
     8 1.641118    192.168.10.114        128.40.58.202         TCP      3175 > http [ACK] Seq=347 Ack=677 Win=64860 Len=0
Frame 8 (54 bytes on wire, 54 bytes captured)
   Arrival Time: May 28, 2007 21:50:26.927627000
   [Time delta from previous packet: 0.000039000 seconds]
   [Time since reference or first frame: 1.641118000 seconds]
   Frame Number: 8
   Type: IP (0x0800)
   Version: 4
   Total Length: 40
   Identification: 0x9a8c (39564)
   Fragment offset: 0
   Time to live: 128
   Header checksum: 0xda36 [correct]
Transmission Control Protocol, Src Port: 3175 (3175), Dst Port: http (80), Seq: 347, Ack: 677, Len: 0
   Sequence number: 347    (relative sequence number)
   Acknowledgement number: 677    (relative ack number)
   Flags: 0x10 (ACK)
   Window size: 64860
   Checksum: 0xc0cf [correct]
   [SEQ/ACK analysis]
       [This is an ACK to the segment in frame: 7]
       [The RTT to ACK the segment was: 0.000039000 seconds]
     9 1.642565    192.168.10.114        128.40.58.202         TCP      3175 > http [FIN, ACK] Seq=347 Ack=677 Win=64860 Len=0
Frame 9 (54 bytes on wire, 54 bytes captured)
   Arrival Time: May 28, 2007 21:50:26.929074000
   [Time delta from previous packet: 0.001447000 seconds]
   [Time since reference or first frame: 1.642565000 seconds]
   Frame Number: 9
   Type: IP (0x0800)
   Version: 4
   Total Length: 40
   Identification: 0x9a8d (39565)
   Fragment offset: 0
   Time to live: 128
   Header checksum: 0xda35 [correct]
   Window size: 64860
   Checksum: 0xc0ce [correct]
    10 1.686508    128.40.58.202         192.168.10.114        TCP      http > 3175 [ACK] Seq=677 Ack=348 Win=6432 Len=0
Frame 10 (60 bytes on wire, 60 bytes captured)
   Arrival Time: May 28, 2007 21:50:26.973017000
   [Time delta from previous packet: 0.043943000 seconds]
   [Time since reference or first frame: 1.686508000 seconds]
   Frame Number: 10
   Type: IP (0x0800)
   Trailer: 0000BFBEF336
   Version: 4
   Total Length: 40
   Fragment offset: 0
   Time to live: 46
   Header checksum: 0xc6c3 [correct]
Transmission Control Protocol, Src Port: http (80), Dst Port: 3175 (3175), Seq: 677, Ack: 348, Len: 0
   Sequence number: 677    (relative sequence number)
   Acknowledgement number: 348    (relative ack number)
   Flags: 0x10 (ACK)
   Window size: 6432
   Checksum: 0xa50b [correct]
   [SEQ/ACK analysis]
       [This is an ACK to the segment in frame: 9]
       [The RTT to ACK the segment was: 0.043943000 seconds]
