I want to cast a concrete Countertop and I created several test batches. I am confused by what I read and need some double checking.
I use a mixture of 1 Part Cement 2 Part Sand and 0.4 Part Water (weight ratio related to the Cement) and 1.3% plasticizer (ADVA CAST 555)
Here is in detail what I mixed:
8 Liter Sand -> 13 kg
4 Liter Cement -> 5.448 kg
Plasticizer 1.3% of 5.448 kg = 72 gr approx 72 ml (max)
So far all is ok the confusion starts with the water.
What I read the water is measured as a weight ratio related to the cement only, that should not exceed 0.5 (better 0.4).
That would mean in my case 0.4 * 5.448 kg = 2.18 kg = 2.18 Liter
Can somebody confirm that this is all correct? Thx...
Ride Sun
  • 717
    Possible duplicate of [What's the best ratio for sand-only concrete?](http://diy.stackexchange.com/questions/90389/whats-the-best-ratio-for-sand-only-concrete) – Jimmy Fix-it Oct 14 '16 at 15:48
  • It's not a duplicate. The emphasis is on the water calculation. – Ride Sun Oct 15 '16 at 06:15
0 Answers0
