My home has laminate (but appears wood) floors, and I want to emulate what we did in the Military, but I don't know any of the product names (just the slang, Sealer)
I have use Linseed Oil on hardwood floors in the past, and really liked the what I got out of it.
Can I use Linseed Oil on my floor to the same effect, or is there a better product to help protect my floors? (Side note: I don't care about the floors look, I care about keeping the material from becoming damaged)
Also, given the suggested protectant: What would be the best way to clean those now-sealed floors?
Daniel Griscom
  • 6,249
  • 33
Laminate flooring is not made to be sealed after installation. The floors are made with a protective coating that make them durable. Typically they have a good warranty on them. The only problem I had was gaps. My floor was not level and when the seasons changed I would get gaps. I finally solved that from another post on the site.
Mike
  • 448
  • This one? http://diy.stackexchange.com/questions/41528/laminate-floor-sliding-out-of-place/100752#100752 – vulpineblazeyt Oct 14 '16 at 19:08
  • Yeah, most of these floors have a surface impregnated with aluminum oxide, which is nearly as hard as diamond. They're not intended to be waxed, polished, or sealed. – isherwood Oct 14 '16 at 19:29
  • This one. http://diy.stackexchange.com/q/58532/60725 I'm not sure if I added this correctly. Dylan's post was the one. I saw it after the HOD didn't work. – Mike Oct 14 '16 at 19:57
