I've got a number of nice heavy brass hinges with splotches of paint on them. Unfortunately this paint appears to be decades old and is rock-hard. It appears to be old oil-based paint but I'm not sure.
The most visible place where paint was applied is the decorative pins that have ball shaped ends. Scraping or sanding without scratching the brass seems impossible. So that leaves soaking in some sort of stripping agent. Are there any concerns with using such products with brass or any specific products and/or approaches recommended?
JimmyJames
  • 2,032
  • Overnight soak in a bucket of dichloromethane usually does the job. The stuff used to be cheap. Looks pricey nowadays: https://www.google.com/search?q=dichloromethane&ie=utf-8&oe=utf-8#q=dichloromethane&tbm=shop – Wayfaring Stranger Nov 07 '16 at 21:16
    buy a new hinge... – dalearn Nov 08 '16 at 01:32
    If you're going to remove them, cut the paint around them with a utility knife first or you risk taking chunks of the door trim with it. – Mazura Nov 08 '16 at 05:09
  • @Mazura Good advice but the hinges in question are not actually on the door. It's not that these were painted on purpose either. Whoever painted them was too lazy to remove them before painting the frame and trim so there are globs of paint where they touched the hinge with the brush. – JimmyJames Nov 08 '16 at 14:27
  • Not necessarily lazy. Taking off and re-hanging can cause problems if the holes are a little worn. – Wayfaring Stranger Nov 08 '16 at 15:49
  • @WayfaringStranger Slopping paint on hinges haphazardly *definitely* causes a problem. It looks like total garbage. Worn holes are easy to fix with a dowel and some glue. Just sharpen a piece of dowel into a rough point. Slather it with wood glue and pound it into the hole. Take a chisel and cut off any excess. Drill a new hole. You don't really need to wait for the glue to dry. – JimmyJames Nov 08 '16 at 16:20
  • @JimmyJames Yes, I agree, but some people can do the work involved, others will make a total botch of it and have to hire a handyman. – Wayfaring Stranger Nov 08 '16 at 17:19
    @dalearn The cost of the hinge is not a concern but trying to find something at matches the many other hinges is a problem. It's in a room with two other doors with these hinges on one 10 foot wall. A different hinge would be the last resort. – JimmyJames Nov 08 '16 at 19:38
I would remove the affected parts from the door and wall and drop them in a small container which can be a) placed outdoors (for fume abatement) and, b) have paint thinner or Goof Off to soak for minutes or hours.
Except for possible varnish finishes on the hardware, paint thinner has no effect on brass, stainless steel, etc.
wallyk
  • 12,319
  • That's good news. It's possible that there many layers and perhaps some are oil and some are latex. Does it matter what I use if the paint is oil-based or water-based? – JimmyJames Nov 07 '16 at 17:16
  • @JimmyJames: If it is latex paint, soapy water might work (albeit slowly), but paint thinner definitely will. – wallyk Nov 07 '16 at 17:19
    Is there a reason to not use actual paint stripper? – JPhi1618 Nov 07 '16 at 18:35
  • I'm not sure if you have a bucket of "Carb Cleaner" with the basket, but I'm fairly certain there is not much that will not dissolve that is organic in nature, in a carb cleaner. – BrownRedHawk Nov 07 '16 at 20:55
I have just recently done this. I had some 90+ year old doors with so many coats of paint on the hardware that the doorknob would not even turn. The ball ends of the hinge pins looked like mini onion domes.
I used a basic cheap heat gun to loosen the paint and then a combination of brushes and scrapers to clean everything up. I did not care about preserving the brass finish, so I had no qualms about using wire brushes, etc.
You might try applying heat on a part of the hinge leaf that will be hidden from view to see if the finish is affected before you tackle the ball ends. Good luck!
wallyk
  • 12,319
bturnip
  • 111
What I've done in the past is to put the hinges into an old crock pot and let them "cook" for a few hours in just plain water. This will heat the metal to a point where the paint should come off. A little elbow grease and maybe a stiff plastic bristly brush should help get the rest of the paint off. I've also used wooden skewers to help scrape off the paint to save my fingernails.
If you choose this route, I would get a crock pot at a second hand store to use solely for projects like this as I wouldn't want to eat anything out of a slow cooker that was used to soak paint.
yakuza
  • So literally put it on the stove? At a simmer? – JimmyJames Nov 07 '16 at 19:02
  • I personally use a crock pot, but I suppose an old pan would work. Although you may want to do any "cooking" outside or at least in a well ventilated area. – yakuza Nov 07 '16 at 20:04
    Note that said crock pot / pan should **never be used for food preparation** afterwards. Old paint often contained lead, which would be ingested. – BryanH Nov 07 '16 at 22:11
Brake fluid wreaks havoc on some types of paint! If you're lucky, and can wait a day or three for it to work you may find it peeling and bubbling off of its own accord. (Use glycol type fluid, most common anyway dot3 or 4 I believe. Observe material safety recommendations). Should be perfectly safe on any metals commonly found in braking systems
wallyk
  • 12,319
Stax
  • 101
