I'm building a slide, but I can't find any information on what angles are safe yet fun.
What's the appropriate range of angles for a slide?
Per the 2016 Michigan State Handbook for Public Playground Safety:
It is recommended that the average incline of a slide chute be no more than 30 degrees. This can be measured by determining that the height to length ratio (as shown in Figure 18) does not exceed 0.577. No span on the slide chute should have a slope greater than 50 degrees.
Edit 20230528 Original link is dead and it appears that Mighigan now follows the Unites States governmental agency Consumer Product Safety Commission. The original information provided above looks to be accurate, but a new document is referenced (especially pages 34-36).
A 30 degree angle slide is a oversimplification of slide safety rules and makes for a very slow slide. The ratio is the height of the sliding surface divided by the total length of the slide. The height is measured from the exit point to the start of the sliding surface, not from ground level. The length should take into account an exit section (1 foot long or more) with an inclination not exceeding 10 degrees to allow drainage, to slow the speed of the rider. The change of inclination should have a radius of 30 inches. As you see, adding the exit sections and the radius makes the angle of your slide steeper than 30 degrees. I believe that around 37 degrees is a fun slide, anything over 40 will look too steep for most users, but will work with a longer exit section.
