We recently bought a little old house with a detached garage that had been converted into a study or studio. There's a great sagging bundle of cables running from the main house to the studio. Some are obviously phone lines, some look like coax cable. None are obviously power lines, but there's definitely electricity in the studio.
We don't have a landline and when we set up our cable they ran a new cable line, and I assume that if we ever wanted a landline they'd start that from scratch, too. So I'd really like to cut these cables, but I obviously don't want to go out with my wire cutter and snip the power line.
Where the power lines come into the main junction box from the street they run through porcelain insulators. I haven't figured out where the power for the studio actually runs.
I've tried to trace them to their respective sources, but at various points they've been painted over and it is really hard to sort out where each wire is coming from or going to.
So my question is: how do I ensure that I won't electrocute myself before I cut any particular wire?
Amanda
  • 1,120
    Post a picture of what you want to cut for better info. – Tyson Feb 27 '17 at 21:59
    Individual power wires may "look" like coaxial cables, from the outside. Round wires look much the same. I'd suggest relaxing about the "great sagging bundle of cables" until you trace where the power actually runs, first. Odds are pretty good it's 3 or 4 of those cables. Words of whiz-dumb for the day: "If it ain't broke, don't fix it." – Ecnerwal Feb 28 '17 at 02:44
    If you're not sure what you're doing, then the risk of electrocution is not worth taking. Hire a qualified electrician. – Dawood ibn Kareem Feb 28 '17 at 02:54
  • @tyson thx! I'd like more confidence than "that doesn't look like a power line" – Amanda Feb 28 '17 at 03:28
  • @Amanda there may be things that are definitely not power, there may be others where the advice is let's talk about that wire, but if we can look at what you are looking at, you WILL get better advice. – Tyson Feb 28 '17 at 03:39
    Well I mean, if you wear thick gloves, shoes, cover your skin, and chop away, you're not going to electrocute yourself. Start a fire or do some damage maybe, but electrocute yourself, no. – Jason C Feb 28 '17 at 04:13
    Right, I should have mentioned that there are more risks than just electrocution that are not worth taking. If you don't want to set fire to your house, and don't want to kill yourself, then for the love of God, hire a qualified electrician. No offence to anyone who might answer this question, but you absolutely should NOT trust the advice of a bunch of strangers on the internet to keep yourself safe. – Dawood ibn Kareem Feb 28 '17 at 04:28
  • @DavidWallace you'll be relieved to know that this is neither the beginning nor the end of my research. – Amanda Feb 28 '17 at 04:53
    Good. Please stay safe! :-) – Dawood ibn Kareem Feb 28 '17 at 05:01
  • Do not listen to @JasonC, unless you are attempting to win a Darwin Award. You should never intentionally cut live wires, regardless of the amount of (DIY) 'safety gear' you think you are wearing. – gregmac Feb 28 '17 at 17:06
  • @gregmac What I said is true. I did not say it was a good idea, nor did I limit it to "diy safety gear". Calling an electrician is the right choice. – Jason C Feb 28 '17 at 17:30
If you go over to Amazon and search "voltage sensor" you can find several quality sensors for less than fifteen bucks. Once you have it, you can place the probe near the wires in question, and the probe will signal if there is any hazardous voltage present. This is an item that should be in any Do-It-Yourselfer's tool box.
BillDOe
  • 1,415
  • I don't need to puncture the insulation to check for live currents? – Amanda Feb 27 '17 at 20:50
  • No. The device works off of induction, and there doesn't actually need to be any current flow in the wire being tested. – BillDOe Feb 27 '17 at 20:51
    "*Non-contact voltage tester*", "*voltage detector*", "*voltage tester*". Any of these search terms should work. – Tester101 Feb 27 '17 at 21:08
    Make sure to test the NCVT on a known-live power wire (even a switched-on lamp cord will do) before using it to test unknown wires. Don't want to be fooled into a false sense of security by a faulty tester or dead batteries. – mmathis Feb 27 '17 at 21:43
    Also be aware that some voltage testers will both light up **and** emit a sound when voltage is detected, but the sound may be muted by holding the power button when turning it on. I was working in another room when a first time user only paid attention to the sound, but since he was unaware that he muted it he incorrectly assumed the wire was dead. Sparks flew, but luckily he was not electrocuted. – llogan Feb 28 '17 at 00:23
  • @LordNeckbeard - And that situation just goes to show the importance of mmathis's comment. – AndyT Feb 28 '17 at 10:22
    Related: [When doing electrical work, what do I use to check wires are safe?](http://diy.stackexchange.com/q/90038/2815) – RedGrittyBrick Feb 28 '17 at 14:27
  • @RedGrittyBrick actually, I think this is really a duplicate of that question. Flagging as such. – Amanda Feb 28 '17 at 15:30
Fuses!
Like everybody is saying, get an electrician.
But, if you aren't going to do that, here is a checklist.
  • use a voltage checker to find power lines. Mark them.
  • turn off or unscrew any fuses that may or may not be relevant.
  • check that the power is indeed off in the area.
  • wear your rubber gloves and boots and other protective equipment.
  • cut the non-power wires.
  • isolate the ends of each wire.
  • turn fuses on again.
  • in case of fire, turn fuses off again before trying to put out fire.
  • call electrician to fix the mess you made.
Stig Hemmer
  • 111
  • for the longer term "isolate the ends of each wire" is the most problematic one. It should be done and *marked* properly. – Rsf Feb 28 '17 at 09:59
