The modular plugs or what I like to call "end-caps" for Cat6 cable, I have the kind where you can push the cable all the way through then cut so you know you have proper cable alignment. I thought this would be the best way to go so I don't have to dreadfully stare at the modular plug to determine if the wiring is in the right order.
Well, what I have noticed is that it is impossible for me to cut the wiring back far enough which creates excessive amount of "noise" and crosstalk and is just a bigger issue than what I imagined. Am I doing something incorrectly or is this just a hazard of using this type modular connector?
EDIT
Below are images of my crimp work - looks good to me, but the cable is still not functioning!
Image 1
Image 2
    It's much easier (and cheaper) for the novice user to buy pre-made patch cables rather than make them. If you have unterminated cable (e.g., run through a wall) get a punch down keystone jack or patch panel to terminate the ends; don't crimp on an RJ-45 jack – mmathis Mar 06 '17 at 16:35
  • Probably wrong type of wirecutters. Pictures of the tools and the connectors as you wired them would be required to make any better answer. – Ecnerwal Mar 06 '17 at 16:36
  • @mmathis - I am making 4 runs through my home, and the Cat6 has been run, now I Just need to actually terminate the ends. Was just checking if there was an easier way to accomplish this, or if I got a bad batch of keystones. I like the idea of the punch down keystone jack. I don't think a patch panel would really work, as I am going from a router downstairs to a switch upstairs - then from the switch to the rooms needing a wired connection – BellHopByDayAmetuerCoderByNigh Mar 06 '17 at 16:40
  • @Ecnerwal - I will get a better crimp tool & wirecutter and see if makes a difference. Thanks for the advice. – BellHopByDayAmetuerCoderByNigh Mar 06 '17 at 16:41
    Don't rush into wasting more money without first posting pictures. And taking mmathis's advice if it applies. If you don't know what's wrong with the type of wirecutter, you won't know what's a better one to buy, for instance. A better quality of the wrong type may be a great cutter that's of no benefit to your problem... – Ecnerwal Mar 06 '17 at 16:43
    @BellHopByDayAmetuerCoderByNigh See a previous answer of mine: http://diy.stackexchange.com/questions/107401/is-my-plan-for-wiring-ethernet-reasonable/107411#107411 for a schematic of how home network wiring is typically done. If I understand you correctly, you'll have 4 connections going from the switch - one to each room - this could be a patch panel, and they make small panels. Though, again, the mantra is buy bigger than you need now, so even a 12-port patch panel would be a good choice (and they're only ~$15 or so) – mmathis Mar 06 '17 at 16:47
    The "proper" way is to put a keystone jack in a wall plate in the room, and a keystone jack or patch panel at the central location where all the cables terminate. You then can use short pre-made patch cables to connect from the jack to your switch/router/PC/etc. – gregmac Mar 06 '17 at 16:47
  • Yep @mmathis's linked answer is exactly what I was trying to explain. This setup gives a lot of flexibility as you can patch any jack as LAN or regular phone line. – gregmac Mar 06 '17 at 16:53
  • @mmathis - ah I see from your link. I was going from switch to switch, and I should be going from switch to patch panel – BellHopByDayAmetuerCoderByNigh Mar 06 '17 at 17:06
  • Wires appear to be untwisted too far on the incoming side. How are you testing these "failed" and at what speed(s)? There does not appear to be excess wire on the cut end as you described, so given "excess noise and crosstalk" (determined how?) I'd look at your lack of twists. – Ecnerwal Mar 07 '17 at 22:32
  • @Ecnerwal - untwisted to far? What do you mean? When I say failed, I mean when I go to plug into computer & router it does not work. – BellHopByDayAmetuerCoderByNigh Mar 08 '17 at 13:29
  • They make a special crimper for these types of connectors that crimps and trims the excess. Costs about $80 but will give you cleaner cut offs. Platinum Tools 100054C – OrganicLawnDIY Mar 13 '17 at 18:08
    @BellHopByDayAmetuerCoderByNigh You've cut the jacket too far back, and untwisted too much length of the wires. The jacket should extend underneath the crimped portion of the RJ-45 plug, and the wires should remain twisted as much as possible - no more than about 1/2" should be untwisted - and most of that is inside the "channels" at the end of the jack. Cat6 is far less tolerant of this than cat5e. – mmathis Mar 13 '17 at 18:16
Pin 6 is not crimped. Your crimp die is defective or you need to try again.
All the pins should be at the same level.
not a good crimp
But really, punch-down into jacks and buy patch cables as already suggested. Cheaper and more reliable.
When you're learning to crimping these, you really need to have a cable tester.
Generic Cat5 cable tester
These plug into both ends and cycle through each conductor, showing you if there are any disconnected or miswired.
Tester in action
Once you identify the problem you can fix it. Be prepared to cut off and redo connectors a few times while learning.
gregmac
  • 28,910
  • 84
  • Good recommend, I will def invest in one of these. I will say that atm, for every 12 modular connectors I add, only 1 cable is good (so 2/12 are good) – BellHopByDayAmetuerCoderByNigh Mar 07 '17 at 20:42
  • Well there are two connectors on every cable, and in each of those, 4 conductors that are critical to ethernet (orange and green pairs): all it takes is for one pin on one connector to be broken and the cable "won't work". (FYI the other two pairs -- blue and brown -- are used for gigabit and PoE; for analog phone, only the blue pair is used) – gregmac Mar 07 '17 at 20:53
  • Interesting to know, I had no idea that blue & brown pairs were used for that. – BellHopByDayAmetuerCoderByNigh Mar 07 '17 at 20:56
    Gigabit is the basic ethernet of today - 10 and 100 are legacy, and Cat6 speaks of a thought of going to 10 Gig (though 6A is preferable.) So all wires are used in the current standards as applicable to most equipment for sale in 2017. The tester pictured only shows connectivity, not the qualifications needed for a 10-gig Cat6 install. Those testers cost much more. Also pin6 is clearly (at full size) not properly crimped on the first picture. – Ecnerwal Mar 07 '17 at 22:34
-1
Your key problem is that pin 6 is not crimped. Today's switches use auto-negotiation to determine speed (10/100/1000) and half or full duplex. Without pin six the switch can't negotiate and the link will not come up. Look up on the ol' interweb and search for quality features to look for in a crimper and invest in a good crimper.
Mar
