There are pressure treated (4"x4") fence posts (set in concrete) nearby to a house. In that area there were previously termites (professionally treated in-ground). This is in a humid region, along the Ohio River (USA) valley.
Is it desirable to apply a termite preventative product (e.g. a borate solution) as well?
Would this be beneficial or purely a waste of money?
Kris K.
  • 165
    From what I've been told, pressure treated wood loses it's pressure treatedness over time (especially in very damp locations). – Tester101 Jan 10 '12 at 21:33
  • depend if the pressure treatment also protects against them (some wont, some will) – ratchet freak Jan 10 '12 at 22:01
  • This is ACQ pressure treated wood, and seems to be the standard for home store use. A decrease in effectiveness would be concerning. – Kris K. Jan 12 '12 at 01:54
It's beneficial. Here in Texas, where it is humid and wet and we also have a lot of ground-based termites, I use TimBor for posts and rot sills in fences.
The problem is, you want to have put that treatment on the wood before it goes in the concrete. At this point, your best method of preventing termites from getting into the structural portions of your fence are to keep dirt, grass, and yard debris away from the fence, and make sure that the concrete 'caps' stay above the level of dirt and grass so that there isn't organic material or termite "straws" along the concrete leading to the posts.
Karl Katzke
  • 7,825
  • 44
