25
We are moving into a house with a fire-place. The current tenants (friends of ours), have been living there just short of 2 decades, and have never used it once.
The house is about 90 years old, so it certainly saw a lot of use once upon a time.
I myself rather enjoy a fire. Though I've not lived in a house with one, since I was a kid. Not really planning on using it for heating, but for a couple of times in the winter it would nice to be able to use it just for the enjoyment of the thing.
Is there anything I should do before using it?
Should I be worried about the chimney being blocked?
How would I go about inspecting for that?
    Clear out the birds' nests. And squirrel nest. – Hot Licks Jun 20 '17 at 12:42
    My opinion: If you have gas, consider an insert or logs. A wood fireplace has a negative energy rating. They are fun and sexy but also dangerous and wasteful. – JimmyJames Jun 20 '17 at 15:16
  • @JimmyJames I don't plan to use it for regular heating, just for occasional use, maybe a dozen times a year, if that. – Frames Catherine White Jun 20 '17 at 15:36
    OK. Just realize that it will pull more energy up the chimney than it will contribute. The main problem is you need to leave the flue open after the fire has died down. In any event make sure you get a safety inspection/cleaning. I knew I guy who looked up to see his ceiling on fire due to a crack in the chimney. – JimmyJames Jun 20 '17 at 15:41
    With an old chimney, converting from wood/coal to gas can increase the dangers. If you have leaks from a wood/coal fire chimney into an upstairs room, you will smell the smoke even if you can't see it. With gas, you won't smell the carbon monoxide! Living in the UK, I've no experience of the specific issues with wood-framed buildings. – alephzero Jun 20 '17 at 18:13
  • @alephzero Gas fireplaces are required (in the US) to have built-in carbon monoxide detectors. Many are rated for use with no extra ventilation. I have a dedicated CO detector one in the room with the gas fireplace, the furnace, each living area, and a combination smoke/CO detector in every bedroom. The dangers of gas fireplaces are much less than with wood (which can produce CO without smoke.) I wouldn't even put a wood fireplace in a new home. I had one in a new-ish townhouse and we had to open a window to get enough draw to prevent smoke from entering the house. – JimmyJames Jun 20 '17 at 20:33
    Inform your insurance company that you have a fireplace. – Andy Jun 20 '17 at 22:25
  • Also a good reason to get a chimney sweep. A friend of mine tried to do it himself. He got some soot in his eye and ended up getting a pretty severe infection in his eye. At least wear goggles. – Caimen Jun 21 '17 at 15:48
  • Fit a stove - it is far more efficient than a fireplace. You won't get random ambers flying across the room. Also the stove installer will do all the checks for you. Stoves will radiate heat after the fire has died. – cup Jun 22 '17 at 12:47
You hire a chimney sweep to inspect (and clean) it. In some cases it may need to be completely rebuilt - in others, it may simply need cleaned and inspected, or it may need something in the middle.
At that age, you may well find that you'll face relining to make use of it under modern conceptions of what's safe - it will have deteriorated with age and probably was not built to standards that are considered safe these days in the first place.
There are ways to solve that problem, but which way is applicable will vary with the state of the chimney, and any work that might have been done to it in the 70 years before it was disused for 20 years, as well as what's been going on inside it for 20 years.
  • At this age the chimney may not be lined above the fire box, I recently removed an entire fireplace from my 1930 farm house the stone work was beautiful and appeared to be in good shape. I inspected it and found there was no liner above the damper and it was only 1 stone wide as it entered the attic. In my opinion this old unit would have been a fire just waiting to happen so I removed it we are using a pellet stove now, it would have been nice to save it because it looked nice but the hearth area was not large enough for even a small insert. – Ed Beal Feb 21 '18 at 14:34
22
Another thing to consider with a chimney that old is the distinct possibility that the bricks were laid up with a mixture of sand, horse hair and a bit of lime mixed in. It is not uncommon for a chimney like that to have the external weather at the roof line and above erode away some of or all of the sand leaving the bricks literally free stacked with spaces between them. Use of a chimney in that condition can set your house on fire if sparks sneak out through the cracks and smolder in your roofing material and rafters.
Another thing with old old chimneys is that they used to think that it was right OK to use the interior surface of the bricks as the heat exposed surface of the stack. Now days the chimneys are built with a much different construction with some type of liner that isolates the brick/blocks of the chimney from the heat in the stack. The liner could be a high tech triple wall stainless steel stack ($$$) or a more contemporary liner that is a fired clay affair with an inside glazed finish. Such liners are specially mortared with a refractory cement which is a special high temperature silicate material.
One of the reasons that liners are used is that it gives the interior wall of the chimney a smooth surface so that there is much less chance of tar, pitch and gum build up in the chimney as opposed to what happens on the inside of a plain brick chimney with rough bricks and mortar joints. Chimney fires that resulted from these deposits catching fire when an especially hot fire was in progress in the fire place were rather common place often leading to a good part of a house or all of it burning down. As a matter of fact in my young years in a farming community in the 50's and 60's there were at least four such fires that I recall left the families without a home.
Michael Karas
  • 64,093
  • 63
  • 142
    +1 for "...can set your house on fire if sparks sneak out through the cracks..." but it's not simply sparks or embers that are dangerous. Hardwood burns at 900F or more. A gap in the chimney is like having a propane torch inside the wall. In an older house, if the tiles have shifted, you could have a lot of gaps as well as edges for creosote to gather. This is a serious thing. You need to have a licensed chimney sweep inspect and clean your chimney. – JimmyJames Jun 20 '17 at 15:15
If someone offers to modernise your chimney by putting some sort of metal tube or liner inside, make sure the chimney is cleaned first and all soot is removed. If this is not done properly, you risk having a fire in the space between the tube and the chimney, which you (or the fire brigade) won't be able to reach to put out.
Consider installing a wood-burning stove with a glass door in the same fireplace, along with a suitable new liner in the chimney. You get the look of the flames combined with modern technology to keep the heat in the house and not burn it down.
You might even get a grant from your local authority.
RedSonja
  • 537
    Seconded. A wood-burning stove gets a lot more heat into your room, from less wood. With an open fire, far more heat goes up the chimney. – nigel222 Jun 21 '17 at 08:32
    I was *amazed* when we moved from a house with an open fire to a house with a wood-stove how much more heat we got, and how much less wood we burned. It is truly amazing the difference (and modern wood-burners give you a decent view of the flames provided you scrub the glass with paper every time you light it). – Martin Bonner supports Monica Jun 21 '17 at 12:08
If you want this to be a working fireplace you will need to first have it inspected and swept by a chimney sweep. The chimney sweep can do a smoke test to check for issues such as leakage and blockages. This involves setting off a small smoke pellet and looking to see if smoke comes out the chimney at the top, and anywhere else it shouldn't be.
At his point you may find that the inside of the chimney has issues such as being blocked up, or even be at risk of internal collapse. If the pointing is in poor shape this could let gasses through into rooms which are passed by the chimney. The inside may have become rough which will reduce the flow of air up the chimney due to friction. The usual solution to these issues is to fit a flue liner which will offer some support. These can be flexible and fitted by shoving (to use the technical term) them down the chimney from the top.
Be warned though that this can be easier said than done. In my circa 1830 house the flue has bends and a few holes (small, about 500mm square) had to knocked in walls to get access and clear blockages.
If you do require a flue, in the UK it must be fitted by a HETAS registered installer. An incorrectly fitted flue and fireplace can lead to carbon monoxide poisoning.
crobar
  • 201
