My dryer is vented through a crawl space and as it exits the space it will run up hill. Is this creating a problem by code or will it collect lint and moisture and clog prematurely?
Asked
Active
Viewed 5,131 times
How long is the entire vent? How many bends? How long is the sloped part, and what's the vertical distance? – Niall C. Aug 02 '17 at 15:51
I would think lint balls would be your only issue where it raises. Once a year cleaning that be done on all dryer vents should be good. + up north. – Ed Beal Nov 14 '17 at 15:15
The International Residential Code (IRC 2009) has no restrictions or requirements for clothes-dryer exhaust ducts to have any pitch, either up or down, although they are also required to conform to the "dryer manufacturer's installation instructions".
Upnorth
- 808
- 4
- 8
Always run dryer vent piping a at least a 3% grade to the outside to allow any moisture to run to the exterior to the building , " common sense and 55 years in the industry"
2Hello, and welcome to Home Improvement. Does significant amounts of moisture accumulate in dryer ducting? And, you should probably [take our tour](//diy.stackexchange.com/tour) so you'll know how best to contribute here. – Daniel Griscom Oct 18 '20 at 20:41
