The staple or brad that connects the control bar to several of the shutters have come off. Some of them are completely lost. How do I repair this?
Asked
Active
Viewed 526 times
I used to own and run a Blind business. Living in Florida, a majority of our volume were shutters. I would suggest getting a staple that is slightly longer than the one that came out and then pushing the new one in.
I would protect the lever with a towel and then use a wide wrench, like a plumbers wrench, to squeeze the staple in. Another option which would probably be easier would be to use the same size staple that fell out and use a two-part epoxy to set them in the holes. You may have to get a small syringe to inject the mix into the tiny holes before inserting the staple.
Evil Elf
- 3,704
- 8
- 46
- 56
Sounds pretty simple, I'll give that a shot and get back to you. – Shane Feb 13 '12 at 18:07
Plastic syringes are available for these types of uses. My wife works at a vet, so these are at my disposal. If you use one with a metal needle, be VARY careful. Injecting yourself with epoxy would be dangerous. – Evil Elf Feb 14 '12 at 13:45
I would add that since I use epoxy to hold the crown staple into the control arm or blade I pre drill two tiny holes to make insertion easier. – Kris Feb 02 '21 at 17:18
I just started using gel Cyanoacrylate cements; pretty useful for something like this. – Evil Elf Feb 02 '21 at 21:26
