6 ft tall 4x4 PT post out of plumb by 1-3/8". Excellent condition. Years old. Set in cement. Rock solid in part because tree roots have encased the cement. Tree too valuable to risk damaging roots by removing old post and cement, or placing new post nearby.
I plan to replumb the post by crosscutting about 2/3 the way through the post at 12" above the top of the cement. This will weaken it enough to bend at the kerf. Once replumbed (past plumbed, actually, to balance out forces), scab on 30" length of 2x4 PT, fitted to the bend, on the side with the kerf.
Question is on which side of the post should the kerf be placed? on the "overhanging" side so that the kerf opens when bent plumb? or on the sloped side so that the kerf closes when plumbed? Aesthetically doesn't matter.
EDIT: or maybe snap a plumb line from top to bottom, then saw off the "overhanging" 6 ft wedge, then scab it on to the sloping side.
Aoba Brute
    Your second (edited-in) idea is a good one. It leaves the bottom of the post nearly full-thickness. It will be challenging to get clean, straight, well-aligned cuts from both sides, however. – isherwood Oct 05 '17 at 19:05
    what is not clear is what the post is for and why it is imperative that it be plumb and its dimentions be 4x4? . can you pretend you are Leonardo Da Vinci and see the straight board inside the 4x4 and remove everything that is not straight and plumb?. – Alaska Man Oct 06 '17 at 04:27
    Unless you need to mount to both sides of the post, use the edit solution, but without cutting anything off. Just trim a 2x4 into a wedge and attach it to create a vertical surface on the side you need, If the post is also rotated so that the face isn't parallel with the next post, you can cut a compound angle on the wedge to correct both at once. – fixer1234 Jul 21 '18 at 04:44
Stronger if the kerf pinches, the reason being ...
Consider a post that is simply crosscut as mentioned (not reinforced with the 2x4 scab). This weak point will fail much more easily when the post takes a load (bent) in the direction that opens the kerf, as opposed to the opposite direction. This is because the post, when loaded in that direction, is vulnerable to splitting-out at the kerf. When loaded in the opposite direction (that closes the kerf), the post is not vulnerable to splitting out, but would break due to tension failure. Intuitively, it would take much less load to split out than to fracture under tension. If you don't trust my intuition, try this on a 2x4 to see which direction it more easily breaks.
Now consider a post that is crosscut and then reinforced with 2x4 scab as mentioned. If the kerf was placed so that replumbing opened the kerf, then the post would be under a permanent partial load to split out. If the kerf was placed so that replumbing closed the kerf, then the the post would be under a permanent partial negative load to split out, and under a permanent partial load for tension failure. Intuitively, the later makes for a much stronger repair.
The theoretical kerf width required for the closed-kerf scenario is 4 * 1.375 / 60 = 0.092, or about 3/32".
Attach the 2x4 scab with numerous smaller fasteners (not in the same grain line) rather than a couple large fasteners.
As for option two, snapping a plumb line, the easier thing to do is cut a short piece of 2x4 that is 1-3/8" long, then use it to space off one end of straight 6' 2x4 when screwing (or clamping) the 6 footer temporarily to the the post on the opposite side of the cut, then use an adjustable ripping T-guide (that came with the circular saw) to carry out a uniform width rip. Make the rip top to bottom on one side, then bottom to top on the other, keeping the wide part of saw shoe on the post. If the post is too thick for the rips to meet (6x6) complete the rip with a third pass using a sawzall.
In the end, I used the closed kerf method, and attached the trimmed-to-fit 2x4 scab with 12 torx head 3" screws and full caulk. When hit with a fist, it vibrates just as the intact post did, like a tuning fork, though rigidity and strength are not the same. If I had to do it over again, I'd use the same approach.
Aoba Brute
    Hi, please come back and click the check-mark next to your self answer. This is a perfectly acceptable thing to do here, and it prevents the system from automatically bumping your question to the top of the pile every now and then (since it doesn't have an accepted answer). Thanks, and congrats for figuring this out on your own! – FreeMan Jun 04 '20 at 16:25
You could try a Simpson E-Z Mender for fence posts.
https://www.buildsite.com/pdf/simpsonstrongtie/E-Z-Mender-Product-Data-1461816.pdf
Lee Sam
  • 23,095
  • 44
