So when you install wood siding over a Tyvek house wrap, you take care to flash and seal all penetrations from plumbing, HVAC and electrical connections to make sure no water can get in... then you riddle it with nail holes when you nail the siding in place!
Why isn't there any concern about water penetration into the house through the nail holes? Does Tyvek seal itself around the nail holes? Or does nobody worry about it?
Nick
  • 1,562
  • 51
While products like Tyvek do act as a drain plane to some extent, they're not truly waterproof. They're designed to allow vapor to easily pass, and therefore they're inherently an imperfect waterproofer. They should be considered a second line of defense against flawed siding installation and occasional wind-blown water intrusion.
The flashing around windows and other penetrations has as much to do with stopping airflow as it does with stopping water. Housewrap is mostly concerned with air leakage, which can dramatically affect the energy efficiency of a building's envelope.
The bottom line is that nails in the field are less likely to be subject to water on a regular basis, and they do somewhat self-seal. Window flashing is much better at self-sealing and is used in high-risk areas. Housewrap should not be considered a substitute for proper siding drain planning. Steel and vinyl siding channels, for example, must lap properly in order to direct the flow of water outside the siding.
    Allowing vapor to pass does not in any way affect the material's "perfection" as a waterproofer. Vapor is not liquid water, and several products stop liquid water completely but pass vapor just fine. That's what differentiates them from vapor barriers. – Ecnerwal Oct 31 '17 at 16:39
    I agree, but I didn't want to get to pedantic. We're talking about Tyvek and similar products, which are not perfect waterproofers, probably due to manufacturing compromises. – isherwood Oct 31 '17 at 16:48
    You'll notice that [DuPont's literature language](http://www.dupont.com/products-and-services/construction-materials/building-envelope-systems/faqs/wb-faq.html) is careful to use the term "bulk water". It's fairly obvious why to me. :) – isherwood Oct 31 '17 at 16:51
  • Tyvek is slightly elastic, though, so in fact it does tend not to leak around nails. – keshlam Sep 24 '23 at 12:26
I have experience with that issue from back in 1999. I was building new homes in Southwest Washington in an area exposed to higher than average wind. We removed siding on two new homes for different reasons and what I saw ended my use of Tyvek ever since. Both homes had horizontal lap siding so there were rows of nail penetrations on every stud. Rain water was hitting the siding and traveling upward under the 1-1/4" overlap. They say that rainwater can travel 1" vertically for every 10mph of wind blowing on it. I can confirm that it happens.
There were no problems within 6' of the roof overhang. The water ran horizontally across the top of the siding until it hit a window or corner where it then poured down over the Tyvek. Every nail hole in the field had a 4" to 6" wet spot behind it. It was probably sucked in by a pressure difference. Once it was in it stayed there. The Tyvek held it in better than keeping it out.
At the lower part of the corners and below the sides of the windows were the worst situations. So much water got through that there were large wet areas with swollen OSB. The water was trapped and not evaporating through the Tyvek or nail holes.
I never built another Tyvek house. I switched to 15lb felt over plywood and then to 30lb. 30lb felt seals the nail holes, keeps water out and lets vapor pass through. It will probably still be good in 200 years. I never had another water problem on a single house after switching.
  • Yeah, perched water's a pain in the butt -- see https://buildingscience.com/documents/insights/bsi-057-hockey-pucks-and-hydrostatic-pressure for more info on the phenomenon – ThreePhaseEel Sep 24 '23 at 02:11
  • Good info, but this doesn't answer the question. We're not a discussion forum. Please take the [tour]. – isherwood Sep 24 '23 at 14:20
