Can someone tell me if this plumbing is acceptable? Looks like some type of vent. I am plumbing newb.
Asked
Active
Viewed 119 times
Looks like an air admittance valve (AAV). They are allowed in some areas. You'd have to check with local building codes, to know if they're allowed where you are. Your local building department should be able to tell you, but I would suspect they are allowed (unless the plumbing was installed by an amatuer).
- 78
- 316
- 608
Does it require any maintenance ? – ecco88 Nov 21 '17 at 13:33
Also I don’t see how air is being admitted in - especially the bottom example – ecco88 Nov 21 '17 at 14:36
@ecco88 the second image is a "*drum trap*". Sorry I didn't realize you were asking about both fittings. – Tester101 Nov 21 '17 at 14:51
