I need to change the wax ring on my toilet. The closet bolts that hold it in place are rusted so I need to cut them in order to remove the nuts.
I thought of trying bolt cutters. The bolt cutters I have are, I believe, 24 inches, but they are too big to fit into the space I need to fit them in order to cut the bolts.
What is the smallest size of bolt cutters that can reliably cut those closet bolts holding down the toilet to the floor? Or is there another tool I can use?
Mowzer
  • 345
    Maybe a Dremel tool instead of bolt cutters? Or a nut splitter if it will fit? As far as bolt cutters, it isn't so much the size of the cutter as your strength. – fixer1234 Dec 04 '17 at 05:01
    Use the Dremel as suggested by many others - works like a charm and is very inexpensive - wear EYE protection when you do this - I have done exactly this kind of thing before many many times. Forget the bolt cutters - dremel is more useful and every bit as fast on these. – Ken Dec 04 '17 at 08:08
  • @Ken: I hear you. Have you got any tips for how to deal with the fact that in between and flush with the nut and porcelain toilet, there are two washers—one metal, the other plastic. So there is no gap to go at cutting the bolt directly. That's why I thought about bolt cutters. But as others have pointed out, there are major problems with that approach. So I'll abandon that now. So should I try to attack the nut itself with the Dremel? When I tried this, it seemed like it was going to be a long battle. What does your experience say about my approach? And what tips and tricks can you suggest? – Mowzer Dec 04 '17 at 08:40
    @Mowzer start cutting the nut on an angle not perpendicular but say on a 45 degree. You will need to cut it in two places (preferably where you can access it with a flat tip screw driver 180 out from each other). After you cut into both sides (you only need most of the way about 80-85% or so)- cut one side a bit wider (or use a wider cutting wheel) so you can - insert your screw driver into the cut out . Then TWIST the blade and the nut will split in half. Works like a charm. – Ken Dec 04 '17 at 08:56
    I made your question focus on the problem (cutting rusted closet bolts) instead of your suggested solution (bolt cutters), which avoids the [XY Problem](https://meta.stackexchange.com/questions/66377/what-is-the-xy-problem/66378#66378) without invalidating the answers – Machavity Dec 04 '17 at 13:29
  • @Ken: This is the correct answer. It works as advertised. Those additional details regarding the approach was what I needed to go from zero to hero. Please consider posting your comment as an actual answer within the next couple of days so I can upvote it and accept it. – Mowzer Dec 04 '17 at 16:12
    Have you tried WD40? http://www.taproot.com/content/wp-content/uploads/2013/08/wd40-ducttape.jpg – yo' Dec 05 '17 at 17:55
  • @Mazura: Please elaborate with details. How could a vice grip be used? – Mowzer Dec 09 '17 at 06:15
  • [How to remove {a fastener with a stripped head}?](https://diy.stackexchange.com/a/10479/23295) With [vise-grip locking pliers](https://diy.stackexchange.com/a/126294/23295) – Mazura Dec 09 '17 at 16:50
  • @Mazura: The problem is the nut and the bolt spin together. And there's no way to get anything in there to grip the bolt at the same time to keep it from spinning with the nut. – Mowzer Dec 09 '17 at 20:34
9 Answers9
19
Bolt cutters are not really the best tool for cutting off rusted closet bolts. I usually use a "mini-hack" saw:
Jimmy Fix-it
  • 35,093
  • 55
  • Thanks for your answer. I've actually heard that before. But did not understand why. What advantage/s does a mini-hacksaw have over bolt cutters for this job? – Mowzer Dec 04 '17 at 05:51
    @Mowzer - It will get into tight places. But it will take forever and a day to make the cut, especially if you use the wrong blade. – Hot Licks Dec 04 '17 at 13:23
  • Oh yeah, I've totally done this with my toilet before! Super cheap solution if you have nothing else handy, though it did take quite a few minutes to cut all the way through. – Ogre Psalm33 Dec 04 '17 at 13:54
    That's the poor man's version, but Black and Decker makes a reciprocating saw for about $45 that will make quick work of these bolts. The bolt cutters will likely as not break the toilet in the process of cutting the bolts. – jmarkmurphy Dec 04 '17 at 15:23
  • Even cheaper is to just buy a single hack saw blade and wear gloves. – Astor Florida Dec 05 '17 at 01:13
18
I would caution against using any bolt cutters on the toilet hold down bolts. The reason being that they typically will apply a significant pressure against the porcelain base of the stool and crack or break it.
Another thing to consider is that bolt cutters typically have a jaw profile as shown below. With this type of arrangement it is just not possible to get a grip in the small size of the bolt at or below the nut.
You will be far better off using a mini hand hacksaw as shown in another answer or a Dremel tool with a grinding wheel cutoff blade.
An alternative if you do not have a Dremel tool but do have an oscillating tool is to use a metal cutting blade in that. Note that it is my experience that the typical metal cutting blades for these saws do not last as long as you would hope and they are much more expensive than a few cutoff wheels for a Dremel tool.
Michael Karas
  • 64,093
  • 63
  • 142
    great answer with the dremel pictures included. I use the dremel all the time in this situation even though I have a minihacksaw and the oscillating tool - the dremel is it. – Ken Dec 04 '17 at 08:10
  • Unfortunately, I have not been able to find decent metal cutting blades for an oscillating tool. The ones they sell will cut nails, but not hardened screws. – Hot Licks Dec 04 '17 at 13:25
  • @HotLicks - I agree with you on metal cutting blades for an oscillating tool. That is the reason I made specific comment in the answer above. There may be technical or safety reasons why an oscillating tool blade cannot be made as hard and sharp as a typical high quality hack saw blade. I could envision a type of blade made with a short length of hack saw blade spot welded to the end. I wonder if one could take a worn out oscillating tool blade and adapt it some how to clamp on a section broken from a hack saw blade to the end. On the other hand ... (continued below) – Michael Karas Dec 04 '17 at 14:29
  • (continued from above) On the other hand the standard hack saw blades are really designed to cut with force applied in one direction only. If you bear pressure on a hand operated hack saw as the blade moves in both directions you will wear out the blade faster than otherwise. Also hack saw blades are generally designed for slow operation. Neither of these points is going to be met regarding the oscillating tool which is both very fast and trying to cut in both directions. – Michael Karas Dec 04 '17 at 14:34
    @MichaelKaras it would be worth reinforcing the importance of wearing gloves and safety glasses when using the dremel, and removing anything flammable from the vicinity. Source: I have cut many bolts and other metal items using a dremel. Get ready to see sparks fly, literally. –  Dec 04 '17 at 17:16
  • @Hot Licks I have installed/de-installed perhaps a dozen and a half toilets, and I have yet to see anything other than brass bolts. Nor have I seen any other type of toilet bolt for sale anywhere in North America. Except for stainless, steel rusts. Brass does not. Brass is soft and easily cut. I have used hacksaws many time for this, but an oscillating tool would be much much preferable. – MickeyfAgain_BeforeExitOfSO Dec 04 '17 at 20:14
  • @mickeyf - Yeah, I've only done maybe 6, and I never paid close attention to the material of the bolts and nuts. I would hope that they're either brass or SS, but no telling what comes with Chinese stuff these days. – Hot Licks Dec 04 '17 at 20:19
  • @gwally mentions in a comment to another answer that some are brass plated steel. This is absolutely true and I have seen them (actually bought them by accident). I found out when I cut them shorter to facilitate installation of plastic decorative covers (sometimes you have to cut them depending on closet flange height in relation to floor and toilet base). Now I carry my little screwdriver with the magnet on one end, to test them at the store. Brass bolts are easily and quickly cut using a hacksaw, I don't like getting too close to a client's porcelain with power tools. – Jimmy Fix-it Dec 06 '17 at 02:08
Cutting the bolts might not be the best solution. Closet bolts are typically made of brass which does not rust. However, there can certainly be other types of corrosion present, as well as dirt, grime, and mineral deposits if water got in there (you do need to replace the wax ring, after all). This means that the nuts are likely not fused to the bolts, but just need some encouragement to break loose.
Before attempting to remove the bolts, I recommend spraying them with a product such as Penetrating Blaster.
Can of PB
Let it soak into the area around the nut for a minute or two. Next, get a socket wrench and pick the smallest socket that will fit over the nut and torque it free. If you cannot get the nut to move, try using a breaker bar which provides more leverage. If you do not have access to a breaker bar (you really should have one and they do not cost a lot), you can improvise with a box wrench and a narrow metal pipe slipped over the handle (cheater bar).
Cutting those bolts would be further down on my list of options. In order to keep the toilet firm on the floor without rocking back and forth the bolts should be moderately tight. Cutting through one of them may cause a sudden shift of weight which may cause damage such as cracking the porcelain near one of the bolt holes, or the saw blade may nick the enamel coating on the toilet. If you must use a saw, I would prefer a rotary tool such as a Dremel with the proper metal-cutting blade. Be sure to wear both gloves and safety glasses, move anything flammable away from the work area, and cover trim, drywall, anything nailed down that you do not want damaged. This will create a lot of hot sparks.
    I second this. In my case the entire bolt was spinning so a ratchet was useless. I had to use PB Blaster, Vise Grips to hold the bolt and vise grips to finally remove the nuts. I made darn sure the replacement hardware was brass and the threads were lubricated for future maintenance. – gwally Dec 04 '17 at 23:16
  • You are confusing a cheater bar with a breaker bar. A cheater bar extends your tool to provide more leverage. a breaker bar is a non-ratcheting socket driver designed to take more abuse than a ratchet. I recommend not using a cheater bar with a ratchet (particularly cheap ones) as that may break the ratchet. Using a cheater bar with a box wrench is fine. – hildred Dec 05 '17 at 16:13
  • @hildred thanks, I guess I grew up being taught the wrong terminology. I always thought my breaker bar was just a wrench with a long handle. Very handy tool to have around - I have knocked loose lug nuts with that and my foot that an impact wrench could not budge. TIL... –  Dec 06 '17 at 01:25
Toilets are fragile. This is a recipe for cracking the toilet (then finding out the tank and base are unusual and effectively a matched set, and now you need a whole new toilet and how do you dispose of an old toilet in this city?)
You want low-violence, low-impact methods.
  • Hand hacksaw.
  • Dremel moto-tool, a steady hand, goggles, and plenty of cutoff discs.
Both of them apply little enough force that they are unlikely to crack the toilet when they slip. However they will take awhile.
Typically closet bolts are brass so I'm a little surprised to read that they are rusted. One option that I don't think has been mentioned is that if you can just use a socket wrench to snap the nuts/bolts off.
Take a socket wrench with an extension so that the handle is a few inches above the base sticking forward from the toilet. Take a length of pipe a foot-and-a-half or so and place if over the handle. This extra leverage should allow you to 'persuade' the nut to move, or if it's really on there, the bolt will snap. Either way it should come off. It might be tricky in a really tight bathroom but something to consider.
JimmyJames
  • 2,032
  • Some bolts are brass plated or coated to look like brass. If they're not brass, they definitely rust. – gwally Dec 04 '17 at 23:17
  • Just keep turning until it gives or it breaks. +1 – Mazura Dec 05 '17 at 16:17
  • You could also easily break the flange with all that torque. Cutting them is slow without a power tool but worth it if it spares the flange. – Kris Dec 06 '17 at 01:59
  • @Kris I doubt it. I've snapped quite a few bolts without any extra leverage. The flange should be much stronger than the bolt. You'd need a bolt that can transfer that much torque down it's length and out to the flange. I guess I am assuming the flange is cast iron though. I suppose if it's PVC, that could be a concern. – JimmyJames Dec 06 '17 at 16:14
  • As luck would have it a lot of homes here in South Carolina USA have pvc flanges – Kris Dec 06 '17 at 16:39
  • PVCs have stamped steel flanges. It is *possible* that you could damage it, but I doubt it. I've definitely lost count of how many I've pulled, and I've never been defeated by a fastener. Cutting is for after this doesn't work. – Mazura Dec 08 '17 at 00:51
My usual course of action involves using a Dremel with a cutoff wheel as @ Michael Karas has suggested. My technique involves cutting off and bolt that extends through the nut. Then cut vertically through the nut. By moving slightly from left you will cut the nut and not hit the porcelain. A thin piece of cardboard with a small hole placed over the nut may provide a little extra protection if the tool slips.
mikes
  • 11,165
When I added new bolts to the toilets I replaced, the bolts came longer than they needed to be (helps with installation) but there's a bare spot for cutting to proper length. I used my angle grinder with a 1mm cutting disc to cut them off.
I would caution against using any kind of motorized movement tool as well (the aforementioned oscillating blade or a reciprocating saw) because the same dangers of cracking the toilet apply. A grinder or Dremel will apply steady directional pressure. Anything that moved the blade back and forth (especially on metal) may have unpredictable movements if the blade binds up.
  • A reciprocating saw works great for this if you have room around the toilet to get to it, just make sure the blade is sharp. – jmarkmurphy Dec 04 '17 at 15:28
    @jmarkmurphy Reciprocating saw will cut through almost anything, but is not delicate enough for this task. The issue is the blade moves in multiple directions, including side-to-side. When you need to make a precise cut in one narrow location, it would be one of my last options. The other issue is given the large and clumsy size it could damage the porcelain. I have one toilet with (thankfully) cosmetic damage from where I tried to cut a bolt using a reciprocating saw. –  Dec 04 '17 at 17:21
  • I second using a grinder; I've used one many times for exactly this application. – canadianer Dec 04 '17 at 21:11
Um, the real problem is stuck bolts. Perhaps you should try heating the bolts up with a blow torch. This works beautifully for anything where you can apply an open flame without damaging the surrounding area. If you are worried about damage you can surround the work area with a welding blanket or even a sopping wet towel that you don't care about destroying. Heat those suckers up and then immediately put a wrench on them and start turning. If you can get the nut to move a little bit, spray some PB Blaster or Liquid wrench on there, tap it lightly with a hammer (repeat a few times) and then remove the nut with a wrench.
My primary socket set is a fantastic Craftsman set with hollow centers. No matter how long the bolt the socket wrench slides right on. Something like that would work perfectly for this situation. I'd recommend that tool set, but you can probably get a deep socket on there as well which would be a big help.
Also, it would probably behoove you to take a wire brush and clean up the exposed threads as best you can before removal.
My Dad swears by Liquid Wrench and he is an absolute master at removing stuck/rusted bolts. He would say spray the crap out of it with Liquid Wrench, tap it and repeat. The tapping is to vibrate the bolt/nut so the Liquid Wrench can work into the rusted nut. Let it soak in Liquid Wrench for as long as you can. (Whenever I'm planning on disassembling a rusted part I try to Liquid Wrench/PB Blaster it for DAYS leading up to the actual "work")
When you go to put everything back together, obviously use stainless steel or brass hardware if it's new, but also definitely coat the bolt threads with some Anti-seize
PatHenry52
Instead of attacking the problem from below the toilet bowl, you could work from the top. The bolt will have a flat top that you can see on the bottom of the flush tank. You can use a dremel to cut it off, but a simpler option would be to drill in the center of the bolt head with a drill bit larger than the bolt diameter. Once you drill through, the head will split from the bolt. I've done that before in the same situation. It works quite well.
Next time make sure the bolt is stainless...
-- A bit of clarification... our toilet tanks here (France) are mounted with this kind of stuff:
The bolt head and rubber cone go into the tank, and the rest pokes out of the bottom, which results in something like that:
So the method I used was to drill the head of the bolt off. It works pretty well.
bobflux
  • 8,767
  • He's not removing a toilet seat. – Hot Licks Dec 04 '17 at 13:26
  • @HotLicks misunderstanding... fixed ;) – bobflux Dec 04 '17 at 13:35
  • How do you rotate the flange bolt from below the toilet? – Hot Licks Dec 04 '17 at 14:09
    Hmm... got a picture? Do US toilet bolts install the other way around from ours?... – bobflux Dec 04 '17 at 14:19
  • @peufeu: Difficult to say without knowing which part of the planet "ours" refers to. US toilets are certainly very different from UK toilets (which are typically *screwed* to the (sub)floor, not *bolted* down to a metal flange and which usually connect to a "soil pipe" at *rear*, not *below*). – RedGrittyBrick Dec 04 '17 at 14:33
  • Since I tested the "drill the bolt head off" method and it worked nicely, I removed the other which was unclear... – bobflux Dec 04 '17 at 16:40
    OP is referring to a wax ring and closet bolts holding the *toilet to the floor*, not the gasket and wing nut/bolt combo that holds the tank to the toilet. Though this could still be a useful answer for others in that second situation. – CactusCake Dec 04 '17 at 17:51
    Cool, I had never heard of a wax ring before, that explains the misunderstanding. The way to do it here is completely [different](https://www.google.fr/search?q=pipe+droite+wc&safe=off&client=opera&hs=yOd&source=lnms&tbm=isch&sa=X&ved=0ahUKEwiJvd3D_PDXAhUJLcAKHVGvABYQ_AUICygC) and I have no idea how this is called in English... OP will have to slip a hacksaw blade under the toilet then, been there done that too! – bobflux Dec 04 '17 at 18:27
