I have a pair of LED porch lights. One of them has started to flash/flicker. Do I need to replace it? It is not a bulb; it is built in. It is extremely cold out. Could that be a factor?
Asked
Active
Viewed 1.2k times
-1
Hello, and welcome to Stack Exchange. Are these lights on a switch, or a dimmer? Any chance that bumping the LED might cause/cure the problem? If so, then it's wiring rather than the fixture, and should be checked out quickly. – Daniel Griscom Jan 02 '18 at 02:20
1I have the same problem. It flashes on a very regular cycle, probably twice per second. No dimmer and it started without a change in wiring and bumping it or changes in temperature don't seem to change it. It had been working fine for years, I expect it's going bad although I would hope for longer life from LED. Built in light means I have to replace the whole fixture too. – Uriah Blatherwick Jan 08 '20 at 01:17
Duplicate of https://diy.stackexchange.com/questions/184868/one-of-the-outdoor-garage-lights-in-continuously-flashing-when-turned-on-why-t ? – keshlam Mar 03 '23 at 01:20
Have you tried swapping the bulbs between positions to see if the flickering follows the bulb? – Huesmann Mar 03 '23 at 15:38
I had this happen and it turned out that there was an outdoor circuit with 12 outdoor coach lamps on it. Flashing meant "find the bad bulb". I wound up replacing all of the bulbs a few flashing sessions later as it often counted old bulbs with poor seating as bad. I prefer a non flashing system tbh.
Tim Chavez
- 11
- 1
