The house I recently bought (over 100 years old) has had almost all of its wiring replaced with a new elctrical board. However, in two cases the new wiring has been connected to existing knob-and-tube wiring in a junction box, with the ground wire not connected. So the knob-and-tube wiring is still in place, fed by new wires coming from the panel. Can I just disconnect the knob-and-tube wiring, leave it where it is, and bypass it with new wiring? If I can leave the disconnnected knob-and-tube wiring, do I have to label it somehow?
2possible duplicate of [Should old knob and tube wiring be replaced?](http://diy.stackexchange.com/questions/20/should-old-knob-and-tube-wiring-be-replaced) – Niall C. Mar 23 '12 at 14:32
1@NiallC. that question talks about old wiring that's still in use, whereas this question is about old *unused* wiring. – ChrisF Mar 23 '12 at 15:09
1@chrisf: Quoting this question: "So the knob-and-tube wiring is still in place, fed by new wires coming from the panel." How does this make the wiring _unused_? – Niall C. Mar 23 '12 at 15:21
@NiallC. - missed that :) The rest of the question read like it was dead. – ChrisF Mar 23 '12 at 15:27
Only thing I found in NEC 2008 was in reference to communications/data/low voltage cable, and cable in metal raceways. – Tester101 Mar 23 '12 at 15:30
Near as I can tell, you should remove all "easily" removable sections. The stuff secured in the walls can stay, but you have to remove any sections that are "exposed". No unused cable can exist in metal raceways, so if it goes through conduit you'll have to pull it out. – Tester101 Mar 23 '12 at 15:34
Seems to be, this is not covered in NEC because the disconnected wire is no longer part of the electrical system. Might be covered by NFPA. – Tester101 Mar 23 '12 at 15:41
Yes, you can leave the knob-and-tube wiring in place. Labeling is neither required nor common, but if things are confusing enough that you think it's warranted, it can't hurt. It's also a good idea to rip out whatever wiring is accessible (e.g., in an unfinished basement).
If you have an electrician do the disconnection work, you should ask the electrician to sign a form certifying that all knob-and-tube wiring has been removed. Such a form is sometimes required before blowing in insulation, or when selling the house.
- 9,575
- 18
- 58
- 86
The typical process of disconnecting an unused wire while leaving it in the wall is to join the hot(s) and neutral at each end so that it's obvious that it's unused and any attempt to reconnect it would trip a breaker. And I hope that no crazy electrician would ever want to reconnect an old knob and tube line. I would take the extra step to completely remove it from anywhere that it's easily accessible.
- 42,687
- 14
- 92
- 197
2+1 on the shorting it together solution. A note, written in pencil, on a nearby building member can help also. Pulling K&T out of walls is just about impossible, because of the robust nature of the knobs that clamp the wires. – Bryce Jul 24 '18 at 06:41
