I recently moved into an in-law unit of a large old house. In the kitchen, there are two pipes coming out of the wall (one protruding out a little more than the other). I had assumed they were gas lines to connect my stove. But since the stove only connects to one pipe, I'm now wondering if they're actually water lines. Can anyone explain how I can tell the difference? On the other side of the wall is a large closet with the air conditioning system, water heater, and what I think is the gas shutoff valve.
3What material are the pipes? A picture would be helpful for sure. Can you see them and where they go from underneath in the basement/crawlspace? – gregmac Mar 23 '12 at 18:50
Also, what size are the pipes? What is the pipe diameter? – auujay Mar 23 '12 at 18:55
Gas lines are usually made of steel or flexible steel pipe. In the older days cast iron was used. – Jon Raynor Mar 23 '12 at 19:21
My gas lines are made of copper. – Owl Jul 17 '19 at 19:58
You should be able to tell by the color, and connections used.
Gas
"Black pipe" is commonly used for natural gas, and is dark grey/black.
All connections will be threaded.
Water
Water lines come in a variety of materials, some of the most common are.
Copper
This will be um... copper, in color.
While there are other ways to join copper pipes, the most common is solder.
Galvanized
Galvanized pipes will be a light grey.
And use threaded connections similar to black pipe.
Plastics
You might also find various types of plastic-ish water pipes. These can come in a variety of colors. Red, blue, white, black, etc.
These may use compression type connections, crimp connections, or various other type or connectors.
Still can't decide?
Try using your other senses.
Touch the pipe.
If it's warm to the touch, it's likely hot water (may not be warm unless hot water was recently used). Hold the pipe and have a helper turn a nearby tap on/off quickly, to see if you can feel vibrations. Try running the water for a bit, then touch the pipe to see if the temperature changes. If the pipe gets colder/hotter, it's likely a water line.
Listen to the pipe.
Put your ear to the pipe, and again have a helper turn on a nearby tap. If you hear the water clearly in the pipe, you found yourself a water line. (make sure the pipe is not in contact with any other pipes when you do this, since sound could be transferred to the other pipe). This is not the most accurate method, but it can sometimes work.
Taste the pipe.
This won't help you at all. I just pictured people licking pipes in my head, and thought it was funny. You could tell your helper to do it, and then laugh at them when they do it. But it's not going to help you figure out what the pipe is.
2@dbracey I think in this case, pictures are more helpful than words. – Tester101 Mar 24 '12 at 18:50
I would add to your answer. Older houses are likely to have brass pipes instead of copper. Oh, and taste would help, iron tastes different than copper though I wouldn't try it with any of the pipes in my house :P – Yitzchak Mar 25 '12 at 18:39
A gas line will usually have a shutoff valve at the end of it. It's usually made of cast iron, steel, flexible steel, or copper.
Here are some pictures of typical stove pipe configurations.
If it just a metal pipe sticking out of the wall, ask the owner of the house what it is or have a plumber come out and look at it. Don't assume anything.
- 3,516
- 3
- 25
- 28
What do the pipes connect to inside that closet? Trace from where the pipes penetrate the wall back. Do they connect to the water heater or other water pipes?
Compare the pipes coming out of your water heater (at the top, where the water side is) to the pipes coming out of the wall. If they match, thats a good sign its a water pipe.
- 4,162
- 12
- 47
- 67
Method 1: I had this problem, one way is to half close the valve on one side of the pipe (this will cause a hiss when water flows through it caused by the water turbulance going through a narrow opening - try it on a known water tap first like a sink stop tap to see what i mean), turn off all the taps and wait for the toilet to finish filling up etc, turn off the boiler.
Feel the pipe first to see if it's warm, if it's warm, it's hot water.
Listen to the pipe. It should be quiet. Turn on the cold taps all over the house so that they are running quietly and flush the toilet. Go back and listen to the pipe. If the pipe hisses, it's water flowing through it, and it's connected to the cold water.
If it doesn't hiss, turn off the cold taps and wait for the flush to finish filling, open up all the hot taps over the house, listen again, is it hissing? If so, it's a hot water pipe - cold water generally flows through the hot water pipes when the boiler is offline.
If it's hissing when both cold water and hot water taps are on, then it could be the cold water intake for the boiler.
If it doesn't hiss ever, then there's a good chance it's gas. Remember to leave the stop tap in the position it started in.
Method 2: Turn it off and see what taps, if any, stop working.
Another thing to note is, if the pipe has cladding around it, like insulation material, it's to stop the pipe from freezing and / or losing energy, since gas wont freeze in normal conditions, it means that the pipe is a water pipe of some kind.
- 115
- 1
- 5
