14
I'm looking for a device like vernier calipers (ie 0.1mm resolution or thereabouts is fine), but in more of a C-clamp configuration which allows me to measure the thickness of some object's face where there is a thicker frame, lip or ridge around the outside which makes it impossible to use verniers.
A few examples:
  • Thickness of glass plate in a framed mirror
  • Thickness of the side walls of a container with a narrowed top
  • Thickness of a lipped lid, say for a barrel
I know there must be a range of measurement devices to do these sorts of things, but my Google-fu is failing me today. Micrometers are the closest I can get, but (1) I don't need that sort of accuracy, and (2) they still don't work if the lip/frame is too thick.
What should I be looking for?
pcdev
  • 313
    Digital or dialed machinist caliper turns up some good results – Kris Feb 15 '18 at 23:26
    How about a block of plastic (of known dimension) and a regular caliper? – Hot Licks Feb 16 '18 at 02:23
  • Thanks @Kris and @Hot, great suggestions. I found it: `External dial calipers` are what I was looking for, but neck calipers definitely come close. Thanks for your input! – pcdev Feb 16 '18 at 02:49
  • I've also found `vernier caliper extension` returns lots of hits on Google images that are a good cheaper alternative to what appears to be an expensive and highly customised measuring device. – pcdev Feb 16 '18 at 02:57
    i use a channel-lock, a piece of styrofoam, and a ruler. bite the surface with the block, then measure the handle distance. then remove, and re-tighen to match the measured handle distance. then measure the gap between the jaw and styrofoam. – dandavis Feb 16 '18 at 14:31
    Measure a spacer that makes the thing bigger than the frame, then measure the combination. – Hari Feb 16 '18 at 23:11
  • I've used a lot of these answers on a similar question over at https://bicycles.stackexchange.com/questions/80769/ – Criggie Sep 13 '21 at 02:37
8 Answers8
19
There are special forms of Vernier caliper such as these known as neck calipers.
Neck Caliper Dimensions of caliper jaws
These neck calipers enable measurements in hard to reach places.
They offer you the following benefits:
  • You can measure wall thickness inside bores and recesses.
Example of measurement geometry
Obviously, the machinists calipers in A.I.Breveleri's answer will be cheaper and will probably work for a much wider range of situations.
Another type is the Curre-jaw caliper - again with a vernier scale - though both these jaw types are available on calipers with electronic digital readout
Curre-Jaw Caliper in use
There are also a very wide range of external dial calipers, as kris and pcdev identified.
External Dial Calipers External Dial Calipers with wide opening
RedGrittyBrick
  • 24,201
  • 47
  • Yes, this is definitely close to what I was hoping for! I've done a bit more research and found some caliper extensions that do a similar job, I'll post soon. – pcdev Feb 16 '18 at 02:31
    Found it! `External dial caliper` in Google returns exactly what I was looking for, but `Neck caliper` is a definite close second choice. If you add a small section on External dial calipers I'll mark your choice as the answer since you definitely got me on the right track with @Kris's comment on dial calipers - thanks for your help! – pcdev Feb 16 '18 at 02:53
  • @ocdev - Done! I'm glad you found something to suit your needs. – RedGrittyBrick Feb 16 '18 at 13:31
13
The instrument you are thinking of is the Machinist Caliper.
"spring" machinist caliper
To use it on a lipped or framed plate where you cannot remove the caliper without opening it, you must insert a plate of known thickness into the measurement.
using caliper on framed object
The caliper has no readable scale -- you use it to transfer measurements to a ruler.
A. I. Breveleri
  • 14,190
  • 44
  • Great, I can see how this would work and remember using these in shop classes at high school. I was kind of hoping that there was a combination machinist and vernier caliper, with the measurement device built in, but this certainly does the trick. I'll wait and see if anyone's got any other ideas. – pcdev Feb 15 '18 at 23:07
There are double-ended calipers which have the same gap at both ends, allowing you to measure the accessible end while set on the thing you are measuring.
Double-ended caliper
There are also calipers with a direct readout scale attached to the accessible end - in this case, using the different location from the pivot point to expand the scale for easier/more precise reading (this one being a jewelers version and optimized for small/precise measurements) - there are others with the same idea but in other sizes:
Jewellers caliper
Reproduction of Studley-chest caliper (which goes two ways, as can the double-ended one) which has the opposite scaling compared to the jeweler's caliper (less movement on the scale as the scale is closer to the pivot point than the tips of the legs are.
Micrometer would be what I can think of with a C shape, other than that, Spring joint calipers maybe?
riseagainst
  • 560
  • Yes, something like a micrometer would work, but more of a C shape than a G shape. The machinist calipers are definitely the sort of shape device I was looking for, but with measurement built in. Thanks! – pcdev Feb 15 '18 at 23:09
If you do not need it that often, then you can just use any old vernier or other measuring tool you have around. Then grab two metal objects (possibly square) that are wide enough to go past the lip on both sides. Hold them to your mirror glass or whatever you are measuring, and measure the total width.
Then, measure just the width of the two objects, and subtract.
And, of course, with a digital measuring device, measure the blocks first and zero your instrument on that.
AnoE
  • 330
  • see https://www.threadcheck.com/the-three-wire-method-of-measuring-pitch-diameter/technicalinfo/ and http://www.texas-mac.com/Measuring_Dovetail_Slot_Dimensions.html for cases where this is pretty well the only way of measuring something – Pete Kirkham Feb 16 '18 at 11:57
  • I have several different sizes of digital micrometers 1", 2" kinda of spendy but very accurate. – Ed Beal Feb 16 '18 at 13:58
    +1, with digital calipers this is especially easy as you can measure the blocks first, zero the caliper and then it shows the remaining thickness directly. – jpa Feb 16 '18 at 18:35
  • Absolutely, @jpa, thanks for pointing that out. – AnoE Feb 16 '18 at 21:43
    For high precision when machinists do this they use parallel bars which are of a constant thickness their entire length, and also used for many other things so they are readily available. – hildred Feb 17 '18 at 16:31
My question has definitely been answered (neck calipers and machinist calipers being good solutions, but external dial calipers was really what I was looking for). I thought I'd add a couple of interesting solutions I came across in my research:
My favourite was these homemade calipers found here. This is essentally exactly what I had in mind when I asked the question. A bit rustic but beautifully simple:
I also found caliper extensions which are an excellent and low cost solution to the problem:
Thanks for all the other great answers!
pcdev
  • 313
  • I wonder if 3D printing some caliper extension tips could be workable. Another excuse to buy one :)) – Criggie Sep 13 '21 at 02:31
If you're look for quick and rough, an ordinary clamp for joinery will do the trick. enter image description here Set the clamp to the thing you're measuring, put ruler against the neck to measure the distance between the base of the two arms, then remove the clamp and reset the clamp to the distance you measured, then measure the space between the two gripping pads.
curly
  • 48
  • Thanks! Yeah I was hoping for a bit more precision, down to sub-millimetre, but this is a good quick alternative that most handimen will have sitting around. – pcdev Feb 02 '23 at 22:47
I made a thickness gauge from wood and right angle braces, long bolt and one nut soldered to the underside of the upper arm. A wooden anvil is attached to the other metal right angle brace. The bottom anglebrace is fixed and the top one is hinged, so you can go around any molding that would prevent direct measurement, as a fancy tabletop. You open the upper jaw, slip it into place and close. Then adjust the bolt till both the underside touches the anvil and the bolt touches the top surface. Then lock in the bolt with two nuts. Then open the jaws, extricate the tool from the item (tabletop). Then just measure the gap.
Glorfindel
  • 1,173
    Welcome to [diy.se]! A picture of this would help to improve your answer. – Glorfindel Feb 02 '23 at 07:50
  • Thanks for your reply! Yes, a picture of this would really help, but from what I can tell it sounds very much like a homemade version of the clamp in curly's answer, albeit with one hinged jaw for quick removal? – pcdev Feb 02 '23 at 22:48
