Question pretty much says it all. I'm installing a sprinkler system in the yard, and discovered the pressure is too high (valves were leaking when on, and kick when turned on/off). I can see whichever device comes first reducing the work of the second device, but I expect it's the potential failure cases which would make it matter if one came before the other. If it matters.
Scivitri
  • 2,098
  • 25
I say BFP first.
The backflow preventer must be installed before any point in the system where the line becomes "open" to the introduction of pollutants that would make the water unsafe for drinking (fertilizers, pesticides, herbicides, animal wastes, bacteria, and other things you generally find in your topsoil). While a pressure reducer's basic operation (most are similar to a gas regulator, where a spring-driven piston controls an inlet) is generally "closed", most designs also have overpressure reliefs that vent liquid from the regulator in cases where the "downstream" pressure becomes dangerously high (freezing temperatures, or conversely overheating). This relief valve opens the regulator (and the water in it) to the introduction of pollutants, and so it must be "downstream" of the backflow preventer to safeguard the potable water supply.
Now, as SteveR said, if the pressure reducer is designed and intended to regulate the pressure to the entire water service (reducing the pressure from the mains to a safe level for home plumbing) then its design will ensure that it cannot introduce pollutants in any situation (usually it won't have an overpressure relief) and so it's safe to place in front of a sprinkler backflow preventer. However, if this is a reg for sprinkler systems (i.e. drip irrigation) then it must come after the backflow preventer for the system.
KeithS
  • 14,107
  • 73
  • Good to know about how pressure reducers work; I didn't realize they had the capability to introduce things to the water. But, as I expected, the reasons you'd want a particular order are in the odd/unusual/failure cases, not normal operations. – Scivitri Apr 03 '12 at 20:42
  • That's the case with most safety devices/features; they're there for "exceptional" cases. The ground wire in electrical wiring is never supposed to be energized, water is never supposed to flow backwards through a drain line, and kids aren't supposed to put screwdrivers in electrical sockets. However, all of these can happen (device failure, flood, kids being kids) and so ground wires, drain BFPs and tamper-resistant outlets are now mandated by code in situations where problems CAN occur (for electrical, that's pretty much anywhere; for plumbing they're mainly concerned with below-grade). – KeithS May 07 '12 at 18:35
I would think you would need the backflow valve first. I don't think it maters much for operating, but I think the water co. might want it that way.
Are you regulating the water pressure to your whole house? Or just the irrigation system? I ask because if you are doing the house, then you need to adjust the air pressure in your expansion tank on the water heater if you have one. The air pressure in the tank should equal the water pressure from the output of the water regulator.
SteveR
  • 3,869
  • This is just for the sprinkler system, there's already a separate pressure reducer for the house. Although, you raise an interesting question: this is a fairly new home (1.5 years old) and I thought those blue expansion tanks were required now. We don't have one. But we have a tankless water heater, so maybe they're only for tanked heaters? – Scivitri Apr 03 '12 at 20:45
  • @Scivitri-I believe their sole purpose is to relieve the pressure in a hot water tank, although I do not know if they are also used on tankless for some reason I may not be aware of. – SteveR Apr 03 '12 at 23:46
On service protection pressure regulator should be first if you have high pressure ie:above 100psi I've installed 10 backflows at lake level with tanks being at least 500' higher Over night during low usage pressures at BACKFLOWS increased and actually blew out the washer on the relief valve Some of the washers actually dis lodged from the Backflow and we're laying on the ground So needless to say I thought I was a champ after the installs All to get a call the next morning that all the devices I installed were in full port discharge
Jimmy ness
