I have an old house with lath and plaster walls. When I moved in a year ago I fixed dozens of cracks in the plaster with spackling, but many of them have opened back up again. What is the best way to solve this with a more permanent solution?
5Remove the plaster and install drywall. – Tester101 Apr 10 '12 at 18:29
@Tester - No plaster no problem. – Jon Raynor Apr 10 '12 at 19:23
You don't. Or, rather, it's a lot of effort for something that a lot of people consider the 'charm' or 'patina' of old plaster walls. – DA01 Apr 10 '12 at 19:45
Check for plaster repair kits in the answers. You have to do it right, then it stays repaired. – Bryce Jul 01 '14 at 19:04
Spackling's best use is to fill holes made by pictures, curtain holders, etc. To fix cracks in plaster, use Plaster of Paris or Durabond, not spackling compound.
Cracks are caused by moving or shifting, so one needs to make sure the existing plaster and corresponding substrate (in this case the lath) are solid.
A simple test is on both sides of the crack in several locations gently push the plaster. If there is movement, additional repairs may be required beyond a simple crack fix. For example, one may need to replace the lath or substrate. A simple crack may also turn into a large area where the plaster needs to be re-attached to the substrate. This is the case where the crack is hiding a larger issue of crumbling or decaying plaster and will need a larger scale fix.
I would advise doing these tests on all your cracks to determine the whether the plaster is just cracked or is suffering from bigger and more labor intensive issues.
If the plaster and substrate is solid, then to fix the crack do the following.
- Remove loose or excess plaster in crack using a utility knife
- Enlarge the crack by creating a V notch with the bottom of the V being the line of crack
- Clean or vacuum any loose debris out of the crack. Wipe any dust with a damp rag to prepare the surface for the new Plaster of Paris or Durabond.
- In your case, I would not use Plaster, but instead use Durabond. I would go for a first coat of non sandable Durabond. Plaster is hard to work with so using Durabond will be easier. The nonsandable Durabond is stronger than the sandable durabound. Follow instructions on how to mix the Durabond.
- Use a joint compound knife and work the mixture into the crack, removing any excess. Do not apply extra as it is non sandable.
- One the first coat is dry (it should also shrink a bit), switch over to the sandable Durabond. Apply 1 to 3 coats (it will shrink a little each time) and sand in between. The final coat should be very light and then sanded, primed and painted.
Plaster is hard to work work with and requires a skilled laborer to apply. So anything beyond a simple crack fix, I would go to a professional.
- 3,516
- 3
- 25
- 28
The plaster is likely cracking due to movement/shifting/settling in your house. If you want to keep the plaster, the only real solution is to correct the root problem.
Now, usually an old house would have already settled, so there might be a bigger question/problem as to why it is continuing to do so. Not to sound any alarms, but you should investigate this. Are there any new cracks in the foundation? Water in the basement? Sagging floors?
As for just fixing the problem at hand, you can either continue to patch it as it occurs, or as Tester101 said in the comments, you can replace the plaster with drywall since it is not as brittle.
- 27,594
- 9
- 53
- 88
This Old House mentioned a product called Big Wally's Plaster Magic, in an article Plaster Repair Made Easier. I've never used this product before, however, the theory of how it works is sound.
In your case (old house), the house has likely already finished settling. Settling combined with the years of service the house has provided, may have caused some of the plaster and lath to become separated. Once this occurs cracks will form, and will be nearly impossible to cover. The product mentioned in the article, actually reattaches the plaster using glue. Once that is complete, the cracks can be repaired using a layer of Spackle.
If you're feeling up to it, don't mind a huge mess, and have the money to burn. You could always rip down the plaster and lath, and replace it with drywall.
Make sure you inspect the foundation and support structure before you do anything else. In some cases cracks can be formed because of underlying structural defects/damage, so you'll want to rule that out before you try to fix the cracks.
- 131,097
- 78
- 316
- 608
1The plaster magic stuff WORKS GREAT. You can roll your own version also, but the official stuff is nice. – Bryce Jul 01 '14 at 19:03
Here is a great trick to fix loose plaster in a lath and plaster ceiling without tearing out the loose plaster. This short cut only works if the plaster itself is in good shape but just separated from the lath:
Brace the loose area of the ceiling with a piece of plywood covered with plastic wrap so the glue to be applied later will not cause the plywood to stick to the ceiling.
Use an old hinge to attach the plywood to a stick around 5 feet in length.
- Attach a second stick about 6 feet in length to the first stick using 2 clamps where the sticks overlap. The sticks now joined together go from the floor to the ceiling with sufficient pressure applied to the plywood that the sticks bow slightly.
- You may want to put something down on the floor so the stick doesn't mark the floor.
- If you have attic access to the ceiling the job is easy: simply pour white wood glue from above over the affected area.
- If you don't have attic access (probably because there's another floor above) then use a large syringe with a 6" length of tubing pushed onto to the end of the nozzle. Use electrical tape so the tubing stays attached to the syringe.
- Now drill a series of small holes 1 or 2 inches outside the edge of the plywood, the holes being just large enough for the tubing. 8 Fill the syringe with white wood glue and insert the tubing into the first hole. Use your judgment as to how much glue to inject into each hole.
- Place a piece of masking tape over the hole immediately upon pulling the tubing out.
- Repeat steps 8 and 9 until all holes are done.
- Wait 2 or 3 days. Be patient. If you take the brace down before the glue dries your ceiling very well can come down and you'll have a huge mess. When the glue dries your ceiling will be very solid. 11: Final step is to plaster over the drilled holes if you had to go that route. Job done!
- 1
I have a 100 year old house and the front hall had many diagonal cracks.
- I opened up the cracks slightly
- About an inch from the crack I would drill a hole about every 8 inches on each side of the crack. If I hit the lathe I would stop and if I didn't I would put an X on that hole and drill another. Then I took a countersink bit and widening the top of the holes (be careful because you don't want to crumble the plaster) Next I used drywall screws and CAREFULLY screwed the plaster back on to the lathe. I would use a drill but would always do the last turns by hand so I wouldn't over do it.
Note: of course the counter sinking is to make room for the drywall heads however if you are to aggressive with the counter sinking you will weaken the plaster and if you are too shallow the heads will not sit flush or you risk cracking the plaster if you force the heads in.
- last I filled the crack in with drywall mud and using paper tape finished off like I would any drywall joint.
I live in Minneapolis and it has been 4 years with no recracking.
