24
My breaker box is very poorly labeled and I want to figure out which circuits may have overloaded (or close to it) and which could reasonably handle a little more.
In the past I have just tried flipping one of the breakers and then running around the house flipping switches and trying receptacles. Surely there is a better way?
If there is a reasonably priced tool that would make this a lot easier I would consider it.
auujay
  • 5,235
  • 40
  • 55
    **NOTE:** If you plan to actually open up one of your electrical boxes with one of these strategies, always double check that the box you're opening has no power anywhere in it with a non-contact voltage tester. **Boxes can contain more than one circuit.** – Zach Mierzejewski Jun 19 '15 at 22:18
  • In ADDITION to the non-contact voltage tester, but a PLUG-IN tester also. There is a reason that some call non-contact testers "suicide sticks". For outlets, the plug-in tester is more accurate and they also check for reversed hot-neutral. Also if the wiring looks sketchy, call a pro, but if not one thing to watch out for is joined neutrals across circuits: you could believe your circuit is off, but someone uses another circuit sending power down into the one you are working on. Happens. – Scott Prive Jan 17 '19 at 00:01
  • And while you are at it, it pays to figure out the ordering of the outlets. Or at least get a good idea, and write it all down. Later you can use this info to "map out" the circuits according to your floor plan. – Scott Prive Jan 17 '19 at 00:02
13 Answers13
13
I tried one of the breaker finders, but it was worse than useless. So my solution was simple. I took a piece of paper and drew maps of every room in the house. On the map I located every outlet, light switch, etc. Then I turned off each breaker one at a time, and tested every outlet in a room, every switch. It helps to have a few items to plug into different outlets so you can test more than one outlet at a time.
For some boxes, you must be careful, as you may have two circuits going into the box in some cases. And some outlets may even be split in two, or some outlets are set up as switched outlets. Identify all of these things, taking careful notes on the map.
This all took little time, and perhaps even less time than it would have taken with a breaker finder. In the end, I have those maps, so whenever anything needs doing, I pull out the map and shut down the correct breaker easily before I do any work. Even so, I STILL check the box to test if the lines into it are dead. You can never be too careful with electricity.
    This is my motivation. I was planing on doing exactly what you describe but I am not looking forward to it. I don't relish the idea of running up and down 3-4 flights of stairs to flipping breakers and check outlets. But thanks for sharing your experience with this tool. – auujay Apr 16 '12 at 23:18
    You still do less running around than you need to do with the electronic finder, IF it works! Send someone down to the box. Tell them to shut off breaker number 1. Find and label all outlets and switches that are now shut off. This will be quick enough. Now, yell down and have them turn breaker 1 back on, then turn off breaker 2. Repeat until done... If you don't want to yell, a pair of cell phones will do wonders. It really will go quickly enough. –  Apr 16 '12 at 23:32
  • @auujay The tool suggested is the circuit breaker tester, designed to find the breaker. woodchips is correct. You know were the breakers are but you are trying to find what the breakers feed. Use a light, radio or whatever. You can use multiple lights but you cannot run multiple testers. – lqlarry Apr 17 '12 at 03:52
    I used an outlet tester on our home that we had just bought when I was making the wiring map. It has a bunch of LEDs that signal whether an outlet is properly wired. It told me if there is no power, or if an outlet had a bad ground, or if the hot and cold wires were switched, etc. So at the same time as I was looking for breakers, I was also verifying that the house wiring had been done properly. –  Apr 17 '12 at 10:20
    With 2 people, this job is much more than twice as fast. With 1 person, this job is impossible. – ssaltman Nov 22 '15 at 16:18
  • The problem for me is how to document the findings. I've got rooms where there are three different circuits. I've also found weird common ground things like a 3 way-switch with 2-wire romex between the switches and the neutral from the light wired to another circuit. That information doesn't really fit on a little sticker. – JimmyJames Nov 23 '16 at 17:08
  • there's a better way: 1: turn a device in every room / outlet on, 2: switch off all the breakers 3: turn them back on one by one (in this way you have to run througout the house only 'one' per circuit) and is easly identifiable: it's easierr to see a lit light in a dark house than a dark one in a lit house – DDS Feb 10 '18 at 13:22
They make Circuit Breaker Tracers for this purpose
Tracer
(source: homedepot.com)
You plug in one end to the circuit you want to trace, then use the probe to identify which breaker in your panel the tracer is connected to. These devices differ from a telco tracer tool in that they work on live elctrical circuits.
This particular model is about $45USD at the time of writing.
Glorfindel
  • 1,173
Steven
  • 27,594
  • 53
  • 88
  • Except when the breaker is on, the signal goes to all the circuits making the circuit tracer hopelessly useless. – wallyk Jun 19 '15 at 19:25
    Tracers work. You're using it wrong! Turn the pen device so the flat side with the arrow and light are on the left. Perpendicular to the panel is what you want. Mine is the one shown and works flawlessly. –  Sep 13 '16 at 15:54
  • link is broken. – Walrus the Cat Dec 24 '18 at 22:55
  • Maybe use a circuit breaker finder, in reverse? [This](https://www.amazon.com/Klein-Tools-80016-Circuit-Accessories/dp/B08VWCSG7G) one comes with an adapter, alligator clips on one end and a female outlet on the other (you could easily make your own): clip alligator clips to hot on breaker and neutral, then use the finder to go around to each outlet?? – Michael Guy Nov 08 '23 at 21:03
For one person, a loud portable radio (preferably one old enough that it turns on when power is restored, but a modern one that does not is usable, since the primary method of use is to plug it in, turn it up, and listen for when it shuts off as you turn off breakers. Saves on the running up and down part, a bit, at least for outlets.
For more than one person, lamps, lights, outlet testers and some communication make the process pretty fast.
    I suppose if you could tell well enough, you could plug in multiple radios with different stations/CD's playing.... turn on one breaker at a time, listen long enough to identify the band and shut off and do the next one? – onaclov2000 Apr 03 '16 at 17:02
I have a better solution if your by yourself than running around or running extension cords. Although it may not be feasible for everyone, I had used my security camera that’s powered by batteries so I was able to move it around the house and would turn the lights on in a particular room along with lamps and other devices plugged into the outlets. Then watching the camera on my phone, I’d flip through the breakers to find out which ones correlated with that particular room and jot it down. Another solution, if no camera is available, if you have a iPad there is an app that can be downloaded to be able to use your iPad as a security camera/baby monitor and view it through your phone. Although these options may not be the most “ideal” it has saved me a ton of time vs going up and down several flights of stairs to just check to see if it was the correct breaker I needed.
Ash
  • 71
Buy cheap night lights in bulk (less than $2 each), plug one into each outlet & turn them on, then all you have to do is turn off one circuit breaker at a time and walk around the house writing down what lights are off for that corresponding circuit breaker.
Dollartree.com & Opentip.com sell large quantities from $1.10 to $2 each.
Dave
  • 61
Night lights is a great idea. I find strings of cheap christmas lights useful, in different colors even. I can stretch them to where I can see them with less running around than if I had to go all the way to each receptacle or room. For exterior receptacles I route them in front of a window so I can see from inside. Funny, I usually turn everything off, then flip circuits on one at a time (instead of other way around)... am I missing something?
Sammity
  • 61
    That way the house loses power to everything, and for a longer time, rather than an average of only half of things for a shorter time each. – mgkrebbs Feb 26 '17 at 21:39
Call a friend and have them come help you. Tell them to bring a cell phone.
They will go from room to room and floor to floor with you on the phone, as you switch off each breaker one by one. When the power goes off in the room they are in, mark on your electrical panel which breaker/fuse you pushed and confirm what room your friend is in. No matter the size of your house, it is way easier and faster than buying a circuit finder. All it will cost you is maybe a beer.
casey
  • 59
I suggest running a long extension cord (if you have one) plugged into the outlet and run it to the breaker box. Then you can have a radio, lamp, Christmas lights or whatever tickles your fancy right next to you as you flick breakers off and on. I did this and dropped an extension cord through my laundry chute to my basement and eliminated the need to yell at my children. I also found I trusted the answer I got a lot more... :-)
Clarence
As Steven says, what you need is a circuit breaker finder. In addition to the components he shows in that picture, there is also an adapter kit available that will allow you to plug the tone generator into a light socket, or even clip onto bare wires (that should ONLY be done on a dead circuit, but it can be invaluable for finding out what a switch controls).
In addition to finding out which breaker controls a particular plug or light fixture, the probe of the breaker will also be able to detect the tone in other plugs and switches on the same circuit. So, you can plug into one outlet, identify the breaker, then take the probe around to other switches and outlets in the same area to determine which others are on that same circuit. Coupled with a simple floor plan diagram of the house, you can map out what circuits control which fixtures with a number or color-code system, then code or number the breakers to match and put the map on the inside of the panel cover.
KeithS
  • 14,107
  • 73
    Remember when checking switched lights with a tone generator, to turn the switch on (it's not as useful if the circuit is open). – Tester101 Apr 17 '12 at 12:17
Try Using A radio, Plug it in, Turn it on, and set the volume to full. Then go to your circuit breakers and start switching them on and off until you hear the radio turn off.
  • Hello, and welcome to Home Improvement. Thanks for the answer; keep 'em coming. And, you should probably [take our tour](//diy.stackexchange.com/tour) so you'll know how best to contribute here. – Daniel Griscom Feb 22 '20 at 13:00
if you have a cordless phone for your landline: connect the base to the outlet you want to test, take the handset with you, then flip a breaker and wait 10 seconds, when the cordless say 'No power to the base' bingo! you found the breaker to which your phone is connected, then bring the base to another outlet and test again.
for faster response: push the 'call' button, as soon as the base goes dark, the 'connection' will drop (even if the base isn't connected to an actual landline : thr only 'feature' you need is 'powered vs unpowered base')
DDS
  • 2,377
I have one thought on this very interesting conversation which I didn’t see. For example, you might have a living room lamp outlet that is also attached to a on/off switch. If, as you know, that switch is in the opened or off position, the outlet plug will be off. Also, for wall plug outlets, test all the plug outlets. In my bedroom I have one 2 plug wall outlet. The top was connected to one circuit breaker and the 2nd one to a different circuit breaker. This was shocking for me to find out. Further I think that the night light suggestion was excellent.
JACK
  • 78,739
  • 72
  • 188
-1
If you just need to find which breaker a single outlet is attached to you can short the hot and common wires together. It'll trip the breaker in the box. That's what breakers are for. I know there will be some people fuss but I've been doing this for years and I know many other electricians that do the same thing.
Eric
  • It would be much better to simulate a 'ground fail': use a 6 W resistor and connect it to 'live' and 'ground' of a new male, then plug it. It will drain a little current (50mA) but enough to make your differential to trip. It's much safer than a live/neutral bridge. It obviously works only if you have a differential breakers. – DDS Feb 10 '18 at 13:20
