I am trying to install vinyl plank flooring in my basement and the cleanout is right in the middle of the floor unfortunately. Am I able to cover it and/or is there a good way to handle putting the flooring down around or over the cleanout?
Image:
thanks in advance!
Eric Anderson
  • 123
  • Hello, and welcome to Stack Exchange. How far above the level of the floor does the plug extend? Any chance you can get it flush or below? – Daniel Griscom Apr 01 '18 at 17:56
  • It'd about a quarter inch above the floor. I would love to get it level and cover it but I don't know if that is OK. I also don't know what the pipe I used for. – jacksonecac Apr 01 '18 at 18:03
    You (and whomever resides there after you) may need access to that in the future, unless it's confirmed out of service. I would start thinking of ways to hide it with furniture. – Jimmy Fix-it Apr 01 '18 at 18:19
I would fit your flooring neatly around the clean-out rim, and then screw down a stainless steel cover plate that laps onto the flooring. You can run the screw right into the cleanout plug.
The clean-out is presumably for your main sewer line, which probably runs under the floor and out to the street or septic system. If you ever have a backup you'll kick yourself if you had covered it up.
