I need to do some work off-grid, and I only have a 1000W generator to drive my power tools, which easily draws twice that (and probably more when starting up) when cutting steel.
Instead of getting a new Honda generator that's powerful enough (minimum 1500$ for 2kW where I live) I was thinking of getting some kind of device that would even out the power draw. The tools usually only draw high currents for half a minute, tops, which would mean a energy usage of about 30s*100A=3000As=0.9Ah, each time. Typically, I would just have less than ten of those peaks, meaning I would require something that could deliver peaks of 100+A (1200VA) and be charged for about 10Ah. It needs to provide 220V AC, not DC.
I was browsing around for "super capacitor" and such, but I only found electronics bits. Then I remembered that a UPS serves a similar purpose, but they don't seem to be able to provide the short bursts of current I require (without costing many thousands of dollars).
I also thought about getting a cheap inverter hooked up to a spare 150Ah battery, but "cheap" and 2000W doesn't seem to appear in the same listings ;-) Found some generic cheap Chinese ones, but the reviews all claimed it would only really supply 500 Watts, so I guess there's a reason they're cheap ...
So do people have a tip on how I can achieve not killing my generator without it costing an arm and a leg?
oligofren
  • 307
    AC electricity does not work that way, there's no way to put a battery or ultracap on AC. The best way to store power for tools is **air**. – Harper - Reinstate Monica Apr 17 '18 at 07:08
  • Yes, there is. A UPS does just that. It has an internal battery and inverter, directly connected to mains, giving backup power in case if short outages of a few minutes. I am just wondering about a cheap option for DIY. It's basically AC/DC/AC – oligofren Apr 17 '18 at 07:41
  • My current take is getting the generator to charge a battery through a battery charger. The battery is then connected to an inverter. – oligofren Apr 17 '18 at 07:44
    You're overthinking this. just get a bigger generator, and sell the old one. Whatever you do is going to cost similar (or more) and mean you have to carry around a large battery bank as well as a generator. – Digital Lightcraft Apr 17 '18 at 09:29
  • I have an extra 150Ah battery bank and a powerful 80A charger at the site due to having a solar powered cabin. That's already 900$ just sitting there, so might as well make use of it. But yeah, if I just had the generator I'd agree with you that this is unnecessarily complicating things :-) It's just a shame to fork out 1200$ (assuming 300$ for the 20 year old existing), if I can get the same result for 120$. I just ordered a cheap 1kW inverter that does 2kVA peaks, so I'll post back the results (whatever they might be). – oligofren Apr 17 '18 at 09:42
    I would be interested to know the outcome, as the last inverter I used would trip out VERY easily on any sort of start-up spike. For example I tried to use my 500w to power a single 240v studio photography flash and despite the flash being rated at just 100w, it tripped immediately. – Digital Lightcraft Apr 17 '18 at 09:53
  • Wow, that's alarming ... Thanks for the heads up. I'll keep you posted. – oligofren Apr 17 '18 at 09:56
    no, a UPS doesn't do that *at the cost ranges you're talking about*. You would need an *online* UPS (the most expensive kind) sized for motor start (again expensive). Cheap power tools do nothing to ease their locked-rotor draw because that would make them cost more, and it's unnecessary with unlimited utility power. "Cheap" is really what this is all about, isn't it? You seem underprepared for the financial commitment of succeeding off-grid, and my recommendation is a lot more research about off-power-grid living, which the Internet is flush with. – Harper - Reinstate Monica Apr 17 '18 at 16:02
  • @Harper: I don't intend to live off-grid. It's just a cabin where I need to do some repairs this Summer. The last time a grinder was started at the site was 20 years ago when the cabin was built, so that's why I try to avoid a huge investment for a tiny two day project. – oligofren Apr 17 '18 at 19:03
    @oligofren oh! Well that makes more sense! Sorry for being grumpy. Yes, needing to use an AC power tool in a remote location ***once*** is a most frustrating situation, and there is no cheap way to do it. GM's first hybrid vehicle, the 2004 Silverado truck, included a 120/240V inverter that was precisely for that problem. Unfortunately they bought back almost all of them, so they could EOL support. Even more unfortunately, no other hybrid maker has picked up on that idea. – Harper - Reinstate Monica Apr 17 '18 at 19:14
Buy a (petrol-fired) air compressor and pneumatic tools, or go for a bigger generator. (Good) Inverter can cost nearly as much as a generator, also remember that an inverter rated for 2kW has a substained rate of about half. I found on Amazon this 3kW inexpensive inverter, check if it may be good for you. Anyway, with an inverter it's important that the battery can provide all the instantaneous power needed, and also that the wires are thick enough: 3000W@12V -> 250A it needs really big wires (60mm^2). Also remember that motors may require a start-up current that can be more than 7 times the 'rated'.
DDS
  • 2,377
  • An air compressor is as expensive as a big generator and still requires a power supply of several kilowatts. Are there affordable options that can fill a pressurized container that will be able to drive a pneumatic grinder? – oligofren Apr 17 '18 at 10:06
  • 7 times! Wow. Not aware of that. – oligofren Apr 17 '18 at 10:07
    You can find a petrol-fired air compressor like this: https://www.agrieuro.com/motocompressore-scoppio-airmec-mini-08260-260-ltmin-loncin-118cc-benzina-p-9392.html?LGWCODE=9392;102443;6125&gclid=EAIaIQobChMI6_zxybXB2gIVUJkbCh1P9ADREAQYAyABEgLO2fD_BwE, so you'll avoid all the hassles of electricity (and you won't need high surge er for electric motors). And use the gen you already own for light duty appliances. – DDS Apr 17 '18 at 13:30
  • 7 times if the appliance doesn't have a soft-start or a power inverter, if the appliances have them startup current became lower. Also remember that a regular (70Ah) car battery can store only 840 Wh of power, that is about 10 minutes of work with 3kW draw. And to recharge will take about 10 hours – DDS Apr 17 '18 at 13:34
  • @DDS soft starts and power inverters are features found on rather high-end tools, that is not the economic stratum we are operating on in this question. – Harper - Reinstate Monica Apr 17 '18 at 16:23
AC power cannot be stored because AC is dynamically changing (to be more precise, alternating). It requires very expensive hardware to arbitrage it for other types of energy which are storeable, and in the sizes you need, the cost of that hardware is well beyond the scope you established in your question. That leaves:
  • Hand tools. Exercise your arms.
  • Smaller tools. A Dremel may be going too far, but plainly it won't trip your generator! If you're using a 9" grinder (1800W), use a 5" grinder (210-360W).
  • Battery powered tools. This is the direct way to do the energy storage you want. You may even find you can get chargers that will charge direct off your solar without need for gen at all. In your question you claimed a rather light duty cycle, and that should be well within the range of battery tools. (If that was falsely stated, GIGO.)
  • Air, as DDS discusses at length. Gas powered air compressor + air tools. Energy storage is done with an air tank, and those are way cheaper than batteries with no energy conversion required.
Michael Karas
  • 64,093
  • 63
  • 142
