My house was built on a slab in1964 and has a walk out basement. There is a floor drain in my basement, along with a toilet & utility sink. Water from the main floor fixtures is backing up through the basement floor drain. I am unable to find a cleanout inside or outside. However, there is a large stack with a plug about 3' from the floor in the basement. Is this the main line cleanout? Thanks for any assistance! (https://i.stack.imgur.com/VTC1N.jpg)
Asked
Active
Viewed 189 times
1A photo of the stack would be helpful is this stack a pipe possibly a back flow preventer. – Ed Beal Jun 12 '18 at 19:09
I've added a photo. – PeoriaRose Jun 13 '18 at 03:07
I would think that could be a clean out. I have not seen copper used with cast but a snake would be easy to run down the access. – Ed Beal Jun 13 '18 at 14:49
Yes, it’s probably a “wall cleanout”. We like them installed on a wall above (at a higher elevation) than a tub drain, or toilet, etc. so that the cap can be removed and the drain cleaned out (snake extended down the drain) without sewage gushing out the cleanout.
Lee Sam
- 23,095
- 3
- 19
- 44
I agree but be cautious if the plug is bad you may have several feet of pipe full of waste water when you open it. – Ed Beal Jun 13 '18 at 14:51
@EdBeal Hmmm...Copper to cast iron...very strange...I don’t understand that. – Lee Sam Jun 13 '18 at 14:56
That's why I mentioned it also a brass plug those are very expensive items shown in the photo but I have only seen cast used in waste lines for residential. – Ed Beal Jun 13 '18 at 15:11
Thanks for all the input! I'll let you know what happens if I can get the plug out. – PeoriaRose Jun 13 '18 at 17:54
