I purchased a pressure machine of KARCHER for car wash purpose from Saudi Arabia. In the catalogue it is written 1~60Hz whilst in Pakistan 50Hz cycle is used. The question is if the 1~60Hz unit can can be used as 50~60Hz?
If I talk about the machine there is a sticker upon which is written "60Hz". So I am puzzled now if it would be a loss if I take it to Pakistan. It is still new and has not been used.
Michael Karas
  • 64,093
  • 63
  • 142
omer ahmed
1~60Hz means 1 (single) phase, 60Hz frequency. Unfortunately, it does not mean 1 to 60 Hz.
Varying frequency is usually written as 50/60Hz, and is less common for electric motors.
It's possible it will work, but it will likely run at a slower rate and may fail early.
  • And is more likely to overheat, since more current may flow... *unless* it's a universal motor. If it has brushes and a commutator, it *might* work. – DrMoishe Pippik Aug 05 '18 at 04:27
