I have a older pressure washer that I was getting ready to put into use. Its primary use right now will be cleaning gable siding on a brick house. I've done some reading and I am sort of confused. The general recommendation is to use soft washing via the pressure washer on the siding. One of the benefits they mention is ability to clean siding from ground. However, when I read about pressure washing it says not to spray upwards because water can get trapped back behind siding. This seems to contradict each other. Can someone clarify this? Also, what is needed to soft wash besides the appropriate nozzles?
I like soft washing because: 1) Control, 2) Will not destroy caulking/sealant, 3) Will not deform face of siding/brick,
1) Controlling the direction of the nozzle is important so the spray does not go where it can leak into the house. Often high pressure sprays will “push” a water stream in cracks, around trim, etc. causing leaks inside the house.
2) A high pressure spray can “blow out” the caulking and sealant around windows and doors.
3) A high pressure spray can easily deform (gouge) the surface of the siding or brick. When we clean historic structures, it is especially important not to “over clean” the surface because it can get damaged easily.
I use a siding cleaner. First, I pre-soak the siding and the spray the cleaner on the surface of the siding/brick. The instructions on the cleaner will tell you how long to let it sit before you clean it off by spraying it.
The comment regarding not aiming the spray upwards is referring to the possibility of pushing water up under building paper and moisture barriers. This is especially important at corners, joints in siding or trim, where the building paper may not be lapped properly.
Remember, brick needs a clear sealant installed over it just like siding needs to be painted. The sun and rain will wear the protective coating off over time, so it needs to be reapplied every 3-5 years.
- 23,095
- 3
- 19
- 44
1Thanks for your detailed answer. As far as cleaning the siding on the gable, is it best to use some sort of scaffolding or is cleaning from ground an option? I wasn't quite clear on that by your answer. – georgia-guy Nov 06 '18 at 07:21
1@georgia-guy I like to be where I can control the spray the best. That means being on a ladder, scaffolding, etc. if necessary. (I suppose it matters how far away it is...) You’ll also be able to use the ladder, etc. for re-painting too. – Lee Sam Nov 06 '18 at 15:53
1What else is needed for soft washing other than the right nozzles? I have a residential gas pressure washer. – georgia-guy Nov 06 '18 at 19:28
1@georgia-guy Is definitely used a cleaner for a pre-wash. I use the kind that hooks to a garden hose and sprays on. I let it sit for about 20 minutes then I rinse. It loosens dirt, algae, etc. and CLEANS everything. Then, the pressure washer is more like a really good rinse instead of a cleaning tool. – Lee Sam Nov 06 '18 at 22:10
The answer nailed it Sister power washed house .Took off chips of brick,,And instead of letting water run down ,worked its way under flashing . Made a mess.Way to much pressure used. – Jun 01 '19 at 03:33
