32
I've been given the Christmas task of setting up an HO model train and rails around a child's room, so I researched a bit and found a shelf train would be the thing. So I go to measure the room in order to figure out how much wood I have to buy to make the the shelves (already thinking about how I'm going to make the round cuts for the inner edges with a simple hand saw...) when my measurements turn out to be: 314.5cm x 335.5cm x 339cm x 304cm... Yes, someone has been able to pull off this masterpiece of a room:
The Most Skewed Room in The World
(Now, I'm not sure a bout the actual shape of the room, because as you can see, they had the delicacy of rounding the corners—to soften the magical skew effect, I guess—so it's impossible to measure angles. What I did was create lines in Photoshop with the lengths I took and simply found a way to connect them so it feels right with what I'm actually seeing in the room.) I guess my predicament is by now obvious: how on earth am I going to correctly measure and cut this shelf?!:
Skewed Shelves
The mere thought of trying to find the correct angle for the corners and the correct radius is daunting! Not to mention the seeming impossibility of how to solve for the 2 corners where the angle will be obtuse and there'll be gaps between one side of the shelf and the wall!
Is this an impossible DIY project? What do you guys think? Am I perhaps going at it wrong and there might be a better, easier, (saner), way of going about it? Thanks in advance for your help!
P.S. The wood I'm looking to buy is particle board (the stuff that's used for melamine boards). I'm focusing on it more for its price, as it's much cheaper than pine or plywood (even MDF) where I live. But I'm not sure if it'll be the easiest to work with at the cutting stage.
UPDATE No 1
Wow! Thanks a lot for all your responses! There's a lot of very good info here that will help me approach this issue and perhaps will help others in the future!
One poster had a similar idea to a second, less elegant, but much more practical shelf layout I had also thought of:
Final shelf layout
I avoid the curved corner details and having to deal with them and, at the same time, make it more practical to fit together the whole setup without that much of a hassle due to the wonky, skewed construction of the room.
Don't pay attention to that red block floating around the top, it's just a leftover piece of shelving panel . I virtually "cut" a large panel of 244x120 into 4 244x20 shelves and a larger 244x40 shelf that goes on top of the closet that's to one side of the room—yes, on the original design uploaded I didn't have the closet drawn in... that's another obstacle I've had to jump over... quite literally (more on that after). And I'm happy to see that I can get all the material I need from only one panel, which will save me some money.
Now, talking of the panel, why have I chosen particleboard and not plywood as a couple of you mentioned? Well, it's much more economic. I live in Spain and I know in other places plywood is dirt cheap but here it's 3 times more expensive than particleboard! I was surprised to find out—I'm not originally from here, so I too went straight for plywood as my first choice, only to find out that the "benchwork" would cost me much more than the actual train set and misc. models! In the end, I've decided to get a white melamine panel, the kind one uses to make normal shelves and/or a desk. It's still particleboard but has that melamine covering which gives it (a) a nicer finish that'll save me some work and (b) gives the particleboard a bit more resistance and makes it less prone to fall apart, I find. It only costs a couple Euro per sq. meter over the regular particleboard, so it's still way cheaper than the plywood.
To answer another particular a couple of you mentioned: I'm clearing all doors (there's 2—no windows) by placing the shelving flush agains the top of the doors' lintels and then going around the room at that height. It's not a small child's room, so the height isn't really forbidding; plus, she's tall, so she can manage. She really likes HO trans, and will be getting up close to her set when she wants to work on the model but, otherwise, it's more of a relaxing scene for her to see as she lies in bed, especially at night, and falls asleep with the sound of the train rolling by. Now, as I mentioned, the closet is another big obstacle, as it stands 9cm taller than the lintels, so I can either raise the entire shelving a further 9cm (which I'd rather not, as it does start to become more of a ceiling train) or I can have inclines going up to and down from the shelf on top of the closet. I'm thinking of putting 50mm pink foam on top of all the shelves except the one on the closet; which would help me make it so that the incline that has to go up and down from the lower shelves to the top of the closet would only have to reach up 4cm, which would mean I can get a good 1 in 30 incline starting at 120cm from the closet (perhaps a little diagram will help better show what I'm talking about exactly):
1 in 30 incline diagram
I understand a 1 in 30 incline is about the bottom margin recommended for an HO gauge train set, as it's already a 3.33% incline, which is way more than any prototype rail actually has. Because we're talking about a passenger train, with a rather strong British Gresley A1 locomotive and 3-4 pullman cars, I think there'll be no problem getting up and down this slope. Now, I've read somewhere that a 1 in 30 incline is really not ideal (aesthetically speaking) for a model main line. I personally don't see that but perhaps do understand there might be a lack of realism. All-in-all, if you can't get up to 1 in 60, which seems to be the best ratio, 1 in 50 is a preferred incline for serious modellers and, indeed, I could even get it up to that:
1 in 50 incline
I don't mind it visually. It may even be interesting to create some sort of mountain side view for the inclines. What do you guys think? I guess I'll know for sure once I get the tracks in place and do a test run with the loco.
As I said before, I could just raise the entire shelving and have it flush with that on top of the closet. If I connect all the shelving (including the one on top of the closet) then I'd be raising the entire set 9cm and I could also put some foam on top of the shelf on the closet. If, however, I just raise the outer shelves enough to get the foam flush with the shelf on the closet (and don't put foam on that) I only have to raise the thing up 4cm. Now, 4cm higher or lower doesn't seem like much and perhaps is not worth the hassle of having to make inclines... I don't know. 9cm already seems like something considerable, but perhaps in the end, visually, it's all the same... What would you guys do?
Another thing I'm planning on doing is running the rails rather close to the edge, because it'd be a shame to push them back and have the train be half-hidden all the time. So I'm going to pop in some wooden posts at intervals on the very edge and string them through with some sort of thin wire or string to make a barrier in case of derailments that will look like some rural fencing. Any ideas how high I should make them to insure nothing rolls off the edge, especially the loco? I'm thinking that some 3-5cm should do the trick...
Finally, the last obstacle I'll face is the wiring. The rails are easy enough to wire but we're also thinking of modelling a little town on the closet, and a little village on one of the corners, perhaps a farm or something like that on the other, so we're also going to need to wire some lights, at the very least—perhaps even some other mechanical stuff. I'm guessing what I'll have to do is cut surface strips on the actual foam and have the wiring go under there. In the case of the closet top, which most likely will have no foam, I'm probably have wires run across the surface and then I'll hide them putting some scenery on top. Any other ideas?
This all is perhaps not the best solution, but I think it's what I'll end up going with. Still, as I work my way into the project I'll know for sure. Which is why I'm not marking any answers or posting these "final" plans as an answer, because I may very well change them upon finding a better solution, or someone else might give me another recommendation here, and then my plans and final result will change.
UPDATE No 2
I realised quite a lot of you are worrying I may be in for a couple of bad surprises.
The first, and perhaps more worrisome: that once I work all of this out I'll realise the HO train set's rails just don't fit what I've made!
Well, don't worry about that. I have taken this into account, which is why I need those rounded or diagonal corners. The first thing I did was use AnyRail to build up the basic track layout with the parts I'm getting in the set I bought, to see what other pieces of track I need to buy and, of course, to see if the room could hold a nice and viable shape. This is my current track laid over the room and shelving diagram:
Track over diagram
In the diagram it fits almost exactly in some parts, which gives me some confidence, as that means I'll be able to make it fit even better by working a little with the track.
The set comes with a basic Hornby oval plus a basic extension pack:
  • 8x R607 Curve radius 43.8cm, 45º
  • 1x R612 Left turnout 16.8cm
  • 1x R604 Curve radius 37.1cm, 22.5º
  • 3x R600 Straight 16.8cm
  • 2x R601 Straight 33.5cm
and I decided what would be more practical and economical would be to add
  • 7x R621 Flex track 97cm
to complete the layout I show. First, because the flex track will allow me to make a skewed quadrangular track that follows in the Tim Burton-y spirit of the room's architect (+1 for the person who said I should find the guy and shake him into his senses). Then, it's also cheaper than buying straights, and as I would have to at least buy 1 piece of flex track in order to fill in gaps that'll surely come up, I might as well just buy them all flex and enjoy the extra latitude they offer.
About the second worry: realising too late that the "straight" walls aren't really straight... well, I thought of that too! Because no home improvement work in this house has been made at all easy by the marvellous architects who dreamed it up! However, I can happily say that whoever built the room wasn't that out of their minds! Of course, they aren't the straighest walls in the world, but they're straight enough. What worries me more is that the floor and ceiling aren't perfectly balanced either... What can I say: Europe's building codes are different... and old buildings with wonky architecture are fine (I once stayed at an AirBnb apartment building in France that was entirely off kilter by several degrees! So much so that when you walked in the apartment you had to hold on to the walls as you felt you were going to fall over. And objects left on one corner of the room would slide down slope to the other!). Anyway, so if you measure from the floor up or the ceiling down in any two points and set your horizontal shelves according to those measurements you'll find that they're very obviously tilted to one or the other side! So I'm looking forward to that part of the adventure! (Luckily, my iPhone has a rather accurate level I can use to get me out of that mess.)
Anyway, again, thanks a million for all your input!
QuestionerNo27
  • 459
    You're going to want to buy a coping saw to cope the rounded corners. Remember, every project is an opportunity to buy new tools! – Eric Lippert Dec 05 '18 at 21:32
    To get the angles right you need one more measurement--go corner to corner across the room. To be safe I would do it both ways and make sure you get the same resulting shape with each measurement. – Loren Pechtel Dec 05 '18 at 21:38
    You may want to make sure that you can get tracks that actually fit your layout before starting to cut the wood. Track radius for corners may leave you with quite wide corners. And the straights have to fit the length of the straight track elements you can get. If your trains can run on flexible tracks that will give you some leeway, but you still can't go below the minimum turn radius that your trainset can safely run on. – Bent Dec 05 '18 at 21:38
    Do not forget that *train corners cannot be square!!* – Fattie Dec 06 '18 at 03:29
  • If you can figure out the approximate radius of the corners, measure your diagonals and plug that info into your diagram – Hot Licks Dec 06 '18 at 03:32
    I'd like to stress that trains, even model trains, need a minimum radius of curvature of the tracks — a possible reference that I have found is https://www.thesprucecrafts.com/minimum-curve-radius-model-trains-2382285 — for HO scale they suggest about 40 to 50 cm minimum radius, hence your straight boards should stop well in advance of the opposite walls, e.g., the 304 cm wall will be fitted with a 204÷224 cm board so that you can put in place the quasi-quarter circle shaped connections. – gboffi Dec 06 '18 at 15:21
    In case you've never done this kind of stuff before: With a room that wonky, it's likely the walls are not very straight either. There will likely be gaps between the straight(ish) boards and the likely-even-less-straight walls. Just something to keep in mind going in rather than discovering later. – JS. Dec 06 '18 at 21:49
  • Don't forget the doorway gap! – Criggie Dec 07 '18 at 10:22
  • If you have further questions, please ask a new question instead of editing it in here. Now we can't differentiate between answers to your first questions and answers to your second question. – JAD Dec 07 '18 at 14:58
  • @JAD Sorry! My edits actually focus on adding more information but I just thought I might include further questions... As some answers and comments focus more on the model train set side of things (rails and gauges and etc.) I got a bit carried away from the specific question in the title and went more into overall recommendations for the entire setup. – QuestionerNo27 Dec 07 '18 at 15:45
  • Be aware that kids (perhaps unexpected ones) will eventually make their way up to the tracks to play with the trains. Consider lowering the system and making a bridge across the door to reduce eventual injuries and allow them better access (don't block the door, but it almost-certainly opens outwards from the room or should). – ti7 Dec 07 '18 at 19:43
  • The tracks look pretty close to the edge in a few places. Generally the distance between the track & the board edge should be >= the height of the train, otherwise it could take a long fall if it derails in the wrong place. There's also an S-curve on the left which would make derailments more likely, although at least there is more space there. – Steve Sanbeg Dec 07 '18 at 20:20
  • To be more sure of the shape of the room, without measuring the angles directly, measure the diagonals. For a triangle but not a quadrilateral, the side lengths uniquely determine the angles. One diagonal is theoretically enough, but if you measure both you can tell whether you got one of the measures wrong or the walls aren't straight. – Anton Sherwood Dec 07 '18 at 22:32
  • tldr; But I would simply hand normal shelves on the straight lengths of the walls, then use a piece of cardboard, a pencil and some scissors to determine the shape of the corner pieces, then use the cardboard as a template to cut the wood. – Steve Dec 07 '18 at 23:16
    Why don't you use flex track??? – Hot Licks Dec 08 '18 at 01:31
  • How would people get in or out of the room when the tracks run around the entire perimeter? – gerrit Dec 08 '18 at 17:16
  • @HotLicks I am definitely using flex track! That'll make my life much easier. – QuestionerNo27 Dec 08 '18 at 18:03
  • @gerrit The layout's goes over the lintel of the doors, so nothing's being blocked. – QuestionerNo27 Dec 08 '18 at 18:04
  • @Steve That's a good idea. – QuestionerNo27 Dec 08 '18 at 18:04
  • @AntonSherwood That's very handy info! I'm sure going to try it and keep it in mind for all future endeavours with wanky rooms! – QuestionerNo27 Dec 08 '18 at 18:05
  • @SteveSanbeg Yep, they're pretty close in some places in my track test on AnyRail but have in mind I'll be using flex track (and I haven't actually changed the straight shape of the flex track on that test layout), so I'll surely be able to get a better fit. Plus, I'm going to be drilling holes regularly for some nice wooden posts that'll be strung through with wire. So they'll look very rural AND protect the loco and rolling stock at the same time. ;) – QuestionerNo27 Dec 08 '18 at 18:08
    @ti7 Well, there are no other kids that come actually. And there's really no way a kid can get up there. But I'll keep your comment in mind if ever a similar situation as you mention may arise. – QuestionerNo27 Dec 08 '18 at 18:10
  • @Criggie Yeah, I'm going over all doorways! So the track won't cover any opening. – QuestionerNo27 Dec 08 '18 at 18:10
  • @JS. Never saw such a wonky room but I did think to myself that if the rest of the room is so badly made, in all probability the walls wouldn't be that straight. Fortunately, it seems the architect's or builders' only talent was in straight walls! They're not that bad, thank god, so at least I don't have to worry about that. (If they were also wonky like you say, I think I'd give up on this project!!!!) – QuestionerNo27 Dec 08 '18 at 18:12
  • @gboffi Yes, I'm taking into account he track radius that comes with the set – QuestionerNo27 Dec 08 '18 at 18:13
  • @Fattie Yeah! That's why I need either diagonal corners or rounded corners, whatever is "less impossible" in my case – QuestionerNo27 Dec 08 '18 at 18:14
  • @Bent Yup! I first made a track layout on AnyRail and then started designing the shelving layout. :) – QuestionerNo27 Dec 08 '18 at 18:14
  • @EricLippert Yeah! I think that's what I'm looking forward to the most! Actually, we haven't even received the train set yet and I've already bought myself several little tools I'm going to need for this! (It's Christmas for me, too!) I'm going to buy a coping saw and I think I'll invest in a nice Carcass Saw... either rip or cross, not decided yet... but that'll really come in handy in the future —I had to leave mine in the last country I lived in because taking saws and power tools with you is so difficult! :( – QuestionerNo27 Dec 08 '18 at 18:17
  • @LorenPechtel This sounds interesting. I'm going to try that out to see how it works. It'll come in handy in the future. – QuestionerNo27 Dec 08 '18 at 18:18
  • @AntonSherwood That's why I suggested measuring the diagonals. The figure becomes rigid rather than flexible. Normally it's a standard test for squareness (the numbers match) but in this case it's obviously not square. – Loren Pechtel Dec 08 '18 at 19:18
    Dude - buy a real spirit level for this. The cellphone ones are only accurate to 3~5% which is only slightly better than eyeballing it. New job new tool! – Criggie Dec 08 '18 at 21:21
  • Since you're looking up at the train, consider using clear perspex and not wood. That way the train can be seen going past. You can also use LED "street lights" to slightly illuminate the corners. If the engine and rolling stock permit - you can even light them up with tiny LEDs inside, to add to the illusion. – Criggie Dec 08 '18 at 21:23
    @criggie strongly seconded -- a spirit level, or better even a laser one on a leg that you can project a line all around the room. If this is truly such a wonky windowless room-from-hell, what's the chances that the floor & ceiling are near level? My 1970-built house had a 2-inch drop between left and right side of a kitchen island, hard to fiddle away once open plan. Not sure OP measured for that. – user3445853 Dec 10 '18 at 11:31
12 Answers12
31
The Easy Way
Fortunately, you're holding up a model train, not an actual train, so you can take some liberties.
The hard part is following the rounded, off-square corners; the easy way to work around that is to literally cut corners. Rather than attempt to follow the rounded corners, just install four shelves as long as the straight parts of each wall, then measure and cut four trapezoid shaped connectors for the corners. Just about any method would work to join the trapezoids to the main shelves since there's not much weight to support. You might use pocket screws, maybe half lap joints if you have the router etc. available.
The Hard Way
You could do some geometry, measure diagonals, get out a protractor, etc. etc., and find the angles. You may even be able to use an app that works with your phone to determine the layout. But in my experience these things don't end well :)
Here's how I picture doing it ... be warned, these things don't always work the way I pictured it.
Install your shelf brackets first
You'll want to rest the shelves on the brackets as you figure things out. I'd place them all on the straight (not rounded) part of the wall, but try to get one as close as possible to the point where the wall starts to round.
Make each shelf as if it was going to be the only shelf
This will be the most time consuming step.
Use a contour gauge, make a pattern out of cardboard, and cut each shelf to hug the rounded part with a jigsaw or coping saw. A rasp may be handy for fine adjustments. Be prepared to spend some time and possibly waste some material.
Err towards removing less material and you'll be less likely to have to scrap it and start over. Remember that a 5-6mm gap will be fine, you're not machining an engine block, you don't need thousandths of an inch precision.
Look forward to the steps where these shelves are cut to fit - don't waste time fussing with a good fit in the portion that's going to wind up cut off.
Lay the shelves in place and mark intersection points
This step is easy but it's the key to the layout. Lay the North and South shelves in place on the brackets, then lay the East and West shelves on top of them. Mark the inside intersection points in each corner, on both shelves.
Cut the East and West shelves
The exact angle isn't important, you don't have to bisect the angle perfectly as long as you start the cut from the intersection point. That will be the key to making these fit nicely.
Mark and cut the North and South Shelves
Now you're coasting... put the East and West shelves back on top of the North and South shelves and mark the cut lines.
Check the fit, and fasten the shelves to the brackets, and you're ready to put tracks on it.
batsplatsterson
  • 24,954
    "Mark intersection points" - I'd simply cut the East/West shelves long and leave square ends on them. When you lay them on top of the North/South shelves, draw a line on the N/S shelves where the E/W shelves hit, cut the N/S shelves, then presto-blamo, they'll all drop into place nicely. If this is exactly what you said, sorry for repeating it - I got a bit lost at the "intersection points" part. – FreeMan Dec 05 '18 at 20:56
23
You don't. You transfer cut marks.
You don't need to make a paper plan of your cuts. Just lay the shelves on each wall.
Don't attempt to span a whole wall with 1 shelf board, it should always be 2 boards for ease of handling. If the wall angle is less than 90 degrees, initially cut each shelf at 80 degrees so its back can go all the way into the corner. The shelves will overlap at the corner.
Now see where the shelf fronts (lips) meet. From that point to the actual wall corner on the upper board, snap a line. Pull that board, cut on that line, and reinstall it. Trace (transfer) that cut line onto the lower shelf. Take the lower shelf off, cut on that line, and reinstall it. They should fit within a pencil's width of snug. You really don't want it snug snug. 5mm of gap is better than 0.
You don't want to fit it too perfectly, or ordinary expansion/contraction could jack against your walls and do damage.
When you get to the corners, figure out the radius that your train will need. It's the same trick, clamp up the piece and then transfer the cut marks from the pieces it needs to attach to.
    Easy and correct. It is often possible to forgo all "numeric" measurement, and just measure with physical objects (sticks with notches, or, as shown here, "in situ" right on the board). – AnoE Dec 06 '18 at 13:00
  • Indeed if the shelf brackets are already there, use small offcuts to raise the one plank [exactly its own thickness,] so it rests neatly on the other, not at an angle. – user3445853 Dec 10 '18 at 11:56
13
I'd suggest going with the plywood over the particle board. Will probably be a lot lighter, and probably more dimensionally stable as well. Depending on your scenery goals, I might suggest using 1/2" ply with a foam top to allow ground contours for visual interest. Use blue or pink foam, and not the white beaded foam, as that is much more messy. To cut the foam, use a florist's hot knife, though make sure to have suitable ventilation.
If you have at least a power miter saw, I might suggest doing the corners in pie-type trapezoidal segments like I have done on my layout, and then gluing the corners together with the top layer offset from the bottom layer by 50% for gluing surface. Such as this:
Curved corners with straight cuts
It looks like your current diagram is to have it all the way around the room. How about windows, closets, or doors? Those need to be accounted for in your plans, along with anything else. If you're planning on a high-level run (i.e. close to the ceiling, above any doors or windows), HO is not the gauge to do it in, as it will be too far away for easy viewing by children.
Is the target audience (i.e. child) already a train fan? If not, you may be going for a whole lot of extra work that will never be appreciated nor used enough to justify the cost and time you'll be spending. If this is the case, then I would suggest setting up a 4x8 foot sheet of plywood on some crates or legs and doing some loops of track at child level so they can interact with the train.
From personal experience, a child needs to be able to interact with the train to be able to keep their interest, and don't skimp on quality of the train, as a poorly performing train layout is not going to keep the child's interest for long at all.
Milwrdfan
  • 3,773
    FWIW I don't think the OP was intending to make a deep-dive into model railroading or large layout benchwork. It seems to be more in-theme with a mom-selected festive holiday decor, if I were to guess. That said, your points about HO being arguably too small for that distance (I think these projects are more frequently garden-scale?), and that a child would probably appreciate a simple 4x8 starter layout they can interact with more than a decor-train looping ceiling are very good points worth considering. – elrobis Dec 05 '18 at 18:22
    I was also curious about the doors :) – axxis Dec 06 '18 at 20:42
12
Just four simple cuts.
I would use slightly oversized brackets and leave a gap against the wall. It might actually make for a nice floating effect.
Set a shelf along one wall, leaving a uniform inch or so behind and keeping all shelf boards in alignment with each other. Leave gaps at the ends, also. Now lay the shelving on an adjacent wall, overlapping slightly with the first. Trace the first shelf onto the second and cut to that angle. Rinse and repeat twice more.
You'll end up with well-fitted corner joints and avoid the whole wavy wall, rounded corners debacle altogether. The best part? Just four simple cuts*.
12 or 16" pre-finished or melamine particle board shelving would probably work just fine for this technique, assuming supports every 32". All cut edges would be hidden. Make your cuts from the visible side (top or bottom, depending on shelf height) because the tearout side won't have as clean an edge.
*I realize that additional rough cuts may be necessary to fit the shelving for tracing. The four cuts statement refers to finish cuts--those required to make everything work together and look nice.
    Not a bad solution here, staying off the wall eliminates a lot of problems, but corners without a bend may make routing the tracks difficult. I'd also rip the 12 inch boards down the middle for a 6 inch width, from what I remember HO gauge trains are fairly small. – Gary Bak Dec 05 '18 at 18:09
  • Corners without a bend? I'm not sure what that means. Yeah, not sure how wide it should be. – isherwood Dec 05 '18 at 18:58
The comment about using cardboard or foam board is exactly why I was thinking.
I would cut 4 identical straight pieces, make their edges square and mount them centered on each wall.
For the corners, tape a wire to the outside edges, between two of the boards to define the inside arc. Hold up the cardboard and cut out the walll edge, then trace out the cut using the straight boards and the wire as guides.
Repeat for the other three corners.
PS: I'm not a big fan of particle board, it's okay when covering with a laminate, but it chips easily and doesn't paint well. For this kind of project, I'd use ply with an iron on edge band.
Gary Bak
  • 1,226
    +1 for the wire suggestion. Just to be clear, you're suggesting using like, a coat-hanger or a short-ish length of 12 AWG wiring to template each corner curve? Fantastic idea. I have to remember that the next time I need to template a curve. – elrobis Dec 05 '18 at 18:13
    @elrobis both a coat hanger and ROMEX are going to have a spring constant that will make them tough to work with, so one time I found my self using solder - it works great provided it doesn't have to support it's own weight for very far. – virtualxtc Dec 06 '18 at 08:44
  • As already suggested a coat hanger would be too stiff, you could make it work by defining the bend yourself, but I was thinking on the line of something more thin and flexible like a multistrand 22 or 24 AWG. Actually just thought of it but weed eater trimmer line may work as well if you have that lying around. – Gary Bak Dec 06 '18 at 21:10
As a slightly out-of-the-box idea, you could have the gap and build model bridges for the model trains - it would mean that you weren't highlighting the odd shape for the next person to walk in, and might add some interest to your setup? (depending on your modelling ambition, it might also make it easier to make each side a different 'zone', focusing on different ages or landscapes...)
As pointed out by user3067860 - if you also made the train go up and down grades on the walls, it would be much less obvious that the room is, you know, a bit out there.
Joe
  • 221
This is doable. To get a better idea of the actual shape of the room, measure its diagonals - that should help you find the correct angles for corners. The curvature will make this tricky, but if the curvature is relatively equal in each corner measuring the diagonals should still give you a more accurate model to work from.
After that there will be be some trial and error involved in cutting the shelves, so it's a good job particle board is cheap. Your design is good because the four main shelves can be cut with confidence - only the corner pieces will need to be cut to match their environs.
Alex
  • 71
  • To measure a diagonal you need to know where the corners are. How do you know where the exact corner is on a rounded wall? – virtualxtc Dec 06 '18 at 08:47
If you want to stick close to the walls, there's a simple four-step process.
1: Cutting Corners
First, start with the comment by Kinnectus - get four pieces of paper or foam, and cut them to fit nicely in each corner. Leave enough space to make sure the wall has flattened out. Use a square to make sure the ends are at right angles with the wall
Importantly, number each piece of cardboard, so you don't mix them up! If you have to, put up pieces of tape on the walls, marked with the corner number.
Also importantly, measure at the installation point! I have some wacky walls in my own home, and nothing is more frustrating than realizing the walls tilt in or out, as well as in and out, and you've cut your board 2cm short.
2: Corner Installation
Once you have the corners templated, transfer the corners to your boards and cut them out, taking care to number the cut-out pieces to match. Then install them - temporarily, at least.
Install the first corner, and make sure it's level. Then, install the second corner, and using a long, straight board and a level, make sure the two corners are level to each other. Next install the corner diagonal to the second, next to the first corner, and make sure it's level. Finally, install the fourth corner, and level it with the two adjacent corners.
3: Cutting Straights
Place a board against the wall to make sure it's flat. If it is, you're in luck; measure between each corner, mark your boards, and cut them.
If it's not flat, you'll need to repeat the previous process: use cardboard to measure the curve of each wall, then transfer that curve to your board. The room-facing edge can be flat.
If the walls are really out of whack, you may need to cut once to match the curve of the wall, then set the board on top of the corners and mark the edge, and cut that next.
4: Final Installation
Make sure the corners are well-affixed, then attach the boards. Place brackets no more than 60cm apart, more if you're expecting to use the shelves for something heavier later. If the wall has any small irregularities (trust me, it will), you can file or sand the boards to get them to fit.
All that's left is to install the tracks!
Other Notes
I don't know what the speed controller looks like, but don't forget to plan where it goes. You may want it next to the track, on a shorter shelf, or mounted on the wall; make sure the wires have a place to go.
If you want the shelves to have a finished look, I'd suggest using painter's caulk to fill in any gaps in the wall, and give it a nice coat of paint.
ArmanX
  • 598
You need to know in advance what are the curvatures available for the curved tracks of your model train system and how much they can be bent to adjust for the non-straight angles of your room. With this info you can proceed as follows
  1. put in place the brackets, on level,
  2. cut the straight boards, taking into account a minimum radius of curvature that https://www.thesprucecrafts.com/minimum-curve-radius-model-trains-2382285 reports in the range of 40 to 55 cm for HO models, you have to take into account the curved tracks available for your project — to determine the length of the board you are going to use against a wall of length L take into account the gap d between the board and the wall, the width w of the board and the radius you have chosen for the curvature r, the length ℓ of the board must be ℓ = L - 2 r - w - 2 d (of course you do not need extra precision),
  3. place and fix the boards on the brackets, trying to put them at the centre of each wall,
  4. for each corner, measure using a pen and a (large) sheet of paper the quadrilateral (almost a trapezoid) that is defined by the four corners of the converging boards,
  5. using a compass and a ruler, find the centres of the two circles (outer and inner) that connect the boards (no extra precision needed) and draw the circles on paper,
  6. transfer each drawing to a plank of wood and cut accordingly,
  7. using supports mounted under the boards put in place the four corners,
  8. lay down the tracks.
gboffi
  • 161
My general cowboy approach: put in two shelves on walls opposite each other, exact elevation is not critical, but should be within 1-2". Then overlap the other two shelves over the first two. Add some wood wedges to navigate the track elevation changes between the two sets. This might add some small interest to the track by creating elevation changes in the track for the train to go up/down. Hide the overlapping areas with scenery. If the overlaps do bother you, just mark the overlapping areas on the top shelves and cut that off. The shelf bodies will be supported by your shelf mounting system. Vibration at the joins can be controlled by using screw in flat metal straps.
Arluin
  • 1,025
How about creating a simple angle gauge using 2 pieces of wood connected by a screw at the end.
put gauge in corner tighten screw, and take found angle to shelf to mark it to be able to cut to size.
Mount shelf, now use angel gauge on corner created by shelf and wall and repeat process , you should be able to have 2 shelves in a corner that connect nicely.
repeat process for all corners and filling in the straight pieces should be easy.
when making the angle gauge cut some corners of the planks you use so it is easier to get into the corners. ( and probably you need to do the same to the shelves)
Richard.
  • Hello, and welcome to Home Improvement. Good idea, although the OP will have to leave room at the corner of the gauge for the smooth corners of the room. – Daniel Griscom Dec 07 '18 at 12:31
There's a good chance you'll be creating scenery, which will hide the table/wall corners behind layers of chicken-wire and papier-mâché and clay.
If you can predict that there will be a construction, then you don't even need a tabletop in that area, which could help reduce overall costs.
This will also give you access to run wires or hoses discreetly inside the scenery.
Criggie
  • 10,046
  • Since this answer, OP has said the track will be above head height, making this redundant because scenery will be blocked by the base board. An alternative is to use transparent perspex for the baseboard, and simply paint a scene on the upper walls. – Criggie Dec 08 '18 at 21:25
