What's the best way to attach 4 mil plastic (vapor barrier) to the studs? I tried to use regular nails (sinkers 4d 1 - 3/8'') but the plastic sheet goes off the studs (through the head of the nails) any time I pull the plastic sheet a little bit.
Asked
Active
Viewed 1,239 times
6[Staples](http://images.wikia.com/prowrestling/images/e/ed/Staple_gun.jpg). Don't forget to seal the seams with appropriate tape. – Tester101 Jun 30 '12 at 15:20
@Tester101 that could have been an answer. – BMitch Mar 03 '14 at 12:23
Just doing some repairs on my (Canadian) house and it uses black foam glue (the tube said "acoustic foam") around the edges and nails with an L shaped right angle head along the studs
mgb
- 1,615
- 2
- 14
- 16
