-5
This came about out of a conversation with a friend and we were wondering if it was theoretically possible to power a device with a hot wire and have that device's neutral/ground be attached back to the same hot wire? Assuming the hot wire is eventually grounded itself.
We just want free power.
Would it work in space?
    +--> fusion power plant +---+---^-----------> earth ground
    |Device           |       |              |
    |        v           v           |       |
    |   processor<------+global storage device|
    |   sensors                      |       |
icirellik
  • 113
    Your question, as written, doesn't make sense to those of us who understand electricity. It may help if you draw a diagram of what you're trying to explain. – brhans Jan 06 '19 at 14:52
  • Added a diagram and thanks for being helpful! – icirellik Jan 06 '19 at 18:21
No. Electricity travels in loops. If you don't have a loop, it will just sit there.
In mains electricity (which I assumed we're talking about here since that's what we do in a home improvement stack), if you somehow manage to ground any of that, you'll get a big bang poof until something burns, blows, or trips.
Now that I see your edit, I see more where you're coming from. The first thing is that current travels in loops, it needs to return to source not ground. Ground is not a return for human generated power: neutral is return.
In mains power, we do bond neutral to ground. But in mains power at the level you would ever charge a battery, you must always wire the neutral, you cannot use a wired ground or the earth for return.
If you are the power company, then yes, you can do that for distribution between far-swept buildings; it's done in the outback of Australia and in developing countries. However all these use very, very high voltage and low current. For a reason.
In low voltage power, you can do almost whatever you want as long as voltage is kept below 30V and wattage below 55VA. But it won't work very well for the same reason: Dirt is a terrible conductor. That's why we go to all the trouble to dig up copper and smelt aluminum.
  • It would be worth updating the response to say "in loops of least resistance", since it will flow "on all paths" at some r=1/rt, ohms law – noybman Jan 06 '19 at 19:06
  • Agree, as written this is a crazy proposal.+ – Ed Beal Jan 06 '19 at 22:05
  • What if I'm DIY'ing my own power plant? Then this is the perfect forum! – icirellik Jan 07 '19 at 23:01
  • Also, if there is a better stack to ask this I would kindly leave in hopes of people with more empathy. – icirellik Jan 07 '19 at 23:01
    Well, it really helps to be asking in the right stack. Despite the name, this stack's wheelhouse is *home* improvement, so electrical questions are off-topic here unless they relate to installations a) plausibly in a residence and b) that could plausibly be Code compliant, as we only discuss Code compliant methods. Almost anything else electrical (and certainly most things involving non-architectural low voltage) goes over to electronics.se, except for highly theoretical questions that belong on physics.se. – Harper - Reinstate Monica Jan 07 '19 at 23:10
  • I also found electrical engineering, this is more like a What If from XKCD. Can it be done, is it reasonably practical, and can it be monetized! – icirellik Jan 08 '19 at 04:12
  • hmm, you might want to [take the tour](https://diy.stackexchange.com/tour) and learn what this venue is exactly. One of the annoying things about SE is that many, many questions, opinions or thoughts have no stack at all where they would be on-topic, that would include many XKCD what-ifs... and certainly this place is the opposite of a social forum. That's a blessing or a curse depending on what you are looking for. But, that's what other web forums are for. – Harper - Reinstate Monica Jan 08 '19 at 04:44
