I have an enormous hole in the drywall where the gas pipe comes in to my stove. Should I use steel wool sheets to cover the hole?
Susan
I know this may sound silly but it actually works. Take some cotton balls and saturate them with peppermint oil and stuff them in that hole. Then do as you stated and stuff some steel wool into the hole. I would follow that with some 45 minute dry time sheetrock mud (you might have to use some foam filler first if the hole is really big).
The peppermint oil will keep the rodents away in the short term. Rodents that are familiar with that entry may return to find the steel wool, which they will ingest and eventually die. The sheetrock mud will be a (hopefully) final deterrant for any other rodents to enter at this location.
Jerry_Contrary
  • 3,675
It may be time to learn about hardware cloth.
It's a flexible metal mesh, sort of like window screen but much larger and heavier. It's good at what steel wool is not: covering gaps.
However if you don't like non-consensual ventilation, you may want to use a solid material like plywood or drywall. They can chew through much of that. But a sandwich of this and also hardware cloth will stop 'em cold.
Better than steel wool is copper wool. The mice don’t like the taste.
Bud
