Does it matter how you sheath around an exterior door? I think it would be stronger to break the sheathing over the door than at the corners, but I'm not sure.
The wall is not load-bearing. Studs are 24" O.C.
The wall is framed like this:
Option 1:
Option 2:
Option 3:
This last one may require some extra cripples at the ends of the header, as a nailing surface.
For extra credit, describe how to sheath around windows, too. (The main difference is that there's sheathing under a window, which a door does not have.
Jay Bazuzi
  • 11,678
  • 33
  • 96
  • 143
  • As an aside, if you can find a local Habitat group that is starting a new project in your area, that's a perfect opportunity to learn rough framing. – BMitch Jul 18 '12 at 01:33
Option 1 is probably the best and 3 is the worst. Similar to drywall, you don't want a seam at the corner. This is where the load causes the most stress and therefore cracking.
For windows, it's the same. You install a full vertical piece as if the window isn't there, and make sure the seam isn't in the corner. Use a chalk line to mark the edges of the window frame, and then you cutout the window with a circular saw.
Note that if you install your sheathing before raising the wall, be sure each corner has the sheathing extend out to overlap appropriately. I like to stagger the joints so there isn't a direct path in the corner. Installing the sheathing before raising the wall makes it heavier, but allows you to completely square the wall first, and it's much easier to nail.
BMitch
  • 42,687
  • 197
