I have a three bulb light fitting that worked fine with 40 watt golf ball bulbs. On removing the bulbs and inserting the first 5.5 watt led the bulb illuminated while the fitting was turned off. This only happened in the one bulb holder the other two worked fine. The fitting now has 2 leds and 1 40 watt bulb and is working fine, any ideas? Cheers
Asked
Active
Viewed 167 times
Is there a dimmer on the circuit? – bib Feb 06 '19 at 19:01
No dimmer but are switched 2 way and work fine off both switches? – David Thomas Feb 06 '19 at 20:03
Do either of the switches have an internal light that comes on when switched off? – DoxyLover Feb 07 '19 at 01:01
