I'm trying to replace the battery of my watch, but I can't work out how to take off the back cover, to get to the battery? (see photo)
Watch Back Case
I've Googled on how to remove the back cover of watches, but it seems to be the back covers vary quite significantly, and all the ones I've found tutorials for seem to have either screws or some notch on the back, yet mine has neither!
As you can see from the photo, my watch has a smooth metal plate on the back, with no obvious means of removing it.
Any help?
McMan
  • Hello, and welcome to Home Improvement. Unfortunately, this has nothing to do with Home Improvement. – Daniel Griscom Feb 11 '19 at 02:35
    I'm voting to close this question as off-topic because it has nothing to do with Home Improvement. – Daniel Griscom Feb 11 '19 at 02:36
  • Hi @Daniel Griscom , I placed this in Home Improvement, since this forum includes DIY (since I'm looking to replace the battery myself). And it looked the most appropriate of the Stack forums to ask this in. I'm new to Stack, but if you feel there's a better Stack forum for this question, please let me know – McMan Feb 11 '19 at 17:42
  • take the watch to a jewelry store and have them replace the battery – jsotola Feb 11 '19 at 19:09
  • You're not the first to be misled by our "DIY" URL; we're pretty focused on homes. Please [take our tour](//diy.stackexchange.com/tour) so you'll know more about our policies. – Daniel Griscom Feb 11 '19 at 19:10
That back cover on your watch is a press fit into the main frame of the watch body.
The typical way these are removed is to place a sharp blade along the side groove where the cover meets the body. Most times the cover actually hangs over the body some toward the outside and placing pressure on the sharp blade will start to make the cover pull up from the body a small amount. Continued work around the perimeter will eventually get enough of a space between the cover and the body that you can get a small flat blade screw driver in the space to twist and get the cover fully free.
Reassembly is a process of just pressing the cover back in place. You want to make sure to squeeze it into place evenly all the way around so it goes in straight. If the cover is cocked off at an angle it could bind in the body and not seat all the way in.
Michael Karas
  • 64,093
  • 63
  • 142
Three tools for watch cases
Three cheap tools from a well-known online retailer named after a river.
The middle one I found to be almost useless. It is the style used by some professionals but they probably use much better quality versions and have more skill than I do.
The right hand one is excellent, works for all but one of my watches with press-fit backs (not that I have many).
I bought the left hand one for a troublesome Tissot. It worked perfectly.
Press-fit backs generally have, somewhere around the perimeter, an area with a slightly larger gap (or a gap rather than none). Sometimes barely perceptible. You insert the sharp hard edge of your tool there and lever the back off.
For refitting the back, I find a watch press useful:
watch back press
Though any soft-faced vice would probably work if you are careful. The advantage of the above item is that it doesn't exert pressure on the glass/crystal front of the watch and so doesn't risk cracking it.
There will be a gasket. Make sure it is in the right place or it will be impossible to refit the back. On my Tissot the gasket was left in the case when removing the back but to replace the back I had to first fit the gasket to the back, not to the case. Other watches will vary considerably.
Although some of these tools cost less a cup of coffee at a coffee shop, they might seem expensive compared to the cost of a Yazole, so you'll have to make a choice based on how many battery changes you expect to do in future.
RedGrittyBrick
  • 24,201
  • 47
  • Thanks for the info, can you give me the names of those tools, that you used to take off the watch back? (particularly the black-handled one on the far right, if that seems to work best?) – McMan Feb 11 '19 at 17:48
  • @McMan: In the typical style of far eastern vendors who ply their trade on Amazon: "NUOLUX Watch Opener Tool Case Opener Pry Type Repair Tools (Black)" – RedGrittyBrick Feb 11 '19 at 17:54
