13
I was told recently that concrete is slightly corrosive.
Should gloves be worn when using concrete or is it fine to handle concrete as long as its not done on a regular basis?
PriestVallon
  • 367
    Any skateboarder can attest to the fact that concrete is hell on the skin. – Chris Cudmore Jul 29 '12 at 15:36
  • I'm specifically talking about wet concrete. – PriestVallon Jul 30 '12 at 09:40
  • water mixed with concrete results in the cement reacting to form hydroxides (calcium/sodium) and during that time the pH is around 11-13 which is very corrosive. – ron Sep 30 '19 at 19:32
  • **should** gloves be worn, yes. properly curing wet [cement] at pH around 12, depending on roughness of hands is not an immediate burn and one can get away with no gloves with good judgement. It would be like handling full strength bleach. – ron Sep 30 '19 at 19:39
6 Answers6
Cement (the active component of concrete) is a base (an alkali) that can be irritating to skin. It is not very strong and should not be a problem on all but sensitive skin, if the exposure is short or intermittent. It could be very irritating to eyes and nasal passages if there is a lot of exposure.
Gloves are not a bad idea (e.g., disposable nitrile) but concrete pourers and DIYers handle all the time with little ill effect (again, for short exposure).
bib
  • 33,635
  • 100
  • Note that "short exposure" is not the opposite of "regular basis". One is frequency, the other is duration. – Jay Bazuzi Aug 01 '12 at 23:48
    good point. repeated exposure or long duration both warrant extra protection. – bib Aug 02 '12 at 00:28
  • Depending on your skin toughness, being an alkali, Portland Cement is a pretty good defatting agent. The slick feel you get from it is it removing all the skin oils. If you're mixing up a wheelbarrow of cement and wash it off immediately, no problem. If you're doing a long term foundation pour, wear gloves. – Fiasco Labs Jun 04 '13 at 15:19
Corrosive? You bet. Wet concrete can cause chemical burns, 3rd degree burns, cause blindness if gotten in the eyes. Wear gloves no matter how often you use concrete. Now, unless you like what your skin turns to when working with concrete without gloves, go ahead.
Gunner
  • 4,417
  • Are you suggesting that "wear gloves" is the appropriate response to "can cause blindness if gotten in the eyes"? – Jay Bazuzi Aug 01 '12 at 23:50
    @JayBazuzi I think the suggestion is that people often rub their eyes with their hands, especially when irritated, so you don't want your hands to be covered in a substance that can cause blindness. But wearing eye protection and a dust mask wouldn't be a bad idea, especially while mixing. – BMitch Jun 04 '13 at 10:52
  • As an example, some individuals have gotten 3rd degree burns requiring skin graphs from kneeling in wet concrete for as little as 2 hours. – AaronLS Oct 07 '14 at 22:38
Please, please wear gloves! Especially if you are a DIYer, and will be working on a project that involves any more than two pounds of cement. I did not listen to the warning, and worked with the wet cement without gloves. We were filling the bottom of a pond that had cracked, and spent about 5 hours across two days working. I didn't notice anything at all while I was working, but as soon as I rinsed off my hands, I found plenty of small puncture wounds and sores that the gravel had eaten into my skin! Even my father, who has carpenter's hands, had the same sores. My advice to anyone working with cement for more than an hour is to wear gloves. Even the cheap disposable kinds really helped my grandfather and brother to avoid the pain and irritation we experienced. Cement also really dries out your skin, so now on top of the sores, I've got cracks and tight skin.
Just wear the gloves!
Heather
  • 71
    Everyone working around concrete does that at least once. You learn to have spare sets of gloves in the pickup if you're doing any amount of concrete work. – Fiasco Labs Jun 08 '13 at 18:54
As you can see from the other answers, there is a range of opinions.
I have observed that some people handle concrete bare-handed without trouble, while others' skin reacts very badly. For example, my neighbor got sores very fast with exposure to concrete while setting fence posts. And I've heard reports that these types of sores heal very slowly.
If you don't want to wear gloves, then try without them, and see how it goes.
Certain activities require more contact with concrete than others. For example, when building a cordwood masonry wall, you typically place concrete by the handful. The literature recommends wearing heavy rubber gloves, and coating your hands with a protective oil beforehand.
Don't forget about your lungs. Breathing concrete dust can be harmful, in ways that you can't immediately detect. Consider a dust mask when mixing, especially indoors.
Jay Bazuzi
  • 11,678
  • 33
  • 96
  • 143
Wear gloves.
I made a similar mistake. My injuries aren't as severe as this guy but still similar in nature. I'm not sure if it's the abrasive action of the sand or the caustic affects of cement/lime, but likely a mixture of the two resulting in this mess. I started getting these injuries within 2-3 hours of working with cement/concrete. It's also extremely basic which sucks the oils right out of your skin which on its own has the potential to damage your skin.
Originally from reddit: enter image description here
horta
  • 148
    I work masonry so I go thru tons of gloves and when someone's breathing down your neck it's easy to cross contaminate when switching gears even when you know how severe cement burn can be best thing to do is keep vinager handy as this will neutralize the base in the lime rinse and put tripalbiotic ointment before you end up like that guy. – Nick Mar 14 '18 at 13:30
  • @Nick Good idea. I guess I should have tried that. – horta Mar 16 '18 at 14:47
I’ve been working with cement and concrete the past 2 days. I was using my bare hands to mix it and while it was irritating after a while my hands were fine. They did get somewhat dried out. My boyfriend was using it to fill in parts of our cellar floor and he received chemical burns on his finger tips and they are oozing. My suggestion if your going to be using concrete or cement even for a few minutes is to wear gloves.
Laurie
  • Hello, and welcome to Home Improvement. Thanks for the answer; keep 'em coming. And, you should probably [take our tour](//diy.stackexchange.com/tour) so you'll know how best to contribute here. – Daniel Griscom Sep 30 '19 at 19:23
