My house has a guest bathroom that has a shower/tub combo, but I realized there seems to be no way to get the water to come out of the showerhead instead of the faucet. There is a volume and temperature control which is identical to the one in the stand-up shower, but nothing on the faucet to pull up to control where the water comes out. There's nothing on the showerhead either. All I can figure is the previous owner swapped out some hardware when they left, but I have no idea what. Is there some easy fix to this? Am I a moron and missing something obvious?
Asked
Active
Viewed 746 times
13
If I'm not mistaken, you can pull down with some force on the bottom of the spout.
If you turn the water on and do that, the water will come out of the shower head until you turn the water off (or until the pressure is low enough).
Ben
- 454
- 3
- 8
2This is it. I've used the same spouts. I like the clean look of not having the pull stopper on top, but they can be confusing to guests. – JPhi1618 Apr 05 '19 at 02:39
6+1 That style of diverter has tripped me up a few times. By being out of one's line-of-sight, it's not a very intuitive style. "You think you're smart until you try to turn on someone else's shower." – Doug Deden Apr 05 '19 at 02:40
1Yep, I had noticed the spout ring was a bit odd and could be spun, but didn't think to pull on it. Good to know I don't actually need to replace anything! – Kat Apr 05 '19 at 14:14
