15
I dug holes for four 8' 4x4 posts, and had the posts positioned and plumbed vertically in the holes, but had to leave for a couple days before I could concrete them in.
In the meantime, storms came and filled the holes. The ends of the posts have been sitting in that water now for 2 days. Are the posts ruined? I've thought about flipping them over to be sure, but if they're done for, no problem, I can use them for other stuff if I have to.
Thanks!
Kerry Thomas
  • 739
    What sort of pressure treatment? Above ground use only or ground contact? – Kevin McKenzie May 02 '19 at 19:17
    Doesn't really matter over a few days. – isherwood May 02 '19 at 19:53
    @KevinMcKenzie, ground contact – Kerry Thomas May 02 '19 at 20:45
    Unasked followon - all you need to do now is let the rainwater drain away, and make sure there's no muck dropped into the bottom of the hole, If you have room a trowel should be enough to get by the post without re-truing it. Then once its dried out enough get on with the concrete. – Criggie May 03 '19 at 00:41
    Concrete absorbs water too. Its presence won't protect wood from moisture over the long term. That's why the posts have to be treated to survive (or could be some species of naturally decay-resistant wood). – StayOnTarget May 03 '19 at 17:44
Pressure treated wood can handle submersion. Many folks just pack rock around the post, so they are always in water after rain. You should be fine to go ahead and pour your concrete with no worries.
yoozer8
  • 280
Pressure-treated lumber is pressure-treated by... wait for it... submersion. It was literally dunked in a vat of liquid. The vat was sealed and pressurized, forcing the liquid to enter the wood. It was then not kiln dried.
Your lumber is in roughly the same condition it was in when you purchased it. Also, it would have been just as wet even if there had been soil (or concrete) in the hole along with it.
    No wonder it's so dang heavy!! :-) – Kerry Thomas May 02 '19 at 19:31
    I assume you are correct in your final verdict, but arguing that wood treatment involving submersion in some undisclosed liquid means submersion in water of the final product is fine is a bad argument. I can easily make things with submersion in any number of liquids as a part of the manufacturing process that cant handle submersion in water upon completion. – Matt May 03 '19 at 03:26
    @Matt True in principle, but ["Usually, water solutions of preservative salts are employed with this process"](https://en.wikipedia.org/wiki/Wood_preservation#Pressure_processes) (even though oils are possible). – Peter - Reinstate Monica May 03 '19 at 12:08
  • For example, Matt? Since wood isn't "manufactured" in a strict sense, _that_ argument isn't worth much. Its properties are pretty well known. – isherwood May 03 '19 at 12:44
  • To be pedantic, you can purchase pressure treated lumber which is kiln dried after treatment. Obviously it's not the case here. – Matthew Gauthier May 03 '19 at 14:02
    @isherwood Wood isnt manufactured, but pressure treated boards certainly are manufactured, which is what we are discussing. Examples of manufactured products with liquid submersion as a step that dont work well long-term in water upon completion include any quenched metal blades, most electronics, and many foods. – Matt May 03 '19 at 15:18
