I just installed a pull chain fixture in a closet. The light works but I paid no attention to black wire to brass screw or white wire to silver. Of course when I am tossing the box I see the instructions written on the interior. Do I have to take it apart and check. Is it a potential problem?
Linda
    These are fundamental concepts in house wiring. You probably should do some reading before taking up your next wiring project. It can get dangerous in a hurry. – isherwood May 18 '19 at 22:07
    Does this answer your question? [Is Switching the Neutral OK?](https://diy.stackexchange.com/questions/55719/is-switching-the-neutral-ok) – Peter Duniho Jan 31 '21 at 22:12
Yes, you should fix it. If nothing else, if you crossed the wires, the threads of the socket would be hot, even with the switch off. This would give a good chance of shock when changing the bulb if you’re not careful.
DoxyLover
  • 12,615
  • 49
Yes, it's essential because you could have wired the fixture as a switched neutral instead of a switched hot... This is deadly! Turning the fixture "off" would not truly switch the hot conductor off and you could get electrocuted with the switch in the "off" position.
