I converted a three way switch in my dining room to a single pole smart switch and plan to put a blank wall plate where the old switch resided. I identified the common wire and the two travelers (one red, one black). At the switch that is being removed, I connected the black traveler wire to the other black wire that goes to the fixture.
The red traveler wire is now disconnected in both boxes, but when I turn the switch to on, my non-contact voltage tester shows that the disconnected red wire is hot in both boxes. How is this possible? Isn't it disconnected from all power sources?
Admittedly, I am an amateur and this is my first time doing this, but I understand (at least I thought I did) the concept here.
OnTheJon
    [Capacitive Coupling](https://en.wikipedia.org/wiki/Capacitive_coupling). It's not really 'hot', it just looks that way to your non-contact tester. – brhans May 23 '19 at 12:55
  • Also described [here](https://diy.stackexchange.com/questions/29394/why-am-i-measuring-16-volts-on-a-wire-that-should-be-at-0-volts). It's not capable of any useful work; if you connect a nightlight between red and neutral, it won't light. – Harper - Reinstate Monica May 23 '19 at 12:56
  • Thanks @brhans and Harper. Good to know I'm not going to burn the house down. – OnTheJon May 23 '19 at 13:21
    Possible duplicate of [Why am I measuring 16 volts on a wire that should be at 0 volts?](https://diy.stackexchange.com/questions/29394/why-am-i-measuring-16-volts-on-a-wire-that-should-be-at-0-volts) – ThreePhaseEel May 23 '19 at 22:25
0 Answers0
