My 110V toaster oven has a 2-prong cable. Also, the oven's chassis has a screw with a connected green/yellow earth wire, which I want to ground.
My wall socket is a modern 3-prong with earth and all.
Is there a special adapter that can convert the 2-prong plug + earth wire into a 3-prong plug? Is that the right way to go?
Thank you!Back side of toaster oven
Sleepster
  • 109
    Pictures would help. But, you could replace the entire wire with a newer wire similar to a power tool cord replacement. – Jeff Cates Jun 20 '19 at 02:15
    Can you get a new cord and strain-relief for the toaster oven? – ThreePhaseEel Jun 20 '19 at 02:29
    Without actually seeing the problem it is impossible to say what the best solution is, although the above 2 comments seem to be your best bet. However, if you are not confident doing this sort of modification it is best left to someone who is,or you may end up as the toast! – Peter Jennings Jun 20 '19 at 10:37
  • Thank you all for your replies. I've added a photo of the back side of the toaster oven. – Sleepster Jun 21 '19 at 15:05
    Is this thing even UL listed, or did you acquire it off Amazon Marketplace (Sold by xxxxxx and fulfilled by Amazon), or eBay, AliExpress etc. ? Coz the yellow/green ground wire is a *real bad sign*, it is a redflag for that... – Harper - Reinstate Monica Jul 21 '19 at 20:58
  • https://diy.stackexchange.com/questions/39848/japanese-appliance-has-a-green-yellow-ground-wire-coming-out-of-it-what-should – sleblanc Mar 25 '20 at 15:05
  • Do you have the instruction manual that was included with this toaster? What does it say about how to connect it? – Nate S. Jul 15 '20 at 22:35
  • Also, does the toaster have a square-within-a-square mark anywhere on it? – Nate S. Jul 15 '20 at 22:37
You could install a replacement three-prong plug and wrap the cable and extra wire with loom to keep them bundled. It's probably not strictly legal, but it's generally safe.
  • I am curious if really need to do that, given that my apartment is equipped with a ground fault circuit interrupter? – Sleepster Jun 23 '19 at 05:53
  • Probably not, but that isn't what you asked. – isherwood Jun 23 '19 at 14:13
  • So a GFCI is a replacement to grounding? – Sleepster Jun 24 '19 at 15:51
  • Lots of info to be found on that. [1](https://diy.stackexchange.com/questions/104170/replacing-two-pronged-outlet-with-gfci-not-grounded-is-it-adequate-for-electro), [2](https://diy.stackexchange.com/questions/121634/is-it-considered-safe-to-connect-ground-to-neutral-with-gfci-outlets), [3](https://diy.stackexchange.com/questions/91089/is-is-safe-to-only-use-a-gfci-with-no-ground-wires-downstream) – isherwood Jun 24 '19 at 17:41
  • use braided cable sleeve ... automotive supply store may stock it in different colors ... https://duckduckgo.com/?q=braided+cable+sleeve&iax=images&ia=images – jsotola Nov 08 '21 at 00:33
