Recently purchased a retrofit farm sink and went to hook the garbage disposal back up. After roughing everything back up because the farm sink sets much lower I am wondering about drainage and if this setup is acceptable. What do you think?
Asked
Active
Viewed 843 times
Robbiem
- 11
https://diy.stackexchange.com/questions/81969/what-is-the-minimum-height-for-garbage-disposal-drain-above-the-drain-stub – noybman Jun 29 '19 at 22:52
The drain pipe coming out of the wall is lower than the outlet of the disposal so it is good to go. **+1 for a well lit photo under a sink**. In the future if you use the search function of this site you may find the same or similar questions with correct answers. – Alaska Man Jun 30 '19 at 00:22
Hello, and welcome to Home Improvement. This will be closed soon as a duplicate; you should probably [take our tour](//diy.stackexchange.com/tour) so you'll know how best to participate here. – Daniel Griscom Jun 30 '19 at 12:18
