We learned here:
...that the fill valve sends water directly into the overflow drain...and that fills the bowl.
However, how does the tank (directly or indirectly) get filled?
P.S.
  • 225
By the valve operated by the float.
As the water rises in the tank the float floats and at a certain height that closes the valve which stops filling the tank as it is ready for the next flush.
Solar Mike
  • 26,234
  • 57
In that particular type of fill valve, the water comes out of the two areas highlighted in yellow in the picture:
  1. The fill tube clipped to the overflow tube.
  2. The bottom of the vertical tube that the fill valve sits on.
longneck
  • 21,108
  • 48
  • 79
