I have been having problems using hole saws when removing the plug of material after use. Looking at What is the right way to clear the drilled plug out of a hole saw? it is still awkward and I have considered spending the extra on buying Forstner bits as an alternative.
Forsner Bit
But then I am told they are not for drilling all the way through. Is it okay (or even safe or wise) to use Forstner bits in this way.
Chris Rogers
  • 443
    As with hole saws, you'll get a cleaner hole if you stop when the center comes out the backside and then drill in from that side - or you can drill a small center pilot hole so you don't have to be quite as fussy about when to stop drilling, given the rather short center on Forstner bits. Downsides are pretty much cost, available sizes, and the fact that you have to apply enough power to turn all the material into chips, which has to do with available sizes (I have, and use, a 4-1/4 inch hole saw. I think my Forstner set tops out at 2-1/2 inches...) – Ecnerwal Aug 04 '19 at 13:17
    @Ecnerwal, that comment seems more like an answer to me. – Toby Speight Aug 05 '19 at 11:54
    To get that scrap out of a holesaw, use a woodscrew longer than the hole-saw is deep. Just drive that into the plug that's left in the holesaw. As the screw advances, it will lift the wood-plug out like a screw-jack. – Barry Aug 04 '19 at 19:41
  • Surely the plug will jam against the drill bit in the middle? – Chris Rogers Aug 04 '19 at 19:49
  • @ChrisRogers Surely it will! More screws, like 3 or 4, are needed. – Mike Waters Aug 04 '19 at 22:04
  • Hello, and welcome to Home Improvement. Thanks for the answer; keep 'em coming. And, you should probably [take our tour](//diy.stackexchange.com/tour) so you'll know how best to contribute here. – Daniel Griscom Aug 04 '19 at 23:13
  • Hi Barry. As with all stackexchange sites this is a Q&A site, not a discussion forum. What you've written here doesn't answer Chris Rogers's question, so I've downvoted it. It would be a useful answer on the question Chris linked, however, which is [What is the right way to clear the drilled plug out of a hole saw?](https://diy.stackexchange.com/questions/42469/what-is-the-right-way-to-clear-the-drilled-plug-out-of-a-hole-saw). – AndyT Aug 05 '19 at 10:15
  • While they weren't intended to drill all the way through, they were for making flat-bottomed holes (think on modern cabinet hinges), they will work just fine for cutting all the way through a piece of wood. I find they work best on a press, it all depends how steady your hands are on a drill. You can get clean results from a paddle bit. Once that center spike starts to peek through the other side, start drilling from that side. I have 24" long paddle bits (hard to reach spots for running wires). – Phaelax z Aug 05 '19 at 19:31
I'm not sure why someone told you that you can't drill all the way though with a Forstner bit, but in my opinion, they are incorrect. These bits excel at creating a flat-bottomed hole but will also drill completely through the material just fine. I regularly use mine in a drill press but they can also be used in a handheld drill.
I find that they splinter the material much less than a spade-type bit does although they are significantly more expensive.
Here is what Rockler says about them:
Rockler
What's so special about Forstner bits?
Unlike the standard twist bit, Forstner bits are optimized for woodworking applications and cut exceptionally precise, clean-edged holes in wood. Because they're designed to produce a minimum amount of tear-out when exiting the material, Forstner bits are the best bit for drilling through holes. Forstner bits drill a flat-bottomed hole, making them a necessary tool for many hardware installations where a precise depth of mortise is required. Forstner bits are guided by the wide outside rim of the bit, unlike most drill bits, which are guided by the tip. Because of that, they can be used along with a drill press to drill angled holes, holes that partially overlap, and holes on the edge of the material.
jwh20
  • 23,085
    Forstner bits are more expensive and take longer to drill a hole than a hole saw. If time and money were no object, then use forstner bits for whatever you want. – Dotes Aug 04 '19 at 23:31
  • To be fair, while they minimize tear-out, they still cause tear-out to some degree in a lot of materials even if you go slow. I just had this experience last weekend (I just didn't care in this case so I just rammed through it). But if you can come back through the back side instead, it'll almost always be a cleaner hole since tear-out is zero on a starting surface :) – dudewad Jun 26 '23 at 18:43
I've always used hole saws before and yes, hard to get the plug out... extra trip to tool box for a screwdriver. Then I used a Forstner bit to install some hinges on cabinet doors. I loved them. They are fine for drilling through wood. They are much more expensive. They work better in a drill press, just like hole saws do but still work well with a standard drill.
JACK
  • 78,739
  • 72
  • 188
When drilling all the way through, a Forstner bit will splinter the back side considerably worse than a standard hole saw. (Of course, a spade bit is worst of all in this regard.)
Removing the "plug" in a hole saw can be tricky at times, but I usually have success by pushing it out with a nail or punch stuck through the holes in the bit. The arrangement of holes in the bit varies with size and design, however.
Hot Licks
  • 2,083
I found that when using a forstner bit with my hand drill, it’s much more difficult to keep a straight line when making deep holes (ex: drilling 1/2” holes 2.5” deep). I find that they easily veer to another direction, even if your focused on keeping a steady hand. In these scenarios, I prefer a paddle bit since the pointed end does a little better at keeping straight.
However, on a drill press, forstner bits are a dream to use.
