23
Had an issue today with a nail going through a water supply line in a bathroom. It got me wondering if there is a practical or technical reason there aren’t typically room-specific shut offs between the master shut off and the shut offs at the fixtures? Seems silly to shut down the whole house for a pinhole, but there really wasn’t a better option.
Just asking out of curiosity to see if there are any plumbers out there.
Mike Whitis
  • 363
    Not a plumber, so just a comment: Typically I see shutoffs at each *fixture* - e.g., beneath the sink, next to the dishwasher, etc. but not "entire bathroom" or "entire kitchen". – manassehkatz-Moving 2 Codidact Aug 12 '19 at 21:30
    Every valve adds another potential point of failure. Usually the house shutoff is easy enough to get at so there would be no real advantage. It's just water, seconds don't really count. – Puddles Aug 12 '19 at 22:26
    There is a manifold type plumbing system (Mike Holmes likes to use them) that has separate hot and cold feeds to each room. They are very uncommon. As @Puddles points out, they add one more thing that can go wrong, and they're more expensive to install. That being said, if I ever built a custom home, I would use one. – BillDOe Aug 12 '19 at 22:44
  • It would be more trouble than it's worth. – Hot Licks Aug 13 '19 at 22:03
  • The better solution is to use a metal detector if you don't know where things run behind your walls. They're not expensive. – Graham Aug 13 '19 at 22:06
    There should be a metal plate over the pipe at the stud to prevent this, something like https://www.garvinindustries.com/media/catalog/product/cache/1/image/1200x1200/9df78eab33525d08d6e5fb8d27136e95/s/p/sp-3_inuse.jpg – boatcoder Aug 14 '19 at 02:46
  • There are in Germany. – gerrit Aug 14 '19 at 06:56
    @Graham Metal detectors don't work well with plastic piping. – SomeoneSomewhereSupportsMonica Aug 14 '19 at 11:57
    good question :-) : As i drove down our street a fire-engine pulled into my driveway. Several fireman sprinted into my home. I followed, at least a little alarmed. OK!!! In the kitchen several firemen were attempting to quell a jet of water emanating from the standalone dishwasher. Another had gone outside to try to locate the water cutoff tap (well hidden :-) ). I had the advantage of knowing that in the pantry there was a cutoff valve for the dishwasher feed. I quickly evicted the miscellaneous food/bags. implements and turned off the valve. What fun. They enjoyed it too :-). – Russell McMahon Aug 14 '19 at 12:10
  • @BillDOe I think you're thinking of PEX piping. It's becoming more common, but you're right that any home older than ~10 years isn't going to have it. – Monica Apologists Get Out Aug 14 '19 at 12:16
  • Interestingly, I recently had to deal with the opposite annoyance when I wanted to shut down the entire water system, but frustratingly there was not a single shutoff point for the entire system so I had to find and turn off multiple shutoffs that controlled certain areas. – Aaron Aug 14 '19 at 16:39
  • @aaron, Don't you have a main shutoff at the meter? – Glen Yates Aug 14 '19 at 17:24
    @GlenYates The house in question has no meter. It has a well and pump. Maybe that allowed someone to get away with more questionable practices. There are some weird electrical issues too that I keep a certain breaker off for until I get around to fixing that as well. – Aaron Aug 14 '19 at 18:09
  • @Adonalsium, yes, you're correct. Manifolds almost always connect to PEX plumbing. I like them, but they are extremely rare in any typical, developer-built home. They're especially useful in fixtures where a shut-off valve is nearly inaccessible or nonexistent. – BillDOe Aug 14 '19 at 18:53
  • @BillDOe Conceptually, a manifold is like an electric breaker box. It gives you one place where you can shut off individual "circuits". I would absolutely specify a manifold for any new construction, even with the higher cost using more PEX. – Monty Harder Aug 14 '19 at 21:00
  • In the US, at least, ~60% of new homes have PEX installed during construction. – Monica Apologists Get Out Aug 15 '19 at 12:16
  • @Aaron With a well and pump system I would think you would just turn off the pump. Close the valve to any storage tank. – Loren Pechtel Aug 16 '19 at 02:05
  • @LorenPechtel Maybe I could have turned off the pump. I would be concerned that the internal air pressure balance could get out of whack if I emptied it too much. But then I don't know a lot about that. I'm not a plumber, and I don't mess with the pump and tank. If I ever need to mess with it again, I suppose that would be good fodder for another question here. – Aaron Aug 16 '19 at 15:17
8 Answers8
32
This is a result of building as efficiently (cheaply) as possible, and there is almost no need for room valves.
First, efficiency:
  • Valves are more expensive than pipe. Extra valves means more labor cost.
  • If the valves are to be centrally located, then more pipe is required because each "zone" will have to be home-run instead of branching off a shared pipe. Extra pipe means more labor cost.
  • If the valves are not centrally located, then they need to be located somewhere accessible to be utilized. That means either designing a space for them, or locating them somewhere not in the way. Extra design work and extra pipe means more labor cost.
Second, there is little need to install valves in advance:
  • In an emergency, shutting off the water to the house for a couple of hours (or a day) while waiting for a plumber (or a run to the hardware store) is an inconvenience that most people can manage.
  • The most common leaks are at fixtures, not in pipes. Each fixture usually has its own shutoff.
  • If you need a valve to facilitate a renovation while the house is occupied, it's easy to plan to shut off the water to the house briefly to install a local valve.
In summary, the expense of the extra valves, pipe and labor are not worth it, especially from the perspective of a builder, where a small reduction in cost per home built results in a large savings overall.
longneck
  • 21,108
  • 48
  • 79
    In addition, zoning doesn't just waste materials at construction time, but has a significant ongoing cost in lost/wasted heat and water, due to each zone having to source hot water all the way from the heater (incurring a delay to get it) rather than piggybacking off of warm/hot water already in the pipes from use of another zone. In climates where AC is in use, this translates to wasted effort by the AC to remove the heat that escapes from the pipes, too. – R.. GitHub STOP HELPING ICE Aug 13 '19 at 18:31
    Which can be alleviated by installing on-demand water heaters at the point of use (with the additional up-front cost that incurs). – Dennis Williamson Aug 13 '19 at 20:54
  • And note that pipes almost never spring a leak other than during construction work. – Loren Pechtel Aug 16 '19 at 02:07
23
The Viega Manabloc is an example of a system in which a central valve manifold uses a dedicated tube for every fixture in the house, as alluded in the comment from BillDOe. image of Viega Manabloc manifold
In some US homes it's not a difficult retrofit to split the house into at least two zones. Typically the water service enters an unfinished "utility closet" space where the water heater is also located. There will be a few tees and water pipes head off in different directions to the master bathroom, kitchen, other bathrooms, etc. These pipes could be cut and valves inserted so that water can be shut off somewhat selectively.
In my own house I reconfigured the plumbing in the utility room. I have the kitchen and basement bathroom on one pair of valves (one each for hot and cold) and the laundry and other bathrooms on a different pair. These are arranged neatly beside the water heater. This has allowed me to defer replacing the shutoff under every sink and toilet, which always seem to be jammed and/or corroded to the point that they can't be shut off when it's needed most.
It's not as fine-grained as the manifold approach, but routine plumbing repairs are far less stressful when at least one toilet in the house remains functional!
Now, to actually answer your question. It cost less than US$100 in parts and several hours of work to make that change in my house. Doing the work that way during original construction would cost almost as much. It doesn't happen because the home buyer doesn't want to pay extra for it, the builder doesn't want to pay for it from his own pocket, and the plumber isn't going to do this premium/extra work for free.
Greg Hill
  • 27,924
  • I know this as Pex plumbing manifold – Rsf Aug 14 '19 at 10:07
  • Similar manifolds are available in France (using BSP fittings!) with several outlets, with and without half-turn taps. – Tim Aug 14 '19 at 12:13
  • RE: your last paragraph: If the option were available and considering the modest increase to the price of a typical home, I'd jump at the option if it was available. – BillDOe Aug 14 '19 at 18:56
    @BillDOe if you ask the builder to do it adding it into the project should be an easy change. The builder won't ordinarily suggest it because they'd rather use any time spent trying to upsell you on changes with much larger profit margins. – Dan Is Fiddling By Firelight Aug 14 '19 at 20:12
  • Dan, agreed. But you've apparently never dealt with Lennar. They won't add ANYTHING that isn't on their approved list of add-ons. At least ours wouldn't. – BillDOe Aug 15 '19 at 20:55
14
It would be difficult to install area shutoffs in most residences, since they need to be accessible to be useful. The best case scenario is an access panel in the floor or wall, the worst case is outside the room in an adjoining room or closet.
Even more damning is the fact that they would, by definition, be in non-standard locations. I pity the poor plumber who's faced with a closed shutoff someplace between the main and fixture shutoff. If it's a newly purchased home, or the knowledgeable person isn't home during the service call you'd never find it.
Matthew Gauthier
  • 3,440
  • I believe in some countries they *do* have a shutoff in each room - and they get around this problem by just having the shut-off visible :) – psmears Aug 13 '19 at 13:20
    No one wants it visible. Not only will it cost more to install, the building will sell for less money because it looks schlocky. Valves can also leak. – Mazura Aug 14 '19 at 00:42
    @Mazura - just not true. In some parts of Europe they're there to be seen. More costly to install - but will save money when there's a problem later - plumbers aren't cheap! Doesn't affect house price. Yes, they can leak, but it's rare. – Tim Aug 14 '19 at 07:07
  • Obviously the people in Spain don’t think it looks schlocky. At least not the ones that actually notice a couple of five centimeter wide bumps just under the ceiling behind the door. – WGroleau Aug 14 '19 at 14:17
  • @Mazura: afaik house prices are not affected because *all* buildings in the country are required to have them. And yes, valves can leak... and so can pipes, joints, fixtures etc! In many ways it's better to have a leak somewhere where it's (a) visible and (b) easy to access and fix :) – psmears Aug 14 '19 at 16:34
There are - just not usually in houses
Commercial, industrial and multi-residential buildings almost always have isolation valves for floor or unit take-offs and for each "group" of fixtures. What constitutes a "group" depends on the layout of the building. Basically its a design balancing act between the how large an area has to be shut down for repairs or modifications versus the additional cost in valves, access panels and additional pipework.
Repairs and maintenance requiring water isolation in a house are relatively rare and only inconveniences one owner so these additional valves are not usually justifiable.
Dale M
  • 380
  • This is a really good answer. Individual vales would let me, the plumber, wash my hands for lunch. So by all means, start putting them in at your own expense. tl;dr: not your problem. – Mazura Aug 15 '19 at 22:21
  • The only reason that you would do this is so that you can slumlord yourself while being minus a bathroom. And I don't see how you could justify spending extra money after having to spend money on emergency repairs, just so that you don't have to pay emergency prices in the future. The cost-benefit says *nope*. #learn how to sweat copper pipe, then you can at least put a cap on a run that's fubar. – Mazura Aug 15 '19 at 22:36
In France it's commonplace. Not only having small shut-off valves for hot and cold, but also to toilet, washer, dishwasher shower and water heater feeds.
There's also manifolds near the rising main and off electric boilers, which isolate each separate feed. Possibly over the top, and meaning more potential leaks, but nevertheless useful on occasions.
It's probably linked with their thinking on electric circuits, where each room has an individual fuse/circuit breaker, unlike U.K., where ring mains are the usual situation.
Tim
  • 5,198
  • The same in Germany. – gerrit Aug 14 '19 at 06:57
    I don't think electric circuits are all that analogous (in Czechia, we have room breakers, but there's still just one water valve). It's very cheap to do this for electric circuits; the only extra cost you're paying is the extra wiring, which you would probably want anyway. For water, you need just as thick pipes, and that means lots of water wasted standing in the pipe (especially a problem for hot water). And while having to shut off a room from electricity is relatively common, water usually has issues with the fixtures, not the piping - adding valves makes the problem worse, not better. – Luaan Aug 15 '19 at 09:16
This really depends on the style of home and the floorplan. For example:
  • My previous home was a 3 story town house with a kitchen, utility room, and half bath on the 1st floor and full baths on the 2nd and 3rd floors. As with most modern designs, all of the rooms with water service were stacked over another to minimize the amount of plumbing that needs to be run. Trying to divide up the water service by room or by floor in that house would be a terrible idea because all of the lines would still be running through the same areas of the same walls.
    1. You can't see the lines inside the walls so you'd have no idea which one is damaged and no idea which room to turn off.
    2. There would be a risk that one line is badly damaged with a large leak while an adjacent line has a smaller leak. Shutting off only the line with the larger and more obvious leak would make it seem like it was under control but there would still be water flowing into the wallspace from the second, smaller leak. You'd have to shut off the whole house anyway to be sure nothing was leaking.
    3. If you double the number of lines running through an area of wall then you double the chances of hitting a line while hammering a nail in that area of wall. Triple the number of lines, triple the chances of hitting a line. Etc.
  • I currently live in a single story ranch home with 2 full baths at one end and a kitchen, utility room and half bath at the other. There are 2 very obvious zones and since the utility room is towards the middle of the house there is never any doubt which zone a water line belongs to. With this layout it would have been silly to not put in supply valves to control the 2 zones independently.
All of this talk of multiple valves and water lines is really just a distraction from the actual problem here: you drove a nail through a water line. Whether you have 1 set of lines or 5 sets of lines, you are still spending time and money to cut open a wall, repair a water line, and do all the necessary clean up. In areas with open space, the lines should be hanging somewhat loose so if a nail comes through it will push the lines aside rather than puncture them. In spots where the lines cannot deflect. such as when passing through a wall stud, there should be a metal blocking plate to protect the lines. With proper installation, the chances of damaging one with a nail should be very small.
krb
  • 121
Here in the UK you commonly find a stopcock in the kitchen for the cold supply to everything except the sink, in the cupboard under the sink (Sometimes the hot as well, but most appliances are cold fill only these days).
I imagine this is because if an appliance like a washing machine or dishwasher is leaking slightly, it's not immediately obvious which appliance. Also getting at its service valve usually means pulling the appliance out from under the work-top and then crawling behind it, which may be beyond the strength or agility of some householders. It gives you the option to easily turn off the appliances without ending up with an uninhabitable house with no water at all.
It was a god-send when my downstairs neighbour told me he had water tricking through his ceiling. It wasn't a faulty appliance. Turned out a rodent had got under the floor and had chewed through the water pipe to the appliances. Had to dismantle half the kitchen to fix it, but fortunately I still had a kitchen sink and bathroom while that was sorted out. BTW always check whether your insurer excludes rodents chewing through pipes or wires before it happens -- it's expensive if they do.
nigel222
  • 778
Tradition is not to do it ; It is difficult to get contractors or plumbers to change. When I drew up my house plans I put a valve at each water use point ( You don't need each room). Although I was there most of the construction I missed that the plumbers did not put in shut off valves for either tub/ shower . I need them now , it is very inconvenient to shut off the whole house. My required shut off at inlet AND outlet of hot water heaters has been useful. Likewise , the framers want 24" doors on bathrooms ; I supervised one and got the 36" door shown on the drawing. I missed the second one and had to take out the framers 24" and put in a 28" rough opening after the framers left.
blacksmith37
  • 8,271
  • Why would you want a shut off at the outlet? The situations in which that would be useful seem extremely few and far between. And even if you did use it, then it sounds like the fixture would get backed up quickly. Do you have any examples of a time when this was a good thing to have? – Aaron Aug 14 '19 at 16:47
  • When replacing the water heater. When a single control mixing faucet is opened , cold water may run into the hot pipe back to the water heater. A problem when the water heater is not there. – blacksmith37 Aug 14 '19 at 19:08
  • If you didn't have elevation drawings you can't really blame the plumber. Also: your fault for signing the check. – Mazura Aug 15 '19 at 22:48
