I need to build a 2'x16' ramp to load a shipping container on a semi trailer. What is the cheapest design of 2x boards and plywood to do this with?
EDIT: I have now built this ramp and used it twice (to load a shipping container on a trailer and then unload it). Your needs may be different from mine, and I can't give a good prescription, because I started with something obviously too weak and then built it up until adequate--an inefficient way to go about it. But if I were to do it again, I would try 1/2" ply, two full-length (16') high-quality 2x4s, and a vertical brace built from a single 8' 2x6. It should have some way to physically connect it to the upper loading surface (container floor etc.).
This would result in a very light-duty ramp without much extra capacity built in, so it's important to build it thoughtfully. I used heavy-duty, long deck screws (torx and square heads; don't bother with phillips or pozidriv).
The vertical brace at the middle of the ramp is critical--it creates two 8' spans instead of a single 16' span. The brace needs to be constructed to handle some side loads (cross bracing) for stability.
I also used commercially bought ramp ends from Amazon, designed for loading an ATV into a pickup bed on two 2x8s. I hoped to screw these into the wooden floor of the container, but the trailer chassis interfered. So for loading the ramp, I used climbing-spec nylon cord and rigged it (trucker's hitch and carabiners) to give me 3:1 mechanical advantage in tying the vertical brace to the truck chassis (the wider the angle the more stable). For unloading, U.S. Customs had cleverly buried the cord & 'biners under all my junk when they reloaded the container post-inspection, so I just used the ramp more gingerly, without tying it off.
Having said all that, 95% of my stuff didn't really require a ramp--it could be lifted by hand onto the container floor while standing on the ground. The ramp only marginally sped things up. And if you REALLY needed the ramp--for very heavy items, loaded by a pair of very heavy moving guys--you WOULD need a beefier ramp than described here.
Phil Esra
  • 718
    Have you looked around for rentals? That much lumber is going to add up. – JPhi1618 Aug 27 '19 at 21:45
  • @JPhi1618 Interesting point--I was picturing taking the ramp with me and using it to unload the truck (shipping container) at the other end of the move (6 weeks later...in Scotland). – Phil Esra Aug 27 '19 at 21:51
  • How high is the deck of the truck? – computercarguy Aug 27 '19 at 22:17
  • @computercarguy 4-5 feet according to the moving company. – Phil Esra Aug 27 '19 at 22:27
  • The Code allows a maximum of 1:12 slope for ramps. A 16’ ramp can only extend 16” vertically. – Lee Sam Aug 27 '19 at 22:32
    Moving company trucks typically have ramps on board – Kris Aug 27 '19 at 22:35
  • @LeeSam, this temporary moving truck ramp will definitely not meet ADA accessibility specs or any other legal codes. – Phil Esra Aug 27 '19 at 23:43
  • @Kris the moving company has made it clear there is no ramp provided. It's an unusual situation--a shipping container on a semi trailer chassis. The container will then be shipped overseas and placed on a different (EU-spec) semi trailer belonging to a different company. Neither trucking company is optimized for people who don't have loading docks or forklifts. – Phil Esra Aug 27 '19 at 23:43
I'd suggest doing something like this:
Since this is a long ramp and your plywood is going to be joined in the middle, I'd suggest cutting your 2 of your 2x8' in half, then use full 8' lengths to bridge the plywood gap and using the 4' sections to extend them to each end. You'll have to brace each juncture (2x4) a bit more, but that can be done with a little scrap from your other cuts. This ramp has the double cross brace in the middle, which is where your plywood should meet. The only end of the plywood that shouldn't be fully supported is the one that meets the ground.
Don't forget the cross bracing between the 2 sides as well as the diagonal bracing on each side. The pic doesn't have diagonal bracing on the sides, but the taller end will need something to keep it from parallelograming out of shape. Besides the diagonal brace at the back of the ramp, like the pic shows, there should be at least one other diagonal brace on a ramp this long and tall going in the opposite diagonal.
The pic looks to be 2'-3' tall, based on the "human for scale" who is not really very close for scale, so this should scale to 16' long and 4'-5' fairly easily. It even looks like a decent grade, so you aren't pushing carts straight up.
Also, don't forget to put wheel guides on the sides of the ramp. You don't want a cart or dolly to fall off it at 4' high. That's a disaster waiting to happen, even without OSHA involved.
You might also want to at least consider adding some "outriggers" at the tall end, so it doesn't fall over if things get a little rough. That can be as simple as some more diagonals from the top of the ramp, perpendicular to the ramp itself, with some more 2x4 at the base to tie it in.
Even though you plan on having those ramp ends attached, you don't want to skimp too much on the safety aspects. If you're filling that whole container, you're going to be walking up and down the ramp very many times, probably with heavy things in tow, and even screws have a nasty tendency to rip out. You don't want to "pause" your packing for an emergency room trip.
FYI, OSHA regulations are mostly basic safety precautions to protect workers from complacent and cheap employers. There's not really much from OSHA that's overly cautious.
One last thing: your plywood should be at least 1/2" thick, nominally. Less than that at even 3/8" thick is not likely to hold up and 1/4" will break through almost immediately for anything of any significant weight. I was going to suggest 3/4", but that's overkill. You can also go with B grade ply, since you don't need the sanded smooth surface of A grade, and the knots of C grade might not stand up to the abuse of walking on it that much.
I know this sounds like overkill, but even a metal ramp that's unsupported in the middle can get serious wobble and bounce to it that will absolutely destroy a wooden ramp, unless it's made out of at least 4x4s or 2x6s. Even then, without 16' lumber going the full span, you're risking a lot on this ramp.
computercarguy
  • 1,770
  • whoa, that is a serious ramp. Thanks a lot for the detailed explanation--it's very useful! I take your point about the wheel guides--I had wondered if those would be important. I will include them. That's also good to know about plywood thickness. I don't promise to build something as burly as in the photo, but I take your recommendations seriously, and will incorporate many of the points you mention! – Phil Esra Aug 28 '19 at 00:01
  • Like my dad says, "if it's worth doing, it's worth overdoing." I consider that double when it's a safety thing. I forgot to mention that if there's any chance of precipitation, you'll want to add traction tape to the plywood. This is so you don't slide down the ramp all the time. This is the kind of stuff that looks like sandpaper glued to things. – computercarguy Aug 28 '19 at 15:56
  • Is there a reason the ramp in the photo has the 2x4s face up instead of on edge? I incorrectly assumed there would be a big cost penalty for a single 16' 2x board vs. two 8' boards. I bought a sheet of 3/8" ply and six cheap 2x3 boards to play with. As you noted, it quickly became clear that 1/2" would be preferable and that support in the middle of the span would be essential. Now that I have this light-duty "core" I will just beef it up. If I were starting over, I'd try two full-length 2x4s, 1/2" ply, and perhaps a 2x8x8 for mid-span legs + outrigger. – Phil Esra Aug 29 '19 at 04:34
  • They are laid down like that for 2 reasons. First, it's easier to build that way, with better ability to screw the ply into he 2x4's and the 2x4's into the supports. Second, most of the support is done by the uprights, not the 2x4's. Also, if you put the support on edge without many vertical supports, they have the possibility of twisting, removing the screws and your support. It can be done safely, it's just more difficult and less likely to last a long time. You don't have to worry about longevity, but you do have to worry about high traffic. – computercarguy Aug 29 '19 at 16:00
