I have read How do I use three-prong appliances when my outlets are mostly two-prong?.
I have recently moved into a house that has some two-prong and some three-prong outlets.
The place in the kitchen where the refrigerator fits has a two-prong outlet. The house had no refrigerator in it when we moved in. When the new refrigerator was delivered, the delivery person said to go to the DIY store and buy a little adapter. The first couple of days, I ran a heavy duty extension cord over to a three-prong outlet, but when I had time to go buy some adapters, I switched to that method, because I was concerned about the cord being a tripping hazard, as it had to cross the kitchen floor right where the door to the basement and garage opens.
We also have a microwave oven, a chest freezer, and a computer running on adapters. They are all on different circuits except the microwave and the fridge which share a circuit. I know this because yesterday we mapped the circuits by turning on all the lights and then flipping the circuits one at a time and observing the results.
We are planning to resolve the problem at some point. How quickly should we do that? Within one week or one month?
aparente001
  • 773
    Are there any GFCI protective devices in this house? Or is this full-on 1953? – Harper - Reinstate Monica Sep 12 '19 at 04:01
    Can you get us some photos of the breaker panel? – ThreePhaseEel Sep 12 '19 at 04:13
  • @ThreePhaseEel - I will try to do that tomorrow. – aparente001 Sep 12 '19 at 04:48
  • @Harper - I haven't found any outlets with the little red button. However, there are some special outlets in the two upstairs bedrooms that have six places to plug something in (built in). – aparente001 Sep 12 '19 at 04:49
    Have you checked that the 3-prong outlets actually have a ground connection? That seems like the sort of thing that's worth checking. – user3757614 Sep 12 '19 at 06:34
  • Can you post photos of the insides of a few representative receptacle boxes (both 2-prong and 3-prong) as well? – ThreePhaseEel Sep 12 '19 at 11:45
  • It depends on how you plan to resolve the problem. It could be left with an adapter forever and it is not much different than just adding a GFCI. (I would not put a fridge on a GFCI) GFCI’s on the counter close to the sink is a really good idea for safety. You still will not have a ground if one is not there but a GFCI will limit a shock you might get to a tingle, instead of possibly something that could be much worse. I don’t use GFCI’s on fridges because motor loads tend to trip GFCI’s and spoiled food in this case is a higher risk than a possible shock for a fridge (my state Allows this). – Ed Beal Sep 12 '19 at 14:52
  • The buttons may not be red. Do any of the circuit breakers have TEST buttons? – Harper - Reinstate Monica Sep 12 '19 at 15:40
For older appliances and such, pre-electronics, it's only a safety issue and even then, only under the worst case scenarios. The National Electric Code is all about those worst case scenarios however, hence the requirement. I'm not minimizing the safety aspect, I'm just saying that people survived for a LONG time with 2 prong outlets.
That said, the OTHER issue (which was not really an issue when the change was made) is that electronics, or more specifically anything that uses a "Switch Mode Power Supply" (SMPS), needs to have a solid reference to ground so that it can deal with what's called "Common Mode Noise" created by the power supply itself. Now virtually EVERYTHING you see with any sort of electronics in is has a little SMPS, all of them creating CM noise on the line. With no reference to ground, that noise builds up, potentially degrading the life of your electronics. So the longer you wait to fix it, the shorter the life of your computers, TVs, phones, "smart" appliances etc.
But per that other thread, in a lot of cases, older houses were wired with what's called "BX" cable; flexible metal covered conductors, and that was grounded, then the outlet and switch boxes were steel as well, all connected together. So if that's what you have, AND you have a metal screw (not plastic as they are now) holding the cover plate on, you WILL get a ground connection by using those adapters and attaching them via that metal screw.
Here is a better thread illustrating this concept.
What is the purpose of the "grounding" tab/wire on a 3-prong to 2-prong adapter?
JRaef
  • 14,844
  • 39
  • Most switching power supply's for phones and small loads are 2 prong not 3. A high neutral voltage can cause problems because of the harmonics created by switching supplies. An NEC approved method is to add a GFCI , then 3 prong outlets can be added but must be labeled “GFCI protected no equipment ground” many homes built prior to the early 70’s have this setup as adding a new separate grounding wire was not legal until recently and it won’t shorten the life of the supply. – Ed Beal Sep 12 '19 at 14:36
  • Yeah, agreed with @EdBeal, your comments about SMPSs needing ground are not true. It depends on the design of the SMPS, but there are many that do not need or use a ground connection, and they work fine. And those that do use ground are generally using it to avoid radiating too much EMI for regulatory purposes, and won't be damaged if it's missing (such as if it's plugged into a non-grounded GFCI, which is perfectly legal). – Nate S. Sep 12 '19 at 16:25
  • FYI - Microwaves and refrigerators are not very compatible if they are on the same circuit. They have a tendency to make circuit breakers trip when they are paired up. You might want to put them on different circuits. – Retired Master Electrician Sep 12 '19 at 19:32
  • Well, when I plugged in the adapters I bought, I ignored the little metal loop. Now I see that I should install them properly by unscrewing the screw, placing the adapter with the correct orientation, and then putting the screw back in. (I checked, and the screws are metal.) // What about the power strip with the built-in switch that I use to plug in my computer, monitor, printer, portable phone? How does that play in to all of this? Or should I ask a new question about that? – aparente001 Sep 12 '19 at 21:45
