I just moved into a townhome (the shower itself installed at time of construction in 2011). I am concerned with cracking of the shower caulking with discoloration. I am going to rip out all the old caulking and replace it with 100% silicone caulk (edit: I think they actually may have put caulking over grout?), but I am curious what people think about what appears to be a bad tape job on the drywall on the floor below or if maybe the mark on the drywall could have been caused by water getting into the crack and seeping to the floor below.
I sprayed the crack to see if anything major was happening but the drywall appears to be the same and does not feel wet to the touch. The drywall just feels like the tape is loose (I'm not an expert at all, not even close). The shower is about 3 feet away from where the mark on the drywall is down below. Could the crack in the pictures have contributed to the drywall being the way it is? Can water travel 3 feet in between floors or would it have to be directly underneath. Any opinions on the drywall would be appreciated. Today I am going to the store to buy a fan and the proper tools to replace the caulking in the shower.
I am worried that from this crack in the caulking on the 2nd level shower has perhaps caused what I am seeing on the 1st level kitchen ceiling drywall.
Follow up
I don't know if my link was changed to embedded photos by an admin or if it just did it automatically but the best I can figure out right now is how to have imgur posts appear as a hyper link. I'm having difficulty figuring out how to just have an image appear in the post without a hyperlink. Apologies. The "Follow Up" hyperlink is the pictures after a brief time with a putty knife just to show a little more detail perhaps. Thanks for all the responses. I also appreciate the reputation points! It appears I need 15 to sign up, I really like this website and can't wait to sign up!
  • Are you sure it is caulk and not grout? Are you talking about drywall in the room below the bathroom? clarify please. – Alaska Man Oct 08 '19 at 21:11
  • The flex joints around the shower do seem to be a different material than the grout in between the other tile, it feels like caulk, not grout. Is it possible though they put caulk over grout? And the drywall in question in the kitchen ceiling on the level below the shower. The mark on the kitchen ceiling drywall is about 3 feet away from where the crack in the caulking in the shower is on the floor above. – Nikolaus Nowak Oct 08 '19 at 21:17
    It sure cracks like grout. The ceiling looks like a bad tape job, there would probably be water stains otherwise. – JACK Oct 08 '19 at 21:31
    25% chance it's just a bad tape job. 50% it's water damage. However, 25% chance it's from people who don't dry off before they get out of the shower, washing dogs, etc. Regardless, fix the crack (and it's up to you to wait on the patch or not). I prefer grout though. The *next time*, give up and use caulk. – Mazura Oct 08 '19 at 21:45
  • I just took at it with a putty knife. I know a putty knife can remove grout as well as caulking. Unless grout can get soggy making it resemble caulking, I'm pretty sure I removed at least some layer of caulking someone had applied. It does appear that it may have been caulking on top of grout? I will update with some pics here in a bit. – Nikolaus Nowak Oct 08 '19 at 21:46
  • "You can always come back and hack-job some caulk at it. When the time comes to readdress it, I'd rather be dealing with lose chunks of grout than removing old, moldy caulk mess. And if you use caulk, you *will* be readdressing it at some point, instead of the maybe you'd get with grout." – [Related](https://diy.stackexchange.com/a/61917/23295) – Mazura Oct 08 '19 at 21:52
  • It's presumably done 95% of its settling; time for try # 2 with grout again. A 'five-in-one' is your best friend. Don't crack the tile... if it doesn't want to come out then it can stay there, as long as it doesn't wiggle. – Mazura Oct 08 '19 at 21:54
  • Thank you for the responses. I may try to grout the vertical seem down to the shower base. The shower base (white) is a plastic feeling material which makes me suspicious that a grout job there will result in cracking again at some point, which makes me want to apply a 100% silicone caulking around the base of the shower where the white plastic shower meets the tile. – Nikolaus Nowak Oct 08 '19 at 22:02
  • As many have said, that's grout, not caulk. One thing that may be aggravating the problem is if the front of the backer/cement board sits behind the lip of the shower pan. This would cause the lower edge of the tile to rest against that edge, and would move whenever the shower pan moves. – SteveSh Mar 08 '20 at 21:28
  • Any if it's any consolation I have grouted corners cracking in my 3-year old tiled shower stall (done by a pro?). But the wall corners around the tub in another bath are fine after 7+ years with just Si-II caulk. – SteveSh Mar 08 '20 at 21:30
Could the crack cause damage below on a lower floor?
Absolutely most tile is inside the pan but the backer whatever was used is outside so if the water gets past the grout it can run down. I would say that little bubble looks like a bad tape job because there are no watermarks I can see. As far as that is concerned I would use a t pin or hat pin and pole a tiny hole there just to make sure, if the spot was caused by water it may drip and that tiny pin hole can help it to dry out. As far as the hole next to a penetration we go for the best utilization of the Sheetrock the hole could be between 2 sheets as any pro will tell you.
The crack can be caused by the corner not being tied when I plan on installing tile I lock the corners (framing together so they will not flex and crack. If not tied calking is better than grout
Last I have pulled dozens of shower and tub shower surrounds that had no barrier. I have found some builders that glued the tile directly to water resistant Sheetrock, I have also seen many with backer board and nothing else. It is possible the crack originally was just calking I know contractors that regularly do this to try and prevent corner cracks. Clean it out the best you can and fill with calking, make sure to use a kitchen & bath type these have mold inhibitors. Good luck.
Cracks (gaps) in either grout or sealant lead to often devastating consequences.
Everyone thinks, "It's such a narrow crack, it can't possibly be the root cause of my serious leak." But it is...
Think it through though. If a crack (gap) is just 0.1mm wide but occurs over a total of 1M in length then you a total of 100 square millimetres of gap. That's the same as having water literally pouring through the equivalent of an 11mm dia hole!
Yes this type of crack can cause water to seep behind the tile. What happens next depends if there was a waterproof membrane installed behind the tile or not, but you can't check for this without taking off the tiles. It depends on when the bathroom was built, when it became mandatory, and if the contractor was cutting corners or not, so personally I wouldn't assume there is one.
The corner grout joint in showers often cracks if the building structure is not rigid, for example in wood structure buildings. That's why it needs a silicone caulk joint, which will stretch without breaking.
You need to take the grout out of the joint, but don't insert a blade or anything sharp into it, as that would cut through the waterproof membrane behind the tile. I use a plaster spatula with rounded corners for this, but any metal implement with a rounded tip will work fine. No need to dig deeply, and certainly not deeper than the thickness of the tile.
Once the cracked grout is removed you can clean it and apply silicone. If you want to do it right, insert a small foam bead into the joint before:
This prevent the joint tearing fro the back, and makes it a lot easier to replace in the future.
bobflux
  • 8,767
No that crack cannot cause the shower to leak.
There is a waterproof layer somewhere behind the tiles if that has holes that would cause a leak.
the the mark on the drywall does not look typical of water damage, it looks more like a failed join. could be structural, could just be a bad mudslinger.
Jasen
  • 19,044
  • Thank you for answering this! I was assuming there was some sort of protection as you mention above, and I tried to find videos of people installing showers, ripping showers out, etc. but I could not really confirm anything from my search so I greatly appreciate your comment! I can breathe a little easier, and now it's just an issue of getting the shower job completed. Maybe one day I'll have the drywall smoothed out but for now I'll just keep an eye on it. – Nikolaus Nowak Oct 08 '19 at 22:13
    @Jasen On what are you basing your conclusions that, "There is a waterproof layer somewhere behind the tiles" and "the the mark on the drywall does not look typical of water damage"? He presented no images or video that support either, partially or wholly. – tahwos Oct 09 '19 at 22:19
  • tiles aren't waterproof, there's always a waterproof layer behind them in a shower. (the tile surface is usually waterproof but the grout is porous) the straight-line blemish next to the recessed lamp does not look like water damage, it looks more like some sort of joint problem, putting a join so close to a penetration seems a bad idea. – Jasen Oct 10 '19 at 02:31
    No there is not always a waterproof layer behind the tile. A properly installed shower would have a barrier but I have seen dozens that do not have a barrier, even worse is the super cheap jobs over water resistant Sheetrock. There out there! – Ed Beal Oct 10 '19 at 19:26
