We had an energy audit done a couple of years ago on our 20 year old home. Basically, they hooked up a blower to the front door, and tested the amount of air leakage.
The written report suggested a number of improvements, most of which we did: new windows, doors, sealing attic hatches, etc. The total spent was around $15k.
Because there's a local government plan to cover some of the expenses, we had a follow up audit done.
The overall score from the follow up was exactly the same. This really baffles me, because I know in a couple of places (pre-repair) I could feel a breeze coming in, and the candle test showed it.
Will I actually get any savings from my new, expensive, energy-star compliant doors & windows?
chris
  • 3,271
Plugging air leaks in you home is a bit like sticking fingers into a leaking dyke. Plug one hole and another one breaks through. Generally, the situation should have improved with new windows and doors (if installed properly).
The technician doing the post-audit should have identified where the air was coming from so you could fix that too.
One possibility is that a fire place flue or external fresh air duct to your funrnace was open during the blower test. This would have let a huge amount of air in. Other things to look for are stuck flapper valves in bathroom and kitchen vents.
Another place to check and seal would be around the sill plate. Often there are a number of small air leaks here. Individually they are not large but in sum they can amount to a significant air leak.
Doresoom
  • 15,623
  • 80
  • 118
