12
I've got some door moldings that are about 1 inch from the adjacent wall. A caulk gun won't begin to get in there, and pivoting the caulk tube up so it's nearly parallel to both walls still doesn't get the tip close enough to the gap.
How should I apply a caulk bead in this situation? Any good tricks, clever tools, or "this worked well enough for me"?
Rough illustration of the situation:
illustration
(source: CoSketch.com)
Jeremy W. Sherman
  • 1,835
In addition to DA01's suggestion, there are also smaller tubes of caulk that may be thin/small enough to angle into the casing corner. More costly, but you only need a little (if it fits).
caulk
bib
  • 33,635
  • 100
  • I've always seen the big, solid tubes. A toothpaste tube of caulk would be just the thing. I'll pick one of these up the next time I'm out acquiring more widgets. – Jeremy W. Sherman Sep 19 '12 at 02:51
    @JeremyW.Sherman There are new, mini-sized widgets, for those occasions when you only have 1 inch between widget sender and widget receiver. – bib Sep 19 '12 at 03:00
If it's an interior door, I'd suggest not bothering. If you can't easily get the tube in there, my guess is you can't easily see it, so it's probably moot.
If it's an exterior door, two ideas:
  1. remove the trim, apply the caulk, re-apply the trim
  2. cut a small bit of surgical hose and attach it to the end of the caulk and use that to apply it.
DA01
  • 24,235
  • 27
  • 76
  • 146
  • The surgical hose is clever. My first thought was a straw, but we had none handy, and I imagined it would just break in the middle or go shooting off to nowhere. – Jeremy W. Sherman Sep 19 '12 at 02:49
    Try a wide diameter drinking straw, or get a short length of clear plastic tube from any hardware store. – GdD Sep 19 '12 at 08:13
