I have an old farmhouse with a bathroom vanity, laundry room, and kitchen sink/dishwasher draining into a single septic run. There aren’t any vents installed in the system with only a crawl space under the two rooms. Is there a way to add a vent in the crawl space or without running it up through the walls or ceiling?
Asked
Active
Viewed 3,332 times
1Vent stacks were very often run outside the home in the old days. Attached to siding and ending above the eaves. – Kris Jan 17 '20 at 14:16
1Related question with good info https://diy.stackexchange.com/questions/58657/does-a-plumbing-vent-need-to-penetrate-the-roof-can-it-penetrate-a-wall – Kris Jan 17 '20 at 14:32
1Not a duplicate they are asking if they can vent to a specific location that is not covered in that answer. The vent needs to be above the level of the drain at a minimum or any backups the vent becomes the drain. – Ed Beal Jan 17 '20 at 16:54
Wouldn't moisture be an issue? I saw where someone had vented into an attic. It was dripping wet up there, even with gable vents. – Keith McClary Jan 18 '20 at 03:44
If allowed in your location an air admittance valve can be added. It needs to be close to the level of the drain. I put them in the sink cabinet as close to the top as I can. I agree with @kris my 1930 farm house has the vent outside several Victorians I remodeled also had them outside. But an AAV if allowed is the easiest but not in the crawl space.
- 4
- 75
- 153
